Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 39 of 39
  1. #31
    Member Sales Rating: (0)
    Join Date
    May 2009
    Location
    Plano, TX
    Posts
    249
    Default
    Quote Originally Posted by westmassguy View Post
    You're correct, however, you could also just remove the polyswitch, install a jumper wire in its place, and increase the value of the 2 ohm resistor to 2.5 ohms. Six of one, half a dozen of the other. It will save you a few bucks.
    I have a different perspective on this one (I just did my 10B XO's): keep two SEPARATE resistors (2 Ohm and .5 Ohm). Why?
    1) Allows for easy "change out" later (I ended up sticking w/the .5 Ohm)
    2) It does alter the behavior of the 12 uF cap somewhat
    It's only a couple of extra bucks...
    Yamaha DSP-A1 Integrated Amp
    (2) Polk Monitor 4's w/peerless tweets (dual centers)
    B&O TX2 Turntable
    Nakamichi Cassette Deck 1
    Pioneer CLD-99 Elite LD
    Samsung BD-P2550 Blu-Ray/DVD
    LG LST-3410a OTA DVR
    Princeton AF3.0HD Monitor
    Optoma HD65 Projector
  2. #32
    Join Date
    Dec 2011
    Location
    Feeding Hills, MA
    Posts
    1,866
    Default
    Quote Originally Posted by StantonZ View Post
    The 5s and 10s are two different animals. The 10s have two 12uf Caps, one is shunting the 2 ohm resistor to affect the voicing of the tweeter in relation to the two woofers, if memory serves, while the other is acting as the high pass filter. The 5 has a single 12uf high pass Cap. There's no shunt Cap. Much simpler design.
    Home Theater/2 Channel:
    Front: SDA-2ATL
    Center: Custom Built http://www.polkaudio.com/forums/show...hannel-Project
    Surrounds & Rears: Custom Built http://www.polkaudio.com/forums/show...rround-Project
    Sonicaps, Mills, RDO-194s-198s, Dynamat & Hurricane Nuts.
    Pioneer Elite VSX-72TXV, Carver PM-350
    "So is there any tread left on those tires or is it just like throwing a hotdog down a hallway?"
    www.dhsspeakerservice.com
  3. #33
    Join Date
    May 2009
    Location
    Plano, TX
    Posts
    249
    Default
    Ahhh...my bad. In that case: it doesn't matter!
    B&O TX2 Turntable
  4. #34
    Join Date
    Dec 2011
    Location
    Feeding Hills, MA
    Posts
    1,866
    Default
    You're correct with the 10s however. The .5 ohm should be kept separate. It's how I did mine as well.
    Front: SDA-2ATL
  5. #35
    Join Date
    May 2009
    Location
    Plano, TX
    Posts
    249
    Default
    +1
    B&O TX2 Turntable
  6. #36
    Join Date
    Jun 2012
    Location
    Pearland Texas 77584
    Posts
    1,843
    Default
    Or replace the poly with a 1 ohm that should do it. You youngsters
    About the only thing I know of to tame the SL2000 is to disconnect it.
  7. #37
    Join Date
    Jul 2013
    Location
    Lancaster,Pa.
    Posts
    13
    Default
    Thanks all, I found the Solens and the Mills at Parts Express. I don't know exactly when I will get the xo mod done , but I will post my findings here. I will do one first and AB the speakers.
  8. #38
    Join Date
    Jul 2013
    Location
    Lancaster,Pa.
    Posts
    13
    Default
    If anyone is still active on this post just a note I am ordering the new xover parts for the Monitor 5's. I guess I should open a new thread to report on anydifferance I hear, correct?
  9. #39
    Join Date
    Jul 2013
    Location
    Lancaster,Pa.
    Posts
    13
    Default
    Oops....I forgot to mention, called Polk and they are out of rdo 194 tweeters until october. I mentioned that everyone on this thread thought the new tweeters were not as bright as the originals. He said flatly the Opposite !! What a hobby! It is all subjective to a point.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Need Help SL 2500 to replace SL 2000 IN SDA CRS+
    By walkerhollis in forum Vintage Speakers
    Last Post: 12-12-2010, 10:11 PM
  2. monitor 5b upgrade tweeter to sl 2500 or sl3000?
    By zarrdoss in forum Vintage Speakers
    Last Post: 03-04-2009, 09:22 PM
  3. New to Systems, 2000 silverado 2500, under 600$
    By brizant7294 in forum Car Audio & Electronics
    Last Post: 11-09-2006, 01:33 AM
  4. Ultimate Speakers for $2000-$2500 Range
    By Lsi9 in forum Speakers
    Last Post: 03-25-2006, 08:35 PM
  5. replacing SL3000 with SL 2500 or SL 2000
    By duke1010 in forum Vintage Speakers
    Last Post: 06-25-2005, 06:01 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
