Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 8 of 9 FirstFirst ... 4 5 6 7 8 9 LastLast
Results 211 to 240 of 245
  1. #211
    Audiophile
    Member Sales Rating: (30)
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I've used Ruby Gold caps in a power supply before, but they do come in limited values.
  2. #212
    Member Sales Rating: (0)
    Join Date
    Sep 2008
    Location
    Athens, GA
    Posts
    496
    Default
    63V & 75V.
    Where thing get "complicated" is the the conflict of capacitance* & space. Cap w/values 10Kuf to 22Kuf*?
    * higher values take up more space
    I'd like 2-4 caps per channel; 20Kuf+ per channel (75V) & 40Kuf+ per channel (63V)
    Some guys like to add a smaller value cap to the big PS caps for better transients.
    I'm interested in this too.
    Thanks Tony
  3. #213
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I need help with a poly cap value on my 300B amp. The cap itself says .05 2000DC 430P. Does that makes sense to anyone?
  4. #214
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Great help from Mark (CoolJazz) on my cap issue. They are Sprague 430P .05mfd 2000v and I'm not going to be changing them out as they are a more rare value, and seem to be decent cap to begin with.
  5. #215
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Quote Originally Posted by gp4jesus View Post
    63V & 75V.
    Thanks Tony
    80V 10000uf Snap In Radial High-temp Low ESR
    You could get a number of these caps and use them to easily configure 20Kuf 75v and 40Kuf 63v as they are 10Kuf and 80v each.
  6. #216
    Join Date
    Sep 2008
    Location
    Athens, GA
    Posts
    496
    Default
    how do ELNA FOR AUDIO stack up against other favorites?
    Brand : Elna Capacitor
    Type : Elna For Audio
    Colour : Black
    Capital colour : Gold
    Capacitance : 12000 uf
    Volt : 63 V
    Diameter : 35 mm
    Height : 50 mm
    Lead pitch : 15 mm
    w/ shipping works out to about $8 each
    tony
  7. #217
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,146
    Default
    The Elna's will be perfectly fine.Unlike when used for signal coupling I'm of the opinion that the sonic differences between modern 'lytics' are miniscule when used for main power supply filtering,assuming similar values.
    btw.I assume they have a temp rating of 105 deg.which indicates a longer life expectancy.
  8. #218
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I've been chatting with Jantzen Audio and I think am going to get some of their Z-Cap Silver Gold capacitors to try. Since I've used their Z-Cap Silver, Superior, Standard, and Crosscaps with success, I asked Iwona what the difference was between the Silver and the Silver Gold caps. The main difference is in the foil from which capacitors are winded. Silver Cap is made from the same foil as Superior but with pure silver lead wires, while Silver Gold Cap uses 99% silver and 1% gold metalized polypropylene instead.
    I'm doing a 300B amplifier upgrade, so a mix of Silver Gold and Silver caps should yield interesting results.
  9. #219
    Member Sales Rating: (47)
    Join Date
    May 2005
    Location
    Sufficiently Breathless
    Posts
    11,285
    Default
    Hey guys,, not tring to derail,,but I's like some advice,,here we go,I have a pair of Quicksilver M-80 monoblock amps,,PTP wiring,,as they get older I am considering replacing the electrolytics with the same uF value with a slightly higher voltage rating(after I measure the actual voltage),if necessary.So,,any suggestions regarding brand/type of electrolytic caps for electronics? Thanks in advance
    George
  10. #220
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,146
    Default
    I assume for power supply filtering , there are a number of good choices like Cornell,UCC,Nichicon ,Panasonic.Look for something with low impedance and a 105 deg. temp. rating as they will have a longer life cycle.
  11. #221
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I would go with Nichicon George if the values are appropriate. They make a great product that is well priced. Ruby Gold also makes good electrolytic caps, but they have only have lower values.
    I about about to install a pair of Bennic 1000uf electrolytics to replace a pair of Panasonics in my T-Amp. I can report back later to let you know if their electrolytic caps are a good product also, but don't want to make a recommendation yet as I have not heard them.
  12. #222
    Join Date
    May 2005
    Location
    Posts
    11,285
    Default
    Thanks Zingo-- let me know please sir.
    Thank you too Fred-- you should be gettin' something in the mail soon.
  13. #223
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,146
    Default
    Quote Originally Posted by george daniel View Post
    Awesome thanks George,perfect timing.
  14. #224
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    21,240
    Default
    Panasonics are great for power filtering. If Nelson Pass uses them then they must "Pass" the test. Nichicon are nice as well, but Panasonic has more value choices. He's been know to recommend and in some cases use Mallory caps as well.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Eastern Electric Mini Max; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  15. #225
    Join Date
    Sep 2008
    Location
    Athens, GA
    Posts
    496
    Default Cap shoot out I realize but... (prefered resistor type)
    ...Metal film resistors are THE prefered resistor, low noise etc, right?? I can change an EXO frequency with resistors
    thanks tony
  16. #226
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,146
    Default
    In electronics yes,though bulk foils are superior but at many times the cost.Wirewounds and Metal Oxides are the norm for passive XO's as metal films are not available at high enough wattage ratings.
    An active crossovers frequency can be changed with a change in resistor value,but in a passive XO the resistors are used for attenuation and response shaping.To change crossover frequency in a passive network you would alter capacitor and inductor values.
  17. #227
    Member Sales Rating: (13)
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,300
    Default
    George
    I'm changing a bunch of PS caps in my tube pre amp as two of them were ready to blow. As Black Gate is out of business I had to do some research and decided to go with Panasonic.
    'Political Correctness'.........defined
    "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  18. #228
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,791
    Default
    Don't forget Jensen.
  19. #229
    Join Date
    Mar 2002
    Location
    The Mars Hotel
    Posts
    31,300
    Default
    They don't make the values I need.
  20. #230
    Join Date
    Sep 2008
    Location
    Athens, GA
    Posts
    496
    Default
    Quote Originally Posted by FTGV View Post
    In electronic [XOs] yes. Bulk foils are superior but at many times the cost. An active crossovers frequency can be changed with a change in resistor value...
    "Sounds like" metal films offer big bang for the buck in electronic XOs. thanks
  21. #231
    Join Date
    May 2005
    Location
    Posts
    11,285
    Default
    Quote Originally Posted by heiney9 View Post
    Brock,, I like the way that you worked Nelson Pass's name into this.
    I think that I'm gonna go with the Panasonic series--thanks all for the replies and suggestions
  22. #232
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I just got these caps in yesterday, and the Bennics are larger than the ClarityCaps! I'm quite sure how they are going to fit into my little T-Amp chassis, but I'm sure I'll make it work... :tongue:
  23. #233
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Before:
    After:
  24. #234
    Member Sales Rating: (43)
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,931
    Thumbs up
    Wow Zingo you stuffed that box pretty full. Give it some time and get another thread going on how it sounds.
    Ben
  25. #235
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I replaced the Bennic 2.2uF input capacitors with ClarityCap ESAs. This provided better depth, body, and clarity, giving the T20U a more expansive, fuller and overall more musical sound. I also replace the stock 1000uF tank capacitors with MUCH larger Bennic electrolytic caps which provided tighter, more powerful bass, improved dynamics and better channel separation. Class D amps can be more effected by cables than regular amps, and the same proved true with capacitors. As soon as I flipped on the amp I could hear all the improvement, even before any burn-in! I'm excited to see how this amp evolves, but I have never heard such a dramatic improvement in SQ with cap upgrades than with this amp.
    Comparing it to my newly upgraded Shuguang Treasure 300B amp, the tubes still provided better tone with more body and life, but the T20U+PSU was still very impressive. I'm really enjoying this Tripath amp, and it you have not heard an upgraded version of one of their better amps, it's worth a listen.
  26. #236
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I've been busy once again...
    Before:
    After:
  27. #237
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,791
    Default
    You may want to reconsider the Standard Z caps.
  28. #238
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    The Standard Z caps are not in key locations, so don't you worry. (Plus I wanted to go with all Jantzen caps, and that is the only line for which they have 100uf) For the coupling caps and other signal carrying locations, I used a combination of Jantzen Silver Gold caps and Silver caps. They are already a nice improvement over stock sound with only a few hours on them, and mixing very well with the Shuguang Treasure tubes and circuit. This amp is the best I've ever used on my speakers, and the high sensitivity Klipsch's are right at home with it.
  29. #239
    Join Date
    Jan 2010
    Location
    At the golf course eating mushrooms!
    Posts
    1,267
    Default
    ^ Reported
  30. #240
    Join Date
    May 2010
    Location
    Addison
    Posts
    1,132
    Default
    IMO, this thread should be a sticky
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, DIY Statements, Samsung 52" LCD
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Capacitor help, please.....
    By geoff727 in forum Vintage Speakers
    Last Post: 10-07-2007, 03:32 PM
  2. popped Capacitor
    By Hirobo in forum Troubleshooting
    Last Post: 02-06-2007, 08:40 AM
  3. capacitor?
    By beavis240 in forum Car Audio & Electronics
    Last Post: 10-21-2004, 04:57 AM
  4. Capacitor
    By hobopenguin in forum Car Audio & Electronics
    Last Post: 08-08-2001, 02:49 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
