Still gain access to it via the controller and wireless head set?
I would think I could but I have a client that claims it does not work, I thought that the controllers are Radio Frequency?
Thanks,
Sal
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreStill gain access to it via the controller and wireless head set?
Thanks,
Sal
Polk Audio SDA SRS 1.2TL's
With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
It All Started here: http://tinyurl.com/lasareath2
Part Deux: http://tinyurl.com/lasareath3
Mine is in a particle board equipment rack that has a drop down door. If I close the door the controller is not 100% responsive, and that is a distance of about 4 feet.
Wow OK, Thanks.
So I need to figure out how to boost this signal. I wonder if a remote extender will work.
Maybe either one of these:
http://www.smarthome.com/59501/Smart...-System/p.aspx
http://www.smarthome.com/8045I/NextG...3-B2B9AD155804
Why don't you try it and find out for yourself?
Blue that is odd. I have a closed tv cabinet and am constantly walking to my fridge for beer >20' away and can still talk on the headset and move around without a hiccup. Is your cabinet made of lead?
YMMV i guess![]()
Anthem 2.0 - Anthem TLP1 & MCA20, CA DacMagic, RTiA5's, HTS 1600, MIT EXp2 Cables, Audio Technica TT, Aurial Thrils Int's
Anthem HT - Anthem MRX300, RTIA3's, RTIA1's, CSIA4, DSW400, 55ST30, APC H15, 360 Elite, Panny DMP-BD35K
Rice is great when you're hungry and you want 2,000 of something - Mitch Hedberg
The 360 controllers operate on 2.4ghz... so if you're having a distance problem, it could be because of wifi saturation in your area. Sometimes, it's as simple as changing the wifi channel on your router. It's a rare problem, because the 360 controllers and wireless headsets use frequency-hopping to avoid this issue... but if all your neighbors are close and rockin' wifi, you can have issues. I've seen people change to wireless-N 5ghz for their wifi and that fixes their 360 controller issues.
There's no easy way to extend them, sadly. That said, I get a solid 30-35 feet from my 360 before it loses the controller (though the wireless headset has a little shorter range). Your only option would be to modify the 360 hardware so you can extend the wireless antenna outside of your cabinet, and I don't know if anyone has even tried that yet. The only setups that I have seen work for a hidden rack setup are using wired controllers with a USB extension built into the room.
Equipment list:
Onkyo TX-NR1007 9.2 AVR
Emotiva XPA-3 amp
Polk RTi70 mains, CSi40 center, RTi28 surrounds, rears and heights
SVS 20-39CS+ subwoofer and Buttkicker LFE, powered by Crown XLS1500
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens 100" Matte White screen
Yes you can. It just depends on the location and if there is any interference from other devices in the area. I know this because it took a while to get mine working just like the OP describes. But it definitely is possible - with a little work.
Thanks all except decal.
This is for a client and his Son's closet.
Decal, I don't need to try it at my house. My closet would be different than my client's closet.
I can confirm it will work if you install an IR blaster to it. I have mine installed in the rear of the HT, in a cabinet. Wireless controller maybe an issue for you depending on distance, though not sure.
Shoot the jumper.....................BALLIN.............!!!! !
Home Theater Pics in the Showcase
http://www.polkaudio.com/forums/show...p?userid=73580
There are currently 1 users browsing this thread. (0 members and 1 guests)
