Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Member Sales Rating: (0)
    Join Date
    Mar 2005
    Location
    Peoria, IL
    Posts
    58
    Default Phono stage set up,....... Help
    I am looking for some advice on setting up my phono stage. I recently purchased a Rega P2 turntable with a Dynavector 10x4 cartridge. My phono stage is a Jolida JD 9. I do not understand all settings on the back of the phone stage and I am hesitant to start playing with the 11 switches that I don't understand. The only reference I can see in the Dynavector literature is “recommended load impedance 47K ohms", and “moving coil cartridge” The phono stage has a high and a low output. I run the IC cables out of the "low output" side.
    These are the 11 switches I have to choose from. They are either on or off.
    MM
    MC High
    MC Low
    100 ohm
    300 ohm
    1K ohm
    47K ohm
    47 PF
    100 PF
    150 PF
    220 PF
    Any input on how to set this up.
    Patrick
    Jolida JD1501RC -Telefunken tubes
    Jolida JD9 Phono Stage
    Rega P2- Dynavector 10x4 Mk.II Cartridge
    Music Hall mmf cd-25
    Canton Ergo 900 DC
    Polk PSW404
    Kimber "Timbre" IC's
    Tributaries "SP4BW" - bi-wired
  2. #2
    Member Sales Rating: (1)
    Join Date
    Dec 2003
    Location
    Sooner Country
    Posts
    3,716
    Default
    I would run it MC high, 47kohms, and 100PF turned on for now. If this allows a pretty even volume setting to your CDP, then you are good to go. This cartridge puts out 2-2.5 milllivolts which is high enough to run on the MM side if you would like to try those settings.
  3. #3
    Join Date
    Mar 2005
    Location
    Peoria, IL
    Posts
    58
    Default
    Thanks Dennis. I will try these settings and see.
    Patrick
    Canton Ergo 900 DC
    Polk PSW404
  4. #4
    Member Sales Rating: (17)
    Join Date
    Jul 2001
    Location
    Northern Colorado
    Posts
    11,914
    Default
    I had the JD9 for awhile. Not only do you have those settings you also can choose between the high and low level outputs. Unless I'm mistaken that gives you 8192 possibilities to try. One combination will sound the best with your particular system so it is well worth trying them out. You won't hurt anything. Better get busy! :D
    madmax
    Vinyl, the final frontier...
  5. #5
    Join Date
    Mar 2005
    Location
    Peoria, IL
    Posts
    58
    Default
    Quote Originally Posted by madmax
    madmax
    Thanks. It's a relief to know I won't do dammage. I tried MC High, it seemed a bit to much gain, and almost grainey at louder levels. Can you tell me the differance between MM and MC.
    Thanks.
    Patrick
    Canton Ergo 900 DC
    Polk PSW404
  6. #6
    Join Date
    Jul 2001
    Location
    Northern Colorado
    Posts
    11,914
    Default
    The three settings are just there to cover the wide range of cartridge output levels. Three different gains, thats all.
    Just the basic basics on cartridges...
    Moving Magnet VS Moving Coil cartridges.
    The MM typically has a higher output level and a user replaceable needle. They are often a lot more robust and can take more handling abuse.
    The MC design has a lower output level and need a secondary gain stage which could be either a step up transformer before your phono pre or a pre with a second stage built in. So much gain is needed that noise becomes a critical factor in design. To replace a needle you have to send the cartridge in to get re-tipped. Many manufacturers offer trade in credit instead. The build is fairly delicate and reqires great care in handling. Most report a higher quality output which is why they are willing to deal with the constraints.
    Hope that helps.
    madmax
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. csi 5 set to small? Sounded better at large?
    By james vaughan in forum Speakers
    Last Post: 11-18-2005, 01:41 PM
  2. Replies: 18
    Last Post: 11-04-2005, 08:17 AM
  3. My set up - your thoughts?
    By DesertPilot in forum Speakers
    Last Post: 07-31-2004, 08:35 PM
  4. What should my crossover be set at?
    By C Bennett in forum Subwoofer Hookup & Bass Management
    Last Post: 10-24-2003, 11:02 AM
  5. wow, all this digital sound graet!!! BUT...
    By haroo in forum Basic Hookup/Wiring Questions
    Last Post: 08-14-2002, 05:52 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
