Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 40 of 40
  1. #31
    Member Sales Rating: (58)
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,306
    Default
    Holy crap, you're screwed.
  2. #32
    Member Sales Rating: (1)
    Join Date
    Oct 2004
    Location
    Boca Raton, FL
    Posts
    155
    Default
    OK, I've tried several connectors for the Interconnect Cable (IC). I first tried crimpable connections, but the pins are smaller than 22 gauge and they wouldn't stay. While looking for a connector, I found small gauge alligator clips that I thought would work for a temporary connection just so I could hear the IC connected difference. The clips have rubber boots, so they won't swing and hit each other. They actually hold quite well.
    I was pleasantly surprised with the IC connected sound difference. Without the IC cable, the left speaker was dominant. I first thought that the right speaker had a tweeter that wasn't as strong as the other right and both lefts. However, I'm guessing that it is powered by the IC cable, because it now sounds like the other right and both lefts.
    The sweet spot is great. I recommend anyone running their SDAs without the IC to hook it up.
    SDA 2s; HSU STF-2; Yamaha RX-V1
    SDA-CRSs; Polk PSW-303; Rotel RB-960BX; Rotel RSP-960AX;
    LSi 7s; Infinity PS8; Rotel RB-980BX; Rotel RSP-980
    Mirage Nanosat 5.1; Yamaha RX-V2300
    Monitor 5s, 5 jrs, & 4s
  3. #33
    Member Sales Rating: (3)
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,364
    Default Re: pin-pin IC cable
    Originally posted by Tide
    My speakers have two round male pins in a circular plastic receptacle. Here's a picture.
    That looks like either (1) a retrofitted connector that the previous owner installed because he lost or never had the SDA cable or (2) a broken SDA cable connector end that is inserted into a receptacle.
  4. #34
    Member Sales Rating: (0)
    Join Date
    Apr 2004
    Posts
    32
    Default
    I would say , if your having a prob. with picking up a interconnect . Try picking a Carver C-9 sonic holgraghy generator , or a Carver Pre with that feature built in . :)
  5. #35
    Member Sales Rating: (7)
    Join Date
    Jul 2001
    Location
    lookin' for fava beans and a nice chianti
    Posts
    12,608
    Default
    I wouldn't.....SH and SDA aren't comparable, IMO. Well, they are I suppose but SH isn't as good as SDA, one, and two, why have the speakers if you aren't using them properly.
    BDT
  6. #36
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,229
    Default
    Not to mention that some of the drivers and tweeters are not being used without the SDA cable connected.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  7. #37
    Join Date
    Dec 2004
    Location
    MA
    Posts
    57
    Default
    I have both the C-9 (in a box in the basement now) and SDA's and the effect is not the same. I much prefer the SDA sound with the cable. I would find a way to retrofit a cable or build one to fit this application. The SDA effect is much more pinpoint in instrument location.
  8. #38
    Join Date
    Dec 2006
    Posts
    13
    Default
    just joined the forum yesterday. unless I wound up buying Tide's speakers I too have the same pin setup. A Tech at polk tells me that this combination was in no way made by polk. I agree with the weed therory, I know I did alot of crazy stuff back then also.
  9. #39
    Member Sales Rating: (43)
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,931
    Default
    Hi Tide I am in Ft Lauderdale, and I too have the SDA2's With the proper interconnect cable and sockets. I am going to upgrade my setup with a DIY interconnect per DarqueKnight's instructions. If you want you can purchase the stock setup from me, or I can help you properly wire your's
    Ben
  10. #40
    Member Sales Rating: (16)
    Join Date
    May 2005
    Location
    Six 'Burgh (Pittsburgh), PA
    Posts
    6,885
    Default
    We have since discovered other Polk owners with this mutant or mystery cable. Blade/blade connectors and recepticals are still available. Wired corectly, this would be a good solution, and consistent with the original design of this vintage speaker.
    Carl
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
