Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 61 to 80 of 80
  1. #61
    Member Sales Rating: (0)
    Join Date
    May 2012
    Location
    Pittsburg, CA
    Posts
    333
    Default
    Hey I got the same feelings when I installed the Adcom 585 until I ran the audessey again and that made a big difference.
    AVR-Onkyo709
    AMP- Parasound 2125, Adcom 585
    Mains for HT and some Music- RTi12s
    Main for Music only- Linn Keilidh or Usher V-601
    PreAmp for Music: B&K AVP-3090
    Rear- RTi8s
    Center-CSi5
    Sub-JBL L8400P 12"
    Player- Oppo BDP-103
    TT: Philips 406
    Phono Pre-Amp: BBE FJB-200X
    Bedroom rig:
    Pionner Elite VSX-30
    Onkyo CS-5VL SACD Player
    Polk Audio LS70
    Hunting for a sub...
  2. #62
    Member Sales Rating: (1)
    Join Date
    Jul 2001
    Location
    chicago
    Posts
    16,084
    Default
    Quote Originally Posted by snake1 View Post
    Is that not the role my Onkyo is playing?
    Yes it is, but for music it does about as good a job as 87 octane does for a Corvette. Everything matters in your chain, a pre amp would help some sure, also get yourself some better cables than that Walmart spool stuff along with some better interconnects.
    An amp's job is to supply power when the speaker demands it, giving you better clarity, definition in the bass notes, and a more insightfull look into the music. You've seemed to experience this so I'm not sure what else you where expecting. An amp isn't going to turn the 12's into a subwoofer if thats what you were looking for.
  3. #63
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    Quote Originally Posted by Irrenhaus View Post
    Thats encouraging to know. Should I run Audyssey in the 4-8ohm amp position or the 2-3ohm position its on now?
    Quote Originally Posted by tonyb View Post
    I can handle better wires soon I suppose. I did get some new banana plugs and have them installed already. I realize its not going to turn it into a sub, I just expected more out of the woofers in the 12s I guess. The way people talk about adding amps though just sounds like some 'miracle' difference.
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  4. #64
    Join Date
    Jan 2009
    Location
    NW Indianapolis Indiana
    Posts
    9,150
    Default
    Normally the "miracle difference" are exactly what your hearing now. However without re-run your EQ (or just running in direct only) your using a EQ that is based on the power output from your AVR, not your amp so its not really a fair compare as your amp has reserves your AVR did not have.
    It should be clearer, more focused and better tighter bass, all of which you have mentioned. Plus you should be able to crank it MUCH higher and not have any distortion, however dont crank it till you re-run the EQ.
    Advice is free, the Flea Market is earned - F1Nut
    Main HT: APC H15 | Pio 51FD | Uverse DVR | Xbox 360 | Squeezebox Classic | Integra DTR 5.9 | Carver AV-705x & M1.0t MKII Opt002 | LSi 15 | LSiC | LSi F/x | Kimber Hero IC & 8VS SC
    Office Rig: Win 7 -> DacMagic w/ Pangea PSU | Pro-ject Debut III | Sunfire TGP-II | Parasound HCA-750ii | Polk RTA 11TL | Cables TBA
    Bedroom: Uverse DVR | Roku 2 | Samsung LCD | SurroundBar 2000
    Sales Rating
    Gear
  5. #65
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    Quote Originally Posted by EndersShadow View Post
    Oh ok!!! See I didn't realize that about the calibrations! Makes sense now that I think about it! Cool, I'll try to get it done asap and get back with y'all!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  6. #66
    Join Date
    Jan 2009
    Location
    Posts
    9,150
    Default
    Direct mode for music is the only fair compare as it turns off the EQ curve you created, so you could technically throw in some music and see what difference you hear in Direct mode only.
    Sales Rating
    Gear
  7. #67
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    Alrighty, auto calibration has been run. I'll check back later tonight after I can test it some. I ran auto cal with the amp in 4-8ohm mode since my speakers are 8ohm anyway. Btw, I would tell you how its going now but I just ran it after I put the little ones down for nap... so have to wait a while before I can use any real volume.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  8. #68
    Join Date
    Feb 2012
    Location
    Anaheim, CA
    Posts
    448
    Default
    Sounds like you should have gotten your SVS first. Not that an Amp is bad idea, but seeing that you don't have a sub and do more movies then music the SVS would have put a bigger smile on your face to start with.
    Hope you getter dialed in!
    Polkaudio Fronts: RTi A7's Vr3 Fortress Edition
    Polkaudio Center: CSi A6 Vr3 Fortress Edition
    Polkaudio Surrounds: FXi A6's
    Sub: SVS PC12-NSD
    Marantz SR-7008
    Marantz TT-15S1
    BDP-Denon DBT-1713UD
    Denon AH-D5000's
    Synology DS 212j-4TB
    TV: Panasonic TC P55VT30
  9. #69
    Join Date
    Aug 2011
    Location
    A place called Winnipeg
    Posts
    2,859
    Default
    A few things...
    - Keep that ohm switch at 4-8
    - Check to ensure that the HPF is not engaged in any means on the back of the amp. You could have engaged it and that will not send lows below whatever cutoff is selected.
    - Get some better wire when possible
    How are the speakers placed? Measurements?
    The biggest difference you should notice is not only how full music sounds when playing louder but that bass is tight and solid. Hell go back to your old setup in pure direct mode and throw the amp back in. The 12's hit low, but if you like your bass hot, a sub should have been the first investment instead of using EQ controls which can damage a speaker if your playing it loud.
  10. #70
    Join Date
    May 2012
    Posts
    371
    Default
    ES is right on with all of his replies. Start with the suggestions from various replies. I have this amp and you should notice the differences ES states when listening to music in Pure Direct or Direct mode. However, you will probably not shatter glass but you'll feel the concussions on your body. You may have to do some detective work to look at your source, cables, set-up, placement, etc. as others have stated. Also, my A7's took about 100-200 hrs of use to really open up. Good Luck.
    __________________________________________________ ___________________________________________
    Source: SONOS Music System, DAC: W4S DAC-2, Pre/Pro: Marantz AV8801, Amp: W4S MC5, Front: Polk RTIA9, Center: Polk CSIA6, Surrounds: Polk FXIA6, Sub EQ: DSPeaker Anti-Mode 8033C, Subs: 2 - Polk DSW PRO660WI, IC & Speaker Cables: Signal Cable
  11. #71
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    WOOO HOOO!!!! Did the recalibration and that made the 'miracle difference'!!! Much more bass on tap now all through the range and cranking just moderately starts thumping hard (keep in mind my bass is turned up, but I'll turn that down some now)!!!!
    This was definately the difference I was expecting! I'll start some critical listening in the coming weeks and also give the amp more time to break in. Can't wait now!!! Thanks to all for your suggestions!!! ES and Irrenhaus had the main answer! More info and review coming in the coming weeks!!!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  12. #72
    Join Date
    Jan 2004
    Location
    Quincy, MA
    Posts
    11,641
    Default
    LOL, enjoy Snake!
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Rotel RCD-1072 CDP, Onkyo TA2600 Tape Deck, Pioneer Elite 47-A DVD, Sony 32" XBR TV, Polk RTA-8T Main Speakers, Boston VR-920 Center Channel, Boston PV-600 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  13. #73
    Join Date
    Feb 2011
    Posts
    162
    Default
    Now that you have the amp working to your liking, the next step in my opinion is a dedicated 2-channel preamp with home theater bypass. Your basically following the same path I did, initially I was using a Pioneer Elite AVR (in pure direct) to feed my Parasound 2250 for music. When I added the Cambridge Audio 840E preamp (which has the bypass feature) things really opened up, every part of the frequency spectrum was improved.
    2-Channel System
    Analog: VPI Traveler TT, Ortofon 2M Blue, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  14. #74
    Join Date
    Sep 2008
    Location
    Athens, GA
    Posts
    494
    Default
    ... but for music it does about as good a job as 87 octane does for a Corvette. Everything* matters[!] in your chain, a pre amp would help some sure... Get yourself some better [speaker] cables than that Walmart spool stuff along with some better interconnects*....
    +100 Tonyb! As the the forum's unofficial wire gauge fanatic: BIGGER, better wire will help. Your new "toy" has the RTi 12's five drivers per channel to control. Add to that contending w/a rather complex XO network. Who knows for sure if the mids have HP filtering or not. Oi! Don't get me started!
    Mo' Bigga will help bass output & definition. Mo' Betta will help everything else...at least up to a point*.
    I remember being blown away by the Sheffield release "Discovered." All I heard was music! W/my eyes shut I could place the instruments including the angle of the upright bass!
    Direct recording playedback on Phillips CD player, Rotel 1068, & Belles through my (well broken-in) 'A7s. No tinkering w/EQ, calibration, etc, just attention to placement. Yeah it was a tad on the bright side but SO engaging & otherwise transparent, I didn't care! Oops! Sorry for the derail. Didn't mean to hyjack your thread.
    Give careful consideration to every piece in your PB chain especially your "front end" and what you feed it. The best amp in the world will only tell you how good (or bad) everything before it is.
    Tony
    Samsung 60" LED
    Rotel 1068
    LG BDP
    Denon LDP
    LR: RTi A7*** Biamped w/TDM EXO
    MT: Rotel RB985->AR 12 ga->MT feed & mids wired w/AR 12ga
    Subs: Belles 1 for each LR subs->MC 10ga->wired w/8ga Powerline
    CC: Rotel RB985->AR 12 ga->CSi A6, mids wired w/AR12 * ***
    SW: Seismic Audio powered 18" wired w/AR12
    Surrounds: Hafler XL280->fed & wired w/AR12->RTi A1**
    *Bi** or tri***-amped one day
  15. #75
    Join Date
    Feb 2012
    Location
    Anaheim, CA
    Posts
    448
    Default
    Good to hear snake...ENJOY!!!
    Sub: SVS PC12-NSD
    Marantz SR-7008
    Marantz TT-15S1
    Denon AH-D5000's
  16. #76
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    I haven't forgotten about the write-up! Still getting in some listening and since I have very small children I have to wait to watch a movie at 'desired levels'. I'm REALLY liking it though!!!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  17. #77
    Member Sales Rating: (3)
    Join Date
    Oct 2004
    Location
    Mid-Michigan
    Posts
    3,549
    Default
    What gauge walmart wire are you using? I'm using the 14 gauge stuff, it may not be the best, but it does do a good job for what you pay for it. I'm running a Parasound HCA 1000a in my rig and it just spews detail. IMO if you are going to upgrade interconnects skip the Signal Cables and go for the Kimber Kable PBJs. You will hear an improvement in detail as well as sound stage over those monocables.
    Speakers:SDA2a, sub:Atlantic Technologies 172 PBM
    Pre:B&K PRO-10MC(2ch)
    Amps:Parasound HCA 1000a
    SourcesOppo DV-970HD, Xbox360, Kenwood KT-5300
    Cables:Philips/RCA/Monster
    Life's short, Listen to SDA's
    Life is short live Sui Juris
    Where did SOPA go?
  18. #78
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    Quote Originally Posted by dudeinaroom View Post
    Yes I do have the 14ga wires for wally world. I also believe it does fine for the value. That being said, I have never heard 'good' cables so I have nothing really to compare to. I do hear a considerable amount of detail now that the 2250 is set and running well! I'll check out the cables as soon as the play $$ fund is back in the black
    Thanks for the suggestions!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  19. #79
    Join Date
    Aug 2012
    Location
    West TN
    Posts
    553
    Default
    The review has been posted here
    http://www.polkaudio.com/forums/show...15#post1844815
    just fyi to any interested.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  20. #80
    Join Date
    Dec 2010
    Location
    Sacramento Ca.
    Posts
    1,729
    Default
    Nice write up,I'm glad things worked out for you..
    Dan
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Parasound 2250 Power Amp
    By Sherardp in forum Electronics
    Last Post: 07-25-2011, 05:04 PM
  2. Replies: 24
    Last Post: 02-16-2011, 03:56 PM
  3. Couple of Questions about Parasound 2250
    By PrazVT in forum Electronics
    Last Post: 09-17-2010, 04:03 PM
  4. Need Help Parasound 2250 hum
    By NewHTguy in forum Electronics
    Last Post: 04-29-2009, 07:26 AM
  5. Parasound 2250
    By Jockos in forum Electronics
    Last Post: 10-17-2006, 10:43 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
