Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 40 of 40
Thread: Rta 15
  1. #31
    Member Sales Rating: (0)
    Join Date
    Apr 2014
    Posts
    24
    Default
    So is a common ground amp still needed? Is 80 watts sufficient?
  2. #32
    Join Date
    Dec 2011
    Location
    Feeding Hills, MA
    Posts
    2,295
    Default
    Common ground is needed, and the 80 watts will make noise, but not shake the house. The amp supposedly is rated for use with 4-16 ohm speakers, but it's really not going to power them properly, especially if you like your music loud, and like a lot of bass.
    Home Theater/2 Channel:
    Front: SDA-2ATL http://www.polkaudio.com/forums/show...ished...Almost
    Center: Custom http://www.polkaudio.com/forums/show...hannel-Project
    Surrounds & Rears: Custom http://www.polkaudio.com/forums/show...rround-Project
    Sonicaps, Mills, RDO-194s-198s, Dynamat, H-Nuts, BH5
    Pioneer Elite VSX-72TXV, Carver PM-350, SVS PB2-Plus Subwoofer
    www.dhsspeakerservice.com
  3. #33
    Join Date
    Oct 2013
    Location
    Westchester county, NY
    Posts
    299
    Default
    Quote Originally Posted by Mystery View Post
    I'd not drive 3 hours
    remember you are on a site where everyone here has driven at least that long for something we weren't quite sure we wanted...its called crazy...! its a good crazy, but still...
    NAD 2100 - NAD 1020 - Project Debut Carbon with speed box S
    Frankin Polk Monitor 10b-2A - Blue Jeans IC's - (living room)
    Marantz 1060 - Infinity RSe - I-job (garage/mancave)
  4. #34
    Join Date
    Apr 2014
    Posts
    24
    Default
    Whew! I'm glad I only drove 2 hours! Any suggestions on what amp to use?
  5. #35
    Join Date
    Dec 2011
    Location
    Feeding Hills, MA
    Posts
    2,295
    Default
    Adcom GFA 555/555 II are very popular
  6. #36
    Join Date
    Apr 2014
    Posts
    24
    Default
    Thanks for all of the info and advice! Hopefully I can find something budget friendly, if there is such a thing.....
  7. #37
    Join Date
    Aug 2010
    Location
    St Louis Area
    Posts
    1,044
    Default
    Adcom 535 and 545 would also work very well. Not as much as power as the 555 but are much cheaper. The 535's usually go for $100-$150. Should be plenty of them on Ebay.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amp: Kenwood KM-894 x 2(fronts and surrounds)
    Fronts: Polk SDA2
    Center: Polk Monitor 7C
    Surrounds: Polk Monitor 7C
    Subwoofer: SVS PB10-ISD
  8. #38
    Join Date
    Apr 2014
    Posts
    24
    Default
    Will a Yamaha MX630 or MX 830 suffice? I seen a couple of them on ebay 1 for 150 and the other for 250.
  9. #39
    Join Date
    Jan 2012
    Location
    Denver
    Posts
    1,873
    Default
    Adcom's don't have speaker protection relay and many don't use them for that reason but mine's are working so far without any blown speakers.
    Boston A400,VR950, DefTech BP10,, Klipsch Forte,KSP-400,KSF-C5,RF3,RC3.
    JBL L20t,L80t3, EPI 20+,T/E 280, Polk 4,4.5,5A,7C, KEF Coda III, Yamaha NS-690, Genesis 3+.
    SUB:Deftech PF15TL+, DCM TB1010, Velodyne VA08BVX10. Pre: HK AP2500. Amps: BB175, Adcom GFA-535,555II, Rotel RB-990BX.
  10. #40
    Join Date
    Jun 2014
    Posts
    2
    Default
    which is a better speaker SDA 1A's or RTA 15's i have a chance of getting one or the other or both sets, and what should i pay of each set
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
