Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
Closed Thread
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 121 to 148 of 148
Thread: whats next?
  1. #121
    Member Sales Rating: (6)
    Join Date
    Sep 2009
    Location
    Alexandria, VA
    Posts
    3,473
    Default
    Quote Originally Posted by Jestered View Post
    Thanks falconcry72. I appreciate it!
    No problem. The thing about amps (and preamps, DACs, etc.) is that they could bench/spec the exact same, yet sound different. So unless you want to audition every amp out there in your own system, it is very helpful to piggyback on the experience of people who have actually spent time listening critically to multiple designs and done A/B comparisons in their own systems.
    Keep in mind, this is a forum for audiophiles, not electrical engineers. What we may lack in the ability to describe the "how" (why does an amp sound a certain way), we make up for in spades with the ability to describe the "what" (what does an amp actually sound like, compared to other designs).
    I can't tell you exactly why my amps sound different from each other, but I can give you real-world experience from comparing and critically listening to literally dozens of different designs over just the last couple years alone.
    There is no theoretical substitute for actual experience via trial and error.
    2-Channel:
    Source 1: PC
    Source 2: Rega Apollo CDP
    USB > SPDIF Converter: Stello U3
    DAC: Audio GD NFB-7
    Preamp: Audio Research LS-15
    Power Amp: BAT VK-500
    Speakers: Magnepan 3.7's
    HT:
    Source 1: HTPC
    Source 2: Oppo 103
    Pre/Pro: Marantz av8003
    Power Amp: Rotel RMB-1095
    Fronts: LSiM-705's
    Center: LSiM-704c
    Surrounds: LSiM-702's
    Subs: Dual SVS PC12-NSD's
  2. #122
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    Quote Originally Posted by Bluefox
    Do you mean 'get' in the sense that Ohm's Law, which uses basic algebra, applies to DC circuits. On the other hand, AC circuits require calculus to solve. Since amps are AC circuits, the simple DC circuit Ohm's Law doesn't apply.
    He got that from the same severely misinformed person that thinks all SS amps sound the same.
    Amazon? Certainly not the first, second, third, fourth or fifth place one would think to look for a quality amp. Audiogon is usually the default choice.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  3. #123
    Member Sales Rating: (12)
    Join Date
    Feb 2005
    Location
    Plainfield, Illinois
    Posts
    5,384
    Default
    Wattage specs would be great if all manufacturers used the same standard to measure them, or at least state what standard was used to get them. THD is another spec that could be expounded upon. You get a fixed amount but don't see when and where the distortion occurred. A distortion analyzer will show what types of distortion, the amounts of and where it occured throughout the audio frequency range. A real visual eye opener you can relate to what you heard. Maybe too much info for some folks.
    Another visual way is to put a scope on your speaker terminals. When music is playing, it looks like a crack addict playing with an etch a sketch. You can adjust settings to get a smooth sine wave and increase power to see if you lop their heads off (clipping). The other way, as stated, is connect a better amp and play at same low and max dB you would listen to. You start hearing more details or everthing the artist intended on the recording, you are golden. You don't know what you are missing until you hear the same material on something better. To me that is what an audiophile goes for. Others are content without that. And I don't want to hear how detail is always strident and painful cause it is not always the case.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's
    Krell KRC-HR Class A Pre w/ Reference Phono
    Krell Class A KSA-250
    Harmonic Technology Pro 9+
    Squeezebox Touch / Welborne Labs PS / I2S Out Mod
    Denon 3910 w/I2S/DSD Out
    Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC
    Sennheiser HD650
    Heavy Plinth Lenco L75 Idler Drive
    AA MG-1 Linear Air Bearing Arm
    AT33PTG/II & Denon 103R
    Shunyata Hydra (Original)
    NHT B-12d subs
    GIK Acoustic Treatments
    CP Showcase
  4. #124
    Member Sales Rating: (4)
    Join Date
    Jan 2008
    Location
    Salem, Oregon (Polk county!)
    Posts
    4,348
    Default
    Jestered is using a classic example of Hegelian dialectic. You present a problem to which you already know the solution, but cause those around you (the Polk Forum in this case) to endlessly present the solution (the truth) yet he acts as if he doesn't realise what that solution is and thus causing the Polk Forum members to endlessly keep presenting the solution to which Jestered already knows the answer (whether factual or not). The person (or people) (Jestered in this case) then continues his steering towards anarchy by "never realising" the answer to the presented problem and the cycle continues. (That is, the solution the problem presenter (Jestered) is seeking, that is anarchy and chaos).
    Please go "play" somewhere else Jestered.
  5. #125
    Member Sales Rating: (0)
    Join Date
    Aug 2013
    Posts
    49
    Default
    Quote Originally Posted by headrott View Post
    Either you're trying to sound smart, or you don't really "get" Hegel's philosophy. Hegel's "philosophy" goes much deeper than the simple explanation you've described. You can twist my question how ever you'd like, but the simple fact is that I asked a question. Nothing more and nothing less.
    Samsung 65" ES8000 LED
    Pioneer Elite VSX-53
    Polk RTiA5's - Front Towers
    Polk CSiA6 - Center Channel
    Polk RT15i's - Side Surrounds
    Polk FXiA4's - Rear Surrounds
    SVS PB-1000 - Subwoofer
    URC MX5000 - Remote
  6. #126
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    BOZO listed.
  7. #127
    Join Date
    Aug 2013
    Posts
    49
    Default
    Quote Originally Posted by F1nut View Post
    1nut- Why do you keep chiming in?
    URC MX5000 - Remote
  8. #128
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    This message is hidden because Jestered is on your BOZO list.
    Ah, much better!
  9. #129
    Join Date
    Aug 2013
    Posts
    49
    Default
    BOZO listed.
    At least you came up with a new name. But, again, why do you keep responding?
    URC MX5000 - Remote
  10. #130
    Join Date
    Aug 2013
    Posts
    49
    Default
    Ah, much better!
    Thank you!
    URC MX5000 - Remote
  11. #131
    Join Date
    Jan 2008
    Location
    Posts
    4,348
    Default
    Excellent! "We" simply answered the question multiple times. Nothing more and nothing less. Please move along before you wind up on others' BOZO lists.
  12. #132
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    Anyone else think mindless and jestered are the same person? I mean, the odds of 2 people being like that are astronomical.
  13. #133
    Join Date
    Jan 2008
    Location
    Posts
    4,348
    Default
    It's funny Jesse, I originally almost posted a question asking Jestered what other screen name(s) he has used......... I decided on my response above however.
  14. #134
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    Just proves that great minds think alike :)
  15. #135
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    6,135
    Default
    I think they are different. Jester doesn't stick question marks in the middle of his sentences.
  16. #136
    Join Date
    Aug 2013
    Location
    Abbotsford BC
    Posts
    1,967
    Default
    Um the similarities are well, uncanny but we could be wrong...
    Living Room Evolved
    Onkyo TX-NR717
    Parasound HCA-1200II
    Polk Audio RTi A7 Black Front
    Polk Audio RTi A3 Black Rear
    Polk Audio CSiA6 Center
    Transparent Audio Music Wave Biwire cables > Mains
    Canare 4S11 >Center
    Audioquest Evergreens on most of the analog connections
    Tannoy TS2.12 Sub
    Marantz CD6004
    Pro-Ject Debut Carbon Piano Black TT
    Parasound Zphono Phono Preamp
    Apple Mac Mini
    Apple TV 3rd Gen
    Sony PS3 160Gb/Microsoft XBox 360
    Insignia 55 inch 120Hz TV
  17. #137
    Join Date
    Aug 2013
    Posts
    49
    Default
    If it means you will stop responding, then PLEASE put me on your list! I'm begging you...
    URC MX5000 - Remote
  18. #138
    Join Date
    Jan 2008
    Location
    Posts
    4,348
    Default
    Why do you insist on taunting others?
  19. #139
    Join Date
    Aug 2013
    Posts
    49
    Default
    Ha! Now that's funny! Who exacatly am I taunting? I've been attacked over and over again in this thread, but yet I'm taunting? You sir are delusional.
    URC MX5000 - Remote
  20. #140
    Join Date
    May 2010
    Location
    Galveston
    Posts
    3,212
    Default
    All I know I have plenty of gear to swap around. That being said I have a 100 watt AVR that distorts a pair of speakers before one of my higher end 60 watt amps measured at the same SPL...proof is in the pudding
    Home Theater:Samsung8000-55LED,Pioneer SC35, Pioneer DV-79AVi, Sunfire TGA7201, LSi25, LCi RTSc, LC80i
    2chnl system:Melody 101 tube pre, Pass XA30.5 amp, Usher MD2 speakers, W4S Dac, MG Audio Planus2 speaker cables
    Office rig: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
  21. #141
    Join Date
    Oct 2004
    Location
    North Texas
    Posts
    6,120
    Default
    Quote Originally Posted by txcoastal1 View Post
    pudding
    It's been years since I've had that. Sounds damn good now thanks to you.
    Usher CP-6311, Shuguang S200MK, Shuguang S845MK, Pioneer BDP-51fd, Essence Audio HDACC, Douglas IC's, Douglas Alpha bi-wire SC's, Pangea/Douglas PC's, Epson 8100
  22. #142
    Join Date
    May 2010
    Location
    Galveston
    Posts
    3,212
    Default
    Quote Originally Posted by DSkip View Post
    Maybe the best thing to eat sick boy....jello and, ice cream too
  23. #143
    Join Date
    Oct 2010
    Location
    It's not home, the N.W. will do for now
    Posts
    1,486
    Default
    What's up my two TEXAS compadres? All I can say is......Yeah I'm gonna miss her...ahh looky there...I've got a bite.......
    Draggn' knee is exhilarating, 150mph wheel standers are pretty cool too
    Home Theater-7.2
    Display-SamsungPN64D8000 | Receiver-Onkyo TX-NR807 | Source-OPPOBDP-103 | Amplifiers-Emotiva; XPA-2 x2, XPA-3 | Speakers: PolkAudio; mains-RTiA9, rears-RTiA9, center-CSiA6, surrounds-FXiA6 | Sub-Epik Empire x 2 | Interconnects-Emotiva
    Cans
    Grado RS2i
    2 Ch Rig
    First purchase will be; a pair of ? but I'd love a pair of SDA SRS
  24. #144
    Join Date
    May 2010
    Location
    Galveston
    Posts
    3,212
    Default
    ....reel her in
    Nada mucho, 2 TX gatherings coming up get your butt down here...Last weekend in Jan.....-1st weekend in May
    Cheers
  25. #145
    Join Date
    Oct 2010
    Location
    Posts
    1,486
    Default
    Man, if only I could!!! Had a transfer come through here last month to get my self back to S.A. I had to decline it, man that was a tough thing to do......I want to get back home so bad. But you know, one of these days, I'll be throwing Whataburgers down the hatch once again.
    Home Theater-7.2
    Cans
    Grado RS2i
    2 Ch Rig
  26. #146
    Join Date
    Jan 2008
    Location
    Posts
    4,348
    Default
    I will let others decide for themselves on both counts.
    In giving my opinion however, you are using projection on both counts.
    Where are we going with this anyway?
  27. #147
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,271
    Default
    Greg, everyone here knows the vile.....small, small dude is nothing but a troll and not a very good one at that.
  28. #148
    Join Date
    Jan 2008
    Location
    Posts
    4,348
    Default
    Come on now Jesse, you're swayin' the masses. Ok, you are right it is that obvious.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Whats up All?
    By VR3 in forum The Clubhouse
    Last Post: 01-14-2009, 12:21 AM
  2. DHL - Whats it about?
    Last Post: 07-27-2004, 06:46 PM
  3. Whats up with this?
    By ninerbj in forum Troubleshooting
    Last Post: 03-26-2004, 04:55 PM
  4. Whats going on here with HSU?
    By DanielCSCS in forum Speakers
    Last Post: 11-26-2003, 04:16 PM
  5. whats the best sub?
    By Nathan32387 in forum Car Subwoofer Talk
    Last Post: 04-16-2003, 10:55 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
