I have RT15 which are just regular bookshelf speakers as my side surrounds and FXi3(triangular cabinet Bi-directional)as my rear surrounds in my 7.1 setup.
I need your expert opinions if I should leave the setup the way it is or should I move the rear Fxi3 to the side surround spot? The main seating area is directly in line with the side surrounds(currently the RT15's).
What if I completely eliminate the RT15 as side surrounds and just swap them with the FXi3's?Will they give me a better effect? Right now,I'm not sure if the Fx13's are being used to the fullest (or it seems that way) since they are about 9 ft behind the seating area.
I'm running them off a Pioneer SC 1525.
Thanks in advance for your input.
