Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 11 of 11
Thread: Media PC
  1. #1
    Member Sales Rating: (2)
    Join Date
    Sep 2004
    Location
    Illinois
    Posts
    1,622
    Default Media PC
    I made my lame attempt at finalizing my media PC tonight. When I say media pc, I mean that I took a 4 year old PC, put an ATI Radeon 9550 video card in and bought a logitech wireless keyboard and mouse and connected it to the DVI input on my TV. I'm really just going to use it as an Itunes jukebox, internet browser and file server for my laptop.
    Video: I'm a little dissappointed in the display through my TV, but it will do. Really, it looks like crap compared to what I expected, but I will play around a bit and see what I can do.
    Audio: The difference between the SPDIF output on the soundcard using Itunes (Apple Lossless files) and my CD player is indistiguishable compared to using the DAC in the H/K receiver . If I run the SPDIF through the external DAC it doesn't sound as "Big" as the output from the CD player. I'm pretty happy with audio overall considering what I put into it and what I was looking for.
    Keyboard and mouse: HELP!!! I have to be 4 feet from the transmitter to get either to work and that is WAY too close to the TV to make it usefull. What do I need to look for to find a keyboard and mouse that will work 10 - 15 feet from the transmitter?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  2. #2
    Member Sales Rating: (13)
    Join Date
    Sep 2007
    Location
    Bridgeton NJ
    Posts
    4,251
    Default
    is the transmitter in direct line of sight to them they are only sapost to work about that far away but if you have a clear line of sight ull be able to get it a little farther GREAT choice going with itunes as aposed to windows media player GREAT
    HT setup
    Dynex 40 inch tv
    Denon DBP-1610
    Monster HTS 1650
    Pioneer Elite VSX-81TXV
    Carver A400X
    MIT Exp 3 Speaker Wire
    Martin Logan Aerius
    Apple Tv 2nd Gen
    Logitech Harmony One Advanced Remote
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  3. #3
    Join Date
    Sep 2004
    Location
    Illinois
    Posts
    1,622
    Default
    I just found this one. Looks like it should work. Anybody had any other suggestions?
    http://www.tigerdirect.com/applicati...8753&CatId=537
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  4. #4
    Member Sales Rating: (6)
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,391
    Default
    I'm thinking you have a normal Blue tooth keyboard and mouse. They're designed for short range so not to interfere with other keypads and mouse.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  5. #5
    Join Date
    Sep 2004
    Location
    Illinois
    Posts
    1,622
    Default
    Quote Originally Posted by bigaudiofanatic View Post
    It's on top of my center channel, which is about 4 or 5 feet high.
    I've always liked the iTunes interface and playlist organization. Apple Lossless appears not to be too bad either.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  6. #6
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,264
    Default
    My PC looks great on my 56" DLP, maybe you need to play with your display settings. You can't beat Half Life 2 or Team Fortress 2 on such a big display. :D
  7. #7
    Join Date
    Sep 2004
    Location
    Illinois
    Posts
    1,622
    Default
    Quote Originally Posted by Face View Post
    What do you have your resolution set to?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  8. #8
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,264
    Default
    1280x768. If it helps, I'm using a G-Force 7800GTX vid card.
  9. #9
    Join Date
    Sep 2004
    Location
    Illinois
    Posts
    1,622
    Default
    If I set it at 1280x768 the display is very jittery. I have it set at 848x480 right now and think it will to the trick for now. I really dissappointed in the richness of the picture. I expected colors like a nice HD broadcast (like CSI Miami or something.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  10. #10
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,264
    Default
    Look in your TV's manual, it should give you a list of resolutions that'll work.
  11. #11
    Member Sales Rating: (1)
    Join Date
    Sep 2006
    Posts
    185
    Default
    ignore previous comments, i have a htpc that i use to play high def downloaded files (so sue me........not literally ;) ) and i have a wireless keyboard and mouse that works great from 12 feet right now. line of sight is needed but is pretty leniant. It's a laser mouse with great precision, not for gaming but for regular use it is very crisp and smooth. click here for product link
    search ebay, i got mine for 20 dollars shipped last year. if you can find a wireless setup that uses blue tooth then you will have better connectivity than this but this works great for me so far.
    in terms of video connection, you NEED to use the native resolution of your display adapter. for my vizio tv its 1366x768. its a pain to get the resolution but its possible to get it even if it is not listed in your supported resolutions in the nvidia control panel or ati, depending on your vid card maker. you can change the registry values by going going to run-->regedit (search online what tree to go to to find the values to input, its pretty simple).
    hope this helps
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. HT/Media room almost done!
    By Silverti in forum Electronics
    Last Post: 10-19-2007, 11:30 AM
  2. Media Bias?
    By Frank Z in forum The Clubhouse
    Last Post: 08-23-2006, 05:10 PM
  3. Media Room
    By kmartin971 in forum Speakers
    Last Post: 07-12-2006, 12:24 AM
  4. Media Extender
    By Willow in forum The Clubhouse
    Last Post: 12-22-2005, 02:19 PM
  5. 7.1 with 5.1 media
    By howie777 in forum Electronics
    Last Post: 09-27-2004, 08:18 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
