Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 41 of 41
  1. #31
    Member Sales Rating: (12)
    Join Date
    Feb 2005
    Location
    Plainfield, Illinois
    Posts
    5,276
    Default
    Quote Originally Posted by disneyjoe7
    I think you're right I6 Ford engine.
    Wrong. I say it is either a 5.0 or 5.8 V8. The throttle body location with EGR valve gives it away. The EFI I6 had the throttle body mounted towards the middle of the intake plenum. The other tells are the left (drivers side) valve cover and the distributor at the front of the intake. The I6 distributor was at the middle-side of the block. The alternator on an I6 was mounted lower too.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's
    Krell KSL Class A Pre w/ KSL Phono
    Krell Class A KSA-250
    Harmonic Technology Pro 9+
    Squeezebox Touch / Welborne Labs PS / I2S Out Mod
    Denon 3910 w/I2S/DSD Out
    Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC
    Sennheiser HD650
    Heavy Plinth Lenco L75 Idler Drive
    AA MG-1 Linear Air Bearing Arm
    Dynavector 17D3
    Shunyata Hydra (Original)
    NHT B-12d subs
    GIK Acoustic Treatments
    CP Showcase
  2. #32
    Member Sales Rating: (4)
    Join Date
    Dec 2002
    Location
    Denial...it's in Egypt.
    Posts
    12,725
    Default
    Are you looking at the same pictures that I am?
  3. #33
    Join Date
    Feb 2005
    Location
    Posts
    5,276
    Salk SoundScape 8's
    Sennheiser HD650
    Dynavector 17D3
    NHT B-12d subs
    CP Showcase
  4. #34
    Join Date
    Dec 2002
    Location
    Posts
    12,725
    Default
    So you're serious?
    I'm still having a hard time finding that "driver's side valve cover".
    I think you're mistaken on the location of the throttle body in relation to the intake plenum. Also, IIRC, Ford started tilting the I6 to one side for many reasons including clearance issues (it's tall) and it actually made more power leaning over to one side because teh intake and exhaust runners had a more direct flow into and out of the cylinder head. That also meant that the distributor appeared higher, more upright and forward in the engine bay.
  5. #35
    Join Date
    Feb 2005
    Location
    Posts
    5,276
    Default
    LOL Yes, I am serious. Early to mid '90's. Pic's from a Ford service manual. Last group of Ford's with 4.9/5.8 we had were '95's. After that model year, I couldn't tell you.
    EDIT: Add enlarged, cropped pic of what can be seen of left valve cover.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	20576   Click image for larger version
ID:	20577   Click image for larger version
    Salk SoundScape 8's
    Sennheiser HD650
    Dynavector 17D3
    NHT B-12d subs
    CP Showcase
  6. #36
    Member Sales Rating: (6)
    Join Date
    Feb 2002
    Location
    Rockledge, Florida
    Posts
    11,587
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  7. #37
    Join Date
    Feb 2005
    Location
    Posts
    5,276
    Default
    OK, I looked.
    Quote Originally Posted by amulford
    Whats it got in it?
    Quote Originally Posted by Vr3MxStyler2k3
    As in...engine? 302
    A 302 is a 5.0 V8.
    When we were dealing with Ford Motor Company back in the '90's, the warranty rep for Ford told us they considered 1 quart per 1000 miles to be acceptable oil consumption. I have no idea what they say now. So you can cling to your engines shouldn't use oil, you can say that is horrible consumption and think I am screwed up for saying a quart for 1,250 miles on that old Ford. The fact is in the real world many engines use oil and many of the people that drive those cars are not willing to shell out the dough to fix them if proper diagnosis determines the problem to be a ring/bore/piston problem.
    In the early to mid 90's, I believe Ford had some QC problems with their engines, particularly the 4.9L I6 with con rods in '95. Many of the 5.8's we had started consuming a quart of oil per 1400 miles well before 100K. And if you think some fleets don't maintain their vehicles well with scheduled oil changes, that is another misconception you’re going to have to deal with. That is why a drivers pre trip normally specifies check the oil before use and add if necessary.
    Salk SoundScape 8's
    Sennheiser HD650
    Dynavector 17D3
    NHT B-12d subs
    CP Showcase
  8. #38
    Polk-a-dweeb
    Member Sales Rating: (0)
    Join Date
    Apr 2002
    Location
    Colorado
    Posts
    5,976
    Default
    Use a can of Sea-Foam in the crankcase. It will clean all of the crap out of the motor and allow the oil rings to seat properly. Great stuff!!
  9. #39
    Join Date
    Feb 2002
    Location
    Rockledge, Florida
    Posts
    11,587
    Default
    A Ford engine can burn 1 quart for 1000 miles, you got to be kidding me.
    No wonder Toyota is #1
    Edited because I'm an Idiot at times.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  10. #40
    Member Sales Rating: (27)
    Join Date
    Mar 2003
    Location
    NC
    Posts
    20,951
    Default
    My Ford isnt burning any oil...
    Its just relocating it in an unusable spot.. hell, it hardly burns ANY oil to be specific...
    Will check the intake tommorow... havnt had a chance - may not even have a chance tommorow...
  11. #41
    Join Date
    Mar 2003
    Location
    NC
    Posts
    20,951
    Default
    Just wanted to let you folks know that you guys nailed it right on the head...
    Changed the PCV valve and there is next to no oil in the intake now... oil pressure is normal, oil isnt being used.
    Truck is actually running 100% now as far as I know!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Truck 4 Amp
    By gwh in forum The Clubhouse
    Last Post: 04-17-2006, 11:48 PM
  2. A sub for a truck...
    By VR3 in forum Car Audio & Electronics
    Last Post: 02-13-2006, 09:38 AM
  3. A rig for a truck...
    Last Post: 02-01-2006, 01:47 PM
  4. Got a new project!!! I mean truck...
    By exalted512 in forum Car Audio & Electronics
    Last Post: 08-29-2005, 08:22 PM
  5. Sub for Reg. Cab Truck
    By phuz in forum Car Subwoofer Talk
    Last Post: 01-28-2003, 03:13 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
