Who wants to redo the wood on your Polks?
Take a look at this piece of exotic hard wood.
http://cgi.ebay.com/EXOTIC-WOOD-XF-P...QQcmdZViewItem
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreWho wants to redo the wood on your Polks?
Polk Audio SDA SRS 1.2TL's
With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
It All Started here: http://tinyurl.com/lasareath2
Part Deux: http://tinyurl.com/lasareath3
Nice, but I'd rather just buy a sheet of veneer.
Veneer perplexes me. How do you make the edges meet? do you cut a chamfer?, do you see the base wood then?
I'll be reveneering the tops and bottoms on some 2.3's here soon so I'll try to keep a log of what goes on. It's really not bad on veneering and, even with rounded corners, etc, it's relatively easy. Use the wider sheets on top and the trim type on the front edges...unless it's 1" wood. Band-it makes a tool that makes it a little easier to get a connecting edge for veneer but everyone is different on what they like to do. If you've not veneered before, give it a shot. Not too terribly hard. F1 can give some great advice on it as well.
Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?................. ................Sinner.
That is some amazing grain. B&W used a similar look on a run of their speakers.
http://cls.audiogon.com/cgi-bin/cls....oni&1195672110
Be proud of the job you did. It came out terrific!
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
There are currently 1 users browsing this thread. (0 members and 1 guests)
