Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 19 of 19
  1. #1
    Member Sales Rating: (17)
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,302
    Default Car Issue - Need Help - Can't Fill up the Tank!
    Hello All,
    My wife has this problem with her car, it'll only take 1.2 to 1.4 gallons at a time. Every gas station attendant hates her. We've been to two Hyundai dealerships and they are clueless. The first time they said it was "Spiders", that the spiders make webs in some air valve/filter and after they vacuum it it'll be fine. It was good for one fill up.
    Please see the Video, Have you ever seen this?
    Thanks,
    Sal
    Polk Audio SDA SRS 1.2TL's
    With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
    My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
    It All Started here: http://tinyurl.com/lasareath2
    Part Deux: http://tinyurl.com/lasareath3
    Car Stereo---->http://www.salsleaf.com/leaf_stereo/index.htm<---- NEW for 2013
  2. #2
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,302
  3. #3
    Member Sales Rating: (0)
    Join Date
    Apr 2012
    Location
    Snellville, GA
    Posts
    570
    Default
    Problem with the evaporative emissions charcoal canister.
    My humble setup...
    ...is no more.
  4. #4
    Join Date
    Apr 2013
    Location
    SLC, UT
    Posts
    43
    Default
    just a guess, but like above, would make sense that the vent isn't venting well.
    Always use the slowest pump speed. Doesn't seem like it would be a problem unless it's not venting at all, and maybe a minor inconvenience when fueling up.
  5. #5
    Join Date
    Apr 2013
    Location
    SLC, UT
    Posts
    43
    Default
    wait, what car is it? the green pump makes me think of diesel, and diesel foams, and will cause the auto shut-off in the handle.. it's normal. if not, then see above.
  6. #6
    Join Date
    Dec 2012
    Location
    North Of The 49th
    Posts
    819
    Default
    Quote Originally Posted by Clownbaby View Post
    I agree, venting issue. I thought it was diesel at first too, but don't think the Sonata has a diesel in N.A. and when she selects the gas button, looks like one of the 3 gasoline options. I have a diesel and it has a venting button a few inches into the filler neck that can be pressed with the side of the nozzle to let air escape because diesel foams so much. If the fuel's going in, it has to move the air out. Possible that the filler neck got whacked with a rock or whatever and now has a restriction. But...this is happening to a lot of the same model? Anyway, whatever's causing it, I don't think the air is getting out fast enough.
  7. #7
    Member Sales Rating: (6)
    Join Date
    Feb 2002
    Location
    Rockledge, Florida
    Posts
    11,588
    Default
    Quote Originally Posted by goofyGAguy View Post
    Yes my guess also and the first thing I would replace.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  8. #8
    Join Date
    Feb 2002
    Location
    Rockledge, Florida
    Posts
    11,588
    Default
    Hey Sal.... Did you see this post on the other thread?
    "The dealer was informed by the Hyundai technical support people of a check valve that they were unaware of. Once the check valve was replaced, they were able to fuel the car without difficulty. Unfortunately, the fuel level sensor in the gas tank was damaged through all this work, and it won't be fixed until tomorrow afternoon. I will be so happy to get my car back. I wonder if this fueling problem is general, or is confined to Hyundais. Thank you for your input."
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  9. #9
    Join Date
    Dec 2010
    Posts
    115
    Default
    Quote Originally Posted by disneyjoe7 View Post
    Have heard other makers having the same issue with some of their models, not sure who?
  10. #10
    Join Date
    Aug 2011
    Location
    A place called Winnipeg
    Posts
    2,859
    Default
    Boy that is weird. Never seen that before. Definitely venting issue. Try leaving the nozzle out a bit. I think I've had a similar issue with my GF's car and pulling the nozzle out 1-2 inch solved it. Was at a couple select pumps we dont normally fill at.
  11. #11
    Member Sales Rating: (16)
    Join Date
    Nov 2007
    Posts
    3,907
    Default
    This happens on our Mazda MPV.
    The gas pump will shut off as if the tank is full and only a gallon or so has been dispensed.
    It's a stop and go slow, stop and go slow ritual to get a full tank in.
  12. #12
    Member Sales Rating: (9)
    Join Date
    Sep 2006
    Location
    Baltimore
    Posts
    2,478
    Default
    Canister vent valve is stuck closed. Believe it or not the spiderweb explanation isn't complete BS, but on an older Hyundai (Elantra?) it's more then likely the vent valve.
    Wris****ch--->Crisco
  13. #13
    Member Sales Rating: (1)
    Join Date
    Mar 2009
    Location
    Mass-hole
    Posts
    1,683
    Default
    And i thought i had a problem when after filling the tank, it takes about an hour for the needle to rise to full.
    You, sir, actually have a problem!!
    2.0 - Zu Audio Omen MK-1B's, Peachtree Decco65 ,Zu Mission SC's, Audio Technica TT, Bugle2 & Bottlehead Reduction Phono Pre's, PS Audio UPC200, Doug's Int's
    HT - Anthem MRX300, RTIA3's, RTIA1's, CSIA4, DSW400, 55ST30, APC H15, 360 Elite, Panny DMP-BD35K
    Rice is great when you're hungry and you want 2,000 of something - MH
    Looking for new homes....
    MIT EXp2 Cables
    Anthem MCA20
    Polk RTiA5's
  14. #14
    Member Sales Rating: (2)
    Join Date
    Feb 2004
    Posts
    106
    Default
    yeah my work truck has the same problem but worse. it only takes 25 cents worth at a time no matter how slow you pump. i have found one station in town that i can pump on the lowest setting that works. i agree with what was said before its a venting problem.
  15. #15
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,302
    Default
    2010 Hyundai Elantra. My wife made another video today with the attendant filling it and as he walks away it clicks off. She had him try 2 more times and she got 3.8 gallons of gas.
    She's bringing it back in to the Dealer Monday with lots of print-outs from various forums.
    Thanks!
  16. #16
    pepster
    Guest
    Default
    You should print ^ out and take it with you to the dealer.
    That way they know!
  17. #17
    Join Date
    Jan 2011
    Location
    Nebraska
    Posts
    1,615
    Default
    Quote Originally Posted by mrbiron View Post
    Usually if you turn the key off and turn it back on it resets the fuel gauge. They make them slow to respond so when fuel is sloshing in the tank the needle isn't bouncing all over the place.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  18. #18
    Join Date
    Jan 2011
    Location
    Nebraska
    Posts
    1,615
    Default
    Also adding more fuel to the tank after the automatic shut off kicks off can cause problems like this. If you over fill the tank it gets liquid fuel in to the evaptoration and venting system and it causes problems.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  19. #19
    Member Sales Rating: (24)
    Join Date
    Nov 2005
    Location
    Gaithersburg, MD
    Posts
    2,374
    Default
    My bet is the vent valve; happened to my titan and was a fairly common thing with the nissan trucks. Might be the same issue with your car. I would have them check that first.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Amp install next to fuel tank
    By fender1 in forum Basic Hookup/Wiring Questions
    Last Post: 11-20-2008, 03:00 PM
  2. Use your lunch break to fill your gas tank.
    By mrbigbluelight in forum The Clubhouse
    Last Post: 08-18-2006, 04:56 PM
  3. i just want to say tank u guys
    By dallasman in forum Car Audio & Electronics
    Last Post: 04-18-2006, 12:13 PM
  4. Abrams M1A2 tank
    By audiobliss in forum The Clubhouse
    Last Post: 11-10-2005, 08:47 AM
  5. To fill our not to fill. That is the question.
    By jer28lms in forum Car Audio & Electronics
    Last Post: 08-08-2003, 05:48 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
