What is the best way to put my grill holders in my Monitor 7Cs? Should I just tap them in with a hammer?
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreWhat is the best way to put my grill holders in my Monitor 7Cs? Should I just tap them in with a hammer?
That would work.
thanks but nevemind, they are too small for the holes, they just slide in and are not big enough in diameter to stick. Ugh!!!
looks like another call to Polk
UHHHGGG, If Polk doesnt have them, try partsexpress. I bought some there, for my subs, that looked like the same size as my 7's.
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!
The PE ones fit the holes but the heads are a hair too small. Get the right ones from Polk.
There are two sizes.....you need the large ones.
Thanks Jake, I am on the phone with Polk now. I may try Parts express if Polk cannot get me the correct ones.
Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!
must be a tough part to find, I am on hold now, he went away to check
The guy from Polk found the larger ones and is sending them to me.
Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!
Grill holders? Aren't those called teeth?:D
HT - Adcom GFA7400H - Douglas Connection Furez cables
Well it has been the 3rd time I called Polk to get these, just wondering what the issue was
There are currently 1 users browsing this thread. (0 members and 1 guests)
