Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 14 of 14
Thread: D/A Converters
  1. #1
    Member Sales Rating: (21)
    Join Date
    Mar 2007
    Location
    Wheatfield, Kansas
    Posts
    1,476
    Default D/A Converters
    There was a post about this recently, but I wanted to better understand. I understand that if I use optical audio (or coax) out from DVD to preamp/processor, that the processor does the D/A conversion. And if the DVD audio track is 5.1, it plays 5 channel. If the DVD is connected with RCA analogs to the processor, then the processor's D/A converters are used....BUT do I still get 5 channel sound (i.e., Dolby Digital or DTS)?
  2. #2
    Member Sales Rating: (6)
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,228
    Default
    Analog/RCA/XLR outs=source is doing the conversion
    Digital out (coax/fiber/XLR)=destination is doing the conversion
    EDIT: Fiber=Toslink, AT&T, Optical
    Source: Squeezebox Touch/CIA Power Supply
    DAC: Benchmark DAC/PRE
    Linestage: Placette RVC Passive
    Power Amp: Parasound HCA-1500A
    Speakers: Harbeth Compact 7ES-3 Monitor
    Subwoofer: SVS PB12-NSD
  3. #3
    Member Sales Rating: (19)
    Join Date
    Feb 2006
    Location
    Tampa, FL
    Posts
    7,387
    Default
    fiber = optical
    RCA 5 separate channel inputed into AVR and are only 5.1
    Optical and Coax auto define 2 ch,5.1,6.1,and 7.1 and so on.
    engtaz
  4. #4
    Member Sales Rating: (28)
    Join Date
    Mar 2005
    Location
    Right here.
    Posts
    10,412
    Default
    Quote Originally Posted by engtaz View Post
    fiber = optical
    SOPA
  5. #5
    Join Date
    Feb 2006
    Location
    Tampa, FL
    Posts
    7,387
    Default
    Help define it better for me PLZ HTrookie. I am at work and limited on time.
    engtaz
  6. #6
    Member Sales Rating: (11)
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,835
    Default
    in the olden days when DVD players first came out.. to get dolby digital or DTS you needed 5 analog RCA cables. L,C,R, LR, RR = 5 the .1 is and always will be your subwoofer. a cable would be used from the receiver's sub output to your subs input. giving you bass
    as well all know today you have the option of using only one cable to do the same exact thing.. that being a digital optical or coax cable.. no longer a need for 5.1 RCA cables.
    so it's up to YOU to decided which YOU prefer one digital cable or 6 analog cables. if you use the analog cables, YOUR DVD player does the decoding.. if you use YOUR receiver YOUR receiver does the decoding via digital cable.
    OMG it's not rocket science for pete's sake.
  7. #7
    Join Date
    Mar 2005
    Location
    Right here.
    Posts
    10,412
    Default
    I just have no idea of what you are trying to say....so can't help you.
    Steve has it right on.
    SOPA
  8. #8
    Member Sales Rating: (3)
    Join Date
    Oct 2004
    Location
    Mid-Michigan
    Posts
    3,549
    Default
    Quote Originally Posted by NeilGabriel View Post
    if you use the the rca's on the back of your dvd player it is not using the receiver's/pre-pro's dac it's using the one in the dvd player. so if you use the stero l/r output you are getting stereo, if you use the 5.1 output(l/r/c/s/ls/rs) you get 5.1(not all dvd players have dedicated 5.1 ouputs)
    I hope that helps
    Later,
    dude
    Speakers:SDA2a, sub:Atlantic Technologies 172 PBM
    Pre:B&K PRO-10MC(2ch)
    Amps:Parasound HCA 1000a
    SourcesOppo DV-970HD, Xbox360, Kenwood KT-5300
    Cables:Philips/RCA/Monster
    Life's short, Listen to SDA's
    Life is short live Sui Juris
    Where did SOPA go?
  9. #9
    Join Date
    Feb 2006
    Location
    Tampa, FL
    Posts
    7,387
    Default
    Some DVD player have 6 ch outs.
    engtaz
  10. #10
    Join Date
    Mar 2007
    Location
    Wheatfield, Kansas
    Posts
    1,476
    Default
    Quote Originally Posted by danger boy View Post
    I agree and understand the above. My question is that if I use the 2 channel RCA outputs on the DVD player, am I only going to get a 2 channel sound. It sounds like the answer is a resounding yes. The processor cannot decode that into a 5 channel sound cause it is not getting 5 channels of information.
  11. #11
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,835
    Default
    if you use 2 ch RCA outputs on a DVD player. the DVD player can downmix all channels into 2 channel's.
  12. #12
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,228
    Default
    Yes, you are correct. Out of 2-channel RCA out you are getting only 2-channels of information, and the source is doing the DA conversion.
  13. #13
    Member Sales Rating: (39)
    Join Date
    Jan 2006
    Location
    Dallas, TX
    Posts
    3,657
    Default
    I have my SACD player hooked up coaxial out to a Theta DAC to integrated amp's CD input. I also have the RCA outs hooked up to the integrated amp's AUX input for SACD playback as I don't believe SACD is output through digital (coaxial or optical).
    It works great! Hope I confused someone.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  14. #14
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,228
    Default
    Many folk's do that, redbook thru digital---SACD via analog (your only choice).
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. digital converters
    By Willow in forum Electronics
    Last Post: 11-22-2004, 09:56 AM
  2. Infrared to RF converters
    By bikezappa in forum Troubleshooting
    Last Post: 11-15-2004, 10:00 PM
  3. Where to buy AC to DC power converters?
    By Jeff1 in forum Speakers
    Last Post: 09-26-2003, 08:33 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
