Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 36 of 36
  1. #31
    Member Sales Rating: (0)
    Join Date
    Aug 2013
    Posts
    9
    Default
    Do you think I'll kill my system using this audio cable? I know it's cheap, don't know if is reliable...
    http://www.123inkcartridges.ca/acces...specifications
    If not, do you know any other cable to use?
  2. #32
    Member Sales Rating: (1)
    Join Date
    Jul 2001
    Location
    chicago
    Posts
    17,110
    Default
    Reliable how so ? Will it do the job ? Yeah....will it sound good doing it ? Debatable. Looks like the same generic cabe you can get on a roll at your local Home depot, Walmart.
    My question is, after spending x amount on speakers and electronics, why cheap out on the last step, cables ? Not saying spend 500 bucks either, but cost effective better cables can be had from the likes of Bluejeans, Douglas connections, Signal cable, etc.
  3. #33
    Join Date
    Jan 2004
    Location
    Quincy, MA
    Posts
    11,748
    Default
    That will do or so will this. It all depends on how much you want to spend.
    http://www.monoprice.com/Product?c_i...seq=1&format=2
    The same from www.bluejeanscable.com Belden 5000UE Speaker Cable, 100 foot, unterminated $52.00.
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Rotel RCD-1072 CDP, Onkyo TA2600 Tape Deck, Pioneer Elite 47-A DVD, Sony 32" XBR TV, Polk RTA-8T Main Speakers, Boston VR-920 Center Channel, Boston PV-600 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  4. #34
    Join Date
    Aug 2013
    Posts
    9
    Default
    I just found this monster as well:
    http://www.futureshop.ca/en-CA/produ...bb5029f2f9en02
    2-300 $ is a fair price for the wires, but if I need to spend more, so be it :)
  5. #35
    Join Date
    Jul 2001
    Location
    chicago
    Posts
    17,110
    Default
    Monster is fairly over priced for the quality you'll get as compared to others. Look up Douglas connections, good quality, pretty cheap, and most importantly......sound good.
  6. #36
    Join Date
    Jun 2012
    Location
    Pearland Texas 77584
    Posts
    2,006
    Default
    I like this wire on a budget it's 12 ga black/red so it's easy to keep phase the white jacket protects it and looks better than plain zip wire.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 23
    Last Post: 06-09-2012, 11:18 AM
  2. need help choosing receiver
    By jhudgens in forum Electronics
    Last Post: 03-18-2012, 07:57 PM
  3. Need Help Projector upgrade 1500 budget
    By EndersShadow in forum Electronics
    Last Post: 10-03-2011, 07:04 PM
  4. Need Help AV receiver upgrade with $1500 budget
    By DMara in forum Electronics
    Last Post: 12-26-2009, 09:05 PM
  5. Receiver or pre/pro for $1050 - $1500?
    By bigsexy1 in forum Electronics
    Last Post: 10-07-2003, 08:11 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
