Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 15 of 15
Thread: SVS SB13 ultra
  1. #1
    Member Sales Rating: (0)
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default SVS SB13 ultra
    After almost a month of waiting and several weather delays in shipping my svs sb13 ultra finally arrived. First off this thing is damn impressive! But I have a few questions and was hoping other svs owners could chime in. I performed auto calibration though my harman kardon avr 7550hd (also called Ez Set/eq). And further tweaked the settings in my avr as per the svs manual.... which are:
    - sub trim to -3db
    - sub woofer level set to 0db
    The volume level in the integrated function controller on the sub itself has to be set fairly high around -2db 0r -3db (on a scale of -100 to 0). The sub sounds GREAT, and blends really well with my speakers. Is this volume setting too high? What do others have theirs set to? I know these settings will vary for room size and equipment variations etc. Any suggestions and help is always appreciated, thank you.
  2. #2
    Member Sales Rating: (1)
    Join Date
    Oct 2008
    Location
    Richton Park,IL.
    Posts
    5,050
    Default
    Welcome to the Ultra-13 Club...........Congrats!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  3. #3
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default
    Quote Originally Posted by danz1906 View Post
    Thank you! The ultra and I have only been together since Thursday, and I already want another one :o
  4. #4
    Join Date
    Dec 2010
    Location
    Sunny SoCal
    Posts
    830
    Default
    Pics man pics! You've spent enough time to take some pictures :P.
    2Ch Tube Audio Convert
  5. #5
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default
    alright here they are! forgive the quality as I only used an I phone. I understand the position of the sub isn't ideal but I am moving into a house feb 27! woo hooo!
  6. #6
    Join Date
    Dec 2010
    Location
    Sunny SoCal
    Posts
    830
    Default
    Looks awesome! Congrats man. That is one slick looking sub! Just make sure you take time to set it up properly and it'll keep delivering!
  7. #7
    Join Date
    Sep 2011
    Posts
    125
    Default
    that sub compliments the lsi's color. very beautiful.
  8. #8
    Join Date
    Mar 2014
    Posts
    10
    Default
    compliment's
  9. #9
    Join Date
    Oct 2008
    Location
    Richton Park,IL.
    Posts
    5,050
    Default
    Sweet!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  10. #10
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default
    Thanks guys! Moved into the new house and have a second one on the way! Hoping to see it before the weekend.
  11. #11
    Member Sales Rating: (3)
    Join Date
    Mar 2008
    Location
    rochester,ny
    Posts
    922
    Default
    Have you tried playing with rew yet
  12. #12
    Member Sales Rating: (11)
    Join Date
    Jan 2006
    Location
    Toronto, ON, Canada
    Posts
    1,952
    Default
    Quote Originally Posted by mikeyb View Post
    - sub trim to -3db
    Are you saying that you have to increase the gain/volume of the built-in amplifier volume control all the way too 100% to blend it in?? I'd say then that either your receiver subwoofer signal level is too low, or your room needs treatment, or the most basic - your sub position in the room is incorrect.
  13. #13
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default
    Quote Originally Posted by ViperZ View Post
    I have managed to figure this problem out. The auto setup feature for my Harman Kardon receiver just plain blows. I tried multiple
    subwoofer locations, and re-ran the auto setup dozens of times. I ended up purchasing an spl meter, re-setting the receiver to factory defaults and starting from scratch. I did talk to the guys at svs and they told me it is not unusual to run the gain on the subwoofer as high as -5. I have trim and sub volume in my avr set to 0 and gain the the svs to -10. I like a bit of base and ran the svs a little hotter than the other channels. I also have moved into a house with a dedicated theater room, so it took quite a bit of
    positioning and experimentation, I have it almost perfect now :)
  14. #14
    Join Date
    Oct 2009
    Location
    Calgary AB, Canada
    Posts
    138
    Default
    Quote Originally Posted by sandworms View Post
    I haven't tried it, but have been thinking about giving it a go. I have been pretty interested in a Velodyne SMS-1 after my second ultra comes in. any recommendations?
  15. #15
    Join Date
    Jan 2006
    Location
    Toronto, ON, Canada
    Posts
    1,952
    Default
    I have SMS-1 and would highly recommend it, with one caveat - it only does a total room response, it will not calibrate subs individually. Only Audyssey MultiEQ XT32 equipped controllers will do so. If you can score SVS AS-EQ1, it will calibrate your subs individually, then do the total room response. Personally, I don't see that box being worth over $600 used. My SMS-1 does a great job doing a total room response. I had to find proper sub positions first, then ran SMS-1. You can also try Anti-mode 8033, apparently it's very similar to SMS-1.
    And of course, as you already found out, no receiver will do a proper sub response equalization, unless it's XT32 equipped.
    Panasonic PT-AE4000U projector for movies
    EluneVision 92" Cinema Gray fixed screen
    Onkyo TX-SR805 Pre/Pro
    Rotel RMB-1075 Amp
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears
    DUAL NHT SubTwo subwoofers
    Velodyne SMS-1
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Harmony 890 RF remote
    Panasonic TC-P50G20 TV + PS3 in the living room
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Interest Check: SVS SB13 Ultra (Pair)
    By MikeC78 in forum For Sale (FS) Classifieds
    Last Post: 07-06-2013, 03:12 PM
  2. PB12 Ultra/2 To Replace My PC Ultra...?
    By wingnut4772 in forum Speakers
    Last Post: 12-12-2005, 02:03 PM
  3. Svs Cs-ultra
    By gwh in forum Flea Market
    Last Post: 12-12-2004, 05:21 PM
  4. Amp for SVS CS Ultra?
    By fireshoes in forum Subwoofer Hookup & Bass Management
    Last Post: 10-22-2004, 12:05 AM
  5. SVS CS Ultra
    By DarqueKnight in forum The Clubhouse
    Last Post: 01-16-2002, 02:27 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
