Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Member Sales Rating: (0)
    Join Date
    Apr 2006
    Posts
    3
    Default Any info on Polk Coax MM6520's?
    The used car I just bought came with Polk Audio MM6520 coax 6.5" speakers, vintage circa 1991. Can anyone fill me in on the specs for these things? My searches on the Polk Car Electronics page and in this forum have come up empty. I'm looking for sensitivity, impedance, RMS power range, and so on.
    The head unit driving these things is a Clarion DB336MP, and when I turn up the volume mid-way, the speakers distort like crazy. Either the head unit is too weak and hits its clipping range before the volume gets high, or the speakers are bolluxed - they look like they should handle this lo-end head unit. I'm still going through the car, so not sure if there is a wiring problem, or a zorched crossover, or if the HU is connected to an amp (maybe miswired) - who knows.
    Thanks!
    Rod
  2. #2
    Join Date
    Nov 2003
    Location
    Dayton, OH
    Posts
    3,459
    Default
    best bet is to call polk customer service, 800-377-7655, they'll fix you up
  3. #3
    Join Date
    Dec 2003
    Location
    Chattanooga, TN
    Posts
    11,820
    Default
    Something is wrong somewhere. As crappy a power source a head unit is, it shouldnt be distorting at mid way volume.
  4. #4
    Join Date
    Apr 2006
    Posts
    3
    Default
    Yeah, I know. There's no low end to speak of, even at louder volumes, and at pretty low volumes (which I guess is a relative term), the Polks are dirtier than you can imagine.
    The Clarion is advertised as about 17Wx4 continuous, while I THINK the Polk MM6520's are rated at something like 100W continuous. Its been a while since I mucked about in audio performance, but if the head unit were the problem, I'd expect to have to turn it WAY up to get some power to the speakers, but run into bad amp clipping as volume went up.
    But right now I get BAD low frequency distortion at what I'd describe as about 1/3 volume... almost like a sub-woofer signal is being fed to the Polks.
    If the Polks are a lot lower than 100W continuous, like say 10W, then maybe the head unit is overdriving them - but the Polks are pretty heavy units, with a big magnet, reasonable quality rubber suspension ring, heavy duty cone frame, so I expect they can handle some heat. Hell, I installed 5x7 coax speakers in the door of my last car and drove them with an Eclipse 3424 head unit direct (no amp), and they were great as far up the volume knob as I could stand it!
    So - I'm left with bad wiring, bad crossovers, or bad amp (if there IS an amp)... or I guess the Polks could have been cooked by the PO.
    Rod
  5. #5
    Join Date
    Apr 2006
    Posts
    3
    Default
    Reached tech support this morning (nice fella!):
    MM6520 (w/ coax tweeter)
    - Range: 35-20kHz, Power: 5-100W RMS, Imped: 4 ohm, Sensitivity: 90db @ 1 m
    - approx recommended input power: 50W RMS per speaker
    - mtg hole: approx 5 5/8", mtg depth: approx 2 5/8"
    Rubber suspension ring holes can be repaired with small dabs of silicon front and back.
    Should be mounted on flat surface to avoid misalignment of moving coil through air space.
    Poor base response could be due to something as simple as phase inversion of one speaker relative to other.
    Tech said he used to have them, and drove them with 50W x 4 amp and loved them.
    So - unless the speakers are physically damaged, it appears they're repairable! Hooray!
  6. #6
    Join Date
    Nov 2003
    Location
    Dayton, OH
    Posts
    3,459
    Default
    w00t! make sure you keep us updated
  7. #7
    Join Date
    Mar 2008
    Location
    Columbus, Ohio area
    Posts
    265
    Default
    Quote Originally Posted by f11 View Post
    I know this is an old thread, but If you're still subscribed, I'd like to know if the mounting on a flat surface thing means rear deck mount only i.e. I've got a flat mount panel in my doors and I have access to a pair of these to replace the factory speakers in a 1996 Toyota Camry Wagon. I'd be mounting them in the door and I'll pass if they are a horizontal flat mount only, but if they can handle vertical flat mount I think I'll get them.
    Thanks for any info you can provide, and by the way, how did they last for you?
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Signal Cable - Club Polk Special
    By RuSsMaN in forum 2 Channel Audio
    Last Post: 04-08-2005, 02:31 PM
  2. Club Polk Karma (Polk Audio Sign)
    By phuz in forum The Clubhouse
    Last Post: 04-05-2005, 07:03 PM
  3. Free Polk Audio Momo Stickers
    By dorokusai in forum Car Audio & Electronics
    Last Post: 10-16-2004, 05:16 PM
  4. Should I mix Polk with other brand Speakers?
    By therockman in forum Basic Hookup/Wiring Questions
    Last Post: 02-07-2004, 03:45 PM
  5. a few sets of Polk speakers DC area
    By warlocks1 in forum Flea Market
    Last Post: 11-15-2003, 08:26 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
