Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 51 of 51
  1. #31
    Member Sales Rating: (0)
    Join Date
    Sep 2013
    Posts
    100
    Default
    Quote Originally Posted by BlueFox View Post
    Of course they do. Nothing personal, but if you are asking that then you have a lot of learning to do. As others say, "Get your read on", and start researching.
    And, cables (power, speaker, interconnects) also have a huge impact on sound quality, so it isn't only the source that matters.
    Blue Fox, I would like to think we all have much to learn, so maybe you can help by shedding some light on this issue for me if you don't mind.
    What would one significant difference if I used a CD input source over a tape input source? Thanks!
  2. #32
    Audiophile
    Member Sales Rating: (30)
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    The inputs are exactly the same on the preamp/receiver, but tape is significantly more noisy than CD, and not at all my preferred material.
  3. #33
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    6,139
    Default
    Quote Originally Posted by Summerwind2 View Post
    Off the top of my head.
    1. Tape hiss.
    2. A CD contains digital files that are converted to analog via the DAC in the CD player. The quality of the DAC determines the sound quality of the file.
    3. A tape is an analog recording that is only as good as the tape heads, recording speed, tape format, and the associated circuitry.
  4. #34
    Join Date
    Sep 2013
    Posts
    100
    Default
    Just for clarity; I was referring to the actual RCA inputs and not the actual device.
    So if I plug my ipod into my CD input or my Tape input would there be any significant SNR issues????
  5. #35
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    I too was thinking about switching back to 8ohms and carpet spikes
    They're on the short wall and 3' off the side walls.
    Ok, I'm not sure how you are measuring, but they can't be 10 feet apart on a 16 foot wall and still be 3 feet from each side wall. Measure from the inside edge of each speaker and set them up at 6 feet apart.
    Question; Do input sources have any impact on sound quality? CD vs Tape vs DVD?
    You mentioned in your other thread about having the best iPod library. Is that what you're using as a source right now?
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  6. #36
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    6,139
    Default
    What kind of a iPod dock are you using? Where did you get the files on your iPod? What type of encoding format is used for these files.
    Plugging your iPod into either of those inputs is a moot point, since they will both suck. I guess you are interested in which one sucks the least. Try it and find out.
    The reason why it sucks is because doing that means you are using the $1.99 DAC chip in the iPod. Plus, I suspect your files use lossy encoding which increases the suckiness of the music.
    As a starting point, read this.
    http://www.theabsolutesound.com/arti...urce=email-161
  7. #37
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,287
    Default
    Ah, you answered my question while I was typing. You need a better source.
  8. #38
    Join Date
    Sep 2013
    Posts
    100
    Default
    Quote Originally Posted by F1nut View Post
    They're 7 feet apart from inside edge and not 10 as I originally stated.
    Yes, I'm using my ipod into my CD input using song I downloaded from itunes.
    Thanks for the insight.
  9. #39
    Member Sales Rating: (3)
    Join Date
    Jun 2009
    Posts
    2,187
    Default
    Summer, all this time I thought you were using a CD or a Blu Ray player to test these speakers.
  10. #40
    Join Date
    Feb 2011
    Posts
    795
    Default
    For two channel I prefer a simple system like I now have with a preamp and a power amp. I had an AVR before I had the separates and it was too complicated just for 2 channel listening. There were so many settings that even when I was listening in "Pure Direct" mode I was always wondering if I was still hearing a signal modified by the AVR or not. Don't get me wrong. I'm not a purist and I'm not above tweaking the bass or treble knobs every now and then. On my Pioneer AVR you had to make sure the front speakers were set to LARGE and it was set for NO subwoofer. Otherwise the bass would be weak.
    SDA 2BTL Sonicaps Mills resistors RDO-198s New gaskets H-nuts Erse inductors Crossover upgrades by westmassguy
    Adcom GTP-450 preamp
    Adcom GFA-555 amp Upgrades & speaker protection added by OldmanSRS
    Pioneer DV-610AV DVD/CD player
    SDA CRS+ Hidden away in the closet
  11. #41
    Join Date
    Sep 2013
    Posts
    100
    Default
    Quote Originally Posted by Polkie2009 View Post
    And using CD too.
    Thanks for all the feedback but I have yet to get an answer to my original ask; do RCA inputs (not the devices) CD vs DVD vs SAT/LD or Video have any significant SNR issues??? or as someone said which one sucks the least
    Thanks again.
  12. #42
    Join Date
    Jun 2011
    Posts
    688
    Default
    F1nut is right..first off the speakers are too far apart. No matter how your measuring them.
    I have SDA 1C's set up in a little over 13' wide by 28' long room. Plus i sit over 14' back.
    They are set at 8' apart if you measure from the outboard side of both speakers. They are also 1' off the back wall. Now that seems to work best in MY room....but if you move them farther apart..things don't work right. If you have a really heavy rug..you need spikes.
    Well the fact your using an AVR..not so great but again..put it back to 8ohms.
    The fact your trying to run a Ipod..with downloaded stuff from itunes. Well..that i have no answers for. You need to talk to the digital people.
    I have a separate Pre amp, amp and tube CD player..I have no problems at all.
  13. #43
    Join Date
    Sep 2013
    Posts
    100
    Default
    [QUOTE=BlueFox;1962658]What kind of a iPod dock are you using? Where did you get the files on your iPod? What type of encoding format is used for these files.
    http://www.theabsolutesound.com/arti...urce=email-161[/QUOTE
    Bluefox I got my read-on:
    http://stereos.about.com/od/accessor...-Bda-1-Dac.htm
    Thanks! Learn something new everyday.
  14. #44
    Join Date
    Aug 2010
    Location
    central Jersey,08859
    Posts
    1,707
    Default Adcom w/Sda 2bs
    My spred from outer corners of my 2bs is 7' and 1 foot off the rear wall. No side walls to deal with and my seating pos is at 9 ' center of my couch almost an equilateral triangle.Straight on,no toe in and I get great stereo seperation.I also share most of my sources w/ the exception of my tt.The Adcom 555, Sda 2bs and Yamaha rx-v665 works as a combo. Where the avr is lacking if just an avr are those sound fields that do nothing but add echo and or delay and it sounds terrible and is never used.Even in pure direct 2-channel it had nothing going for it.
  15. #45
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    6,139
    Default
    Good job.
    I had a Wadia 170 (still use it at work), and later upgraded to a Wadia 171, which sounds even better. I also have both the Bryston BDA1 and BDA2 DACs. In order for the iPod to be an excellent music source the files need to be copied from a CD as either uncompressed, or use Apple lossless compression. Any file bought from iTunes is a lossy file (musical data is removed to create a smaller file size), so you will need to build up your muscial library from scratch. However, I suspect that even the iTunes files will sound better through the Bryston DAC than the internal DAC in the iPod.
    I replaced my iPod wth the Bryston BDP1 digital file player, which is much more versatile than the iPod. It sounds a bit better also, but the iPod is still a great source with the Wadia and a good DAC.
  16. #46
    Join Date
    Jul 2013
    Location
    Evergreen, CO
    Posts
    1,027
    Default
    Quote Originally Posted by leftwinger57 View Post
    ...Yamaha rx-v665 works as a combo. Where the avr is lacking if just an avr are those sound fields that do nothing but add echo and or delay and it sounds terrible and is never used.Even in pure direct 2-channel it had nothing going for it.
    Same for the 667. Garbage for music, okay for HT and gaming.
    |Fronts - Peerless RTA-12B | Center(s) - Peerless Monitor 5 | Rears - Peerless Monitor 4 |
    |AVR - Yamaha Aventage RX-A1020 |
    |TV - Philips 46" Smart LED | Gaming - Xbox One - Xbox 360 | Headphones - Philips Fidelio X1 |
  17. #47
    Join Date
    Jan 2010
    Location
    At the golf course eating mushrooms!
    Posts
    1,267
    Default
    Thanks again.
    To be blunt IT DOESN'T MATTER there all line level inputs and should sound the same.
    "It currently doesn't have a remote because I'm pretty sure my ex threw it out at some point 'cause she's a whore.!"
    "Peace, Love and ICBM's"
    "50% Why... That's almost half."
    "I know, I'm sick and need help."
    www.gimpod.com
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
  18. #48
    Member Sales Rating: (14)
    Join Date
    Mar 2005
    Posts
    4,327
    Default
    Just don't use a phono input.
  19. #49
    Join Date
    May 2006
    Location
    The Seasonally Frozen Wastelands
    Posts
    1,184
    Default
    Quote Originally Posted by gimpod View Post
    Thank you, gimpod. This is one of those times where I had to read the answer in order to understand the question. It happens more often as I get older...or more senile...or more medicated.
  20. #50
    Join Date
    Sep 2013
    Posts
    100
    Default
    Update: I was finally able to access the GUI room set-up on my AVR with all effects off and settings flat.
    And for now Im using my Blueray player as a CD source. The SDA's sounds fantastic @ 25% vol.
    Now I can start tweaking.
    Thanks for all advice and support its much appreciated
  21. #51
    Join Date
    Mar 2005
    Posts
    4,327
    Default
    Welcome to the rabbit hole.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Need Help Less Power Hungry Amp
    By OOsemka in forum Electronics
    Last Post: 04-05-2012, 09:11 PM
  2. Need Help LSi 15's - How power hungry ?
    By Leon S. in forum Speakers
    Last Post: 05-12-2009, 11:34 PM
  3. LSi are so power hungry!
    By organ in forum 2 Channel Audio
    Last Post: 04-11-2006, 12:14 PM
  4. rti12 power hungry
    By skoopman in forum Electronics
    Last Post: 12-27-2004, 07:10 PM
  5. Power Hungry?
    By bigworm460 in forum Speakers
    Last Post: 08-04-2003, 08:57 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
