Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 27 of 27
  1. #1
    Audiophile
    Member Sales Rating: (30)
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default 2 preamps into 1 amp?
    Here is my idea (Illustrated in confusing picture). I want to combine my HT and 2 ch to create one system that fits a little better in a house, yet still sounds as good as my 2 ch. As good as my Marantz pre/pro sounds for HT, it's not very musical and 2 ch is not its forte. So, what if I built two "Y" interconnects that went from my pre/pro and preamp to my main amp and my subwoofer amp. Those are the only two systems that would be used for both music and movies, so all the rest of the equipment would be independently controlled by the pre/pro. Would a "Y" IC create any problems as long as only one pre was on at a time?
  2. #2
    Member Sales Rating: (27)
    Join Date
    Apr 2005
    Location
    CT
    Posts
    2,410
    Default
    Sending a output to another output sounds like a bad idea to me even if only one was on at a time. You can't run your HT through your 2ch pre and run that direct to your amp?
  3. #3
    Member Sales Rating: (4)
    Join Date
    Jan 2005
    Location
    LSU, Louisiana "In a galaxy far far away"
    Posts
    4,100
    Default
    Just get a switch. Video and audio switch should pass anything right through.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!
  4. #4
    Member Sales Rating: (10)
    Join Date
    Jun 2007
    Location
    Cape Cod, Massachusetts
    Posts
    1,286
    Default
    I don't know if it'd work or not, but it sounds risky. How about picking up a pre-amp with an HT Bypass (unity gain)? That's what I do, and it works great.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  5. #5
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Hmmm... that is a good idea with the pass through. I'll look at my pre/pro and see if it has a function like that. Do they make a "Hifi" interconnect switch box? I just don't want to pass my 2 ch signal through some junky little box that bottlenecks my system.
  6. #6
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Would a tape in-out work, or does it specifically have to be something else?
    Here's what the back looks like if you're interested:
  7. #7
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    How about upgrading your pre/pro that also sounds good in 2ch. mode?
  8. #8
    Join Date
    Apr 2005
    Location
    Magnolia, NJ
    Posts
    4,084
    Default
    I just sold my CJ PV14LS2 tube preamp w/ HT bypass that would have fit the bill perfectly for you. It sounded & worked great. Your best bet to do it right is to buy a separate 2 channel pre w/ HT bypass. That way your 2 channel & HT are kept completely separate.
    "2 Channel & 11.2 HT "
    Panny 65" 3D Plasma
    Yamaha AVENTAGE RX-A3010 AVR
    D>SONIC M2-600M mono's / mains
    Rotel RMB-1095 / 5 channel amp
    Rotel RMB-1075 / 5 channel amp
    TEAC UD - 501 DAC
    Oppo BDP-93
    SONOS System
    KEF Q900 / mains
    KEF Q600 / center
    KEF Q800 / surrounds
    KEF Q100 / rear surr.
    Def Tech ProMonitor 1000 / front & rear presence
    Velodyne SPL-1200R subs / dual pair
    DSPeaker Anti-Mode 8033 sub EQ
    Equitech Balanced Power Son of Q 1.5R
    Extensive room treatments
  9. #9
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    You don't need separate components to do it right. It can be done right with the correct components, but it'll cost you.
  10. #10
    Member Sales Rating: (9)
    Join Date
    Jul 2001
    Location
    Fort Lauderdale, FL
    Posts
    2,493
    Default
    Quote Originally Posted by pearsall001 View Post
    I 2nd that idea.
    Let me tell you something about life, around every corner monsters await. I know, I am one.
    If I owned hell and this place, I would rent this place out and live in hell.
    Mains: Anthony Gallo Reference 3.1
    Preamp: Modwright SWL9.0SE
    Amps: Butler TBD2250, PS Audio Trio
    PrePro: Cary Cinema 6, Outlaw 990
    DAC: Benchmark DAC1
    Universal Player: Denon 2900
    Cables: StraightWire Encore II, Kimber Hero, Audioquest Type 4, CV-8, Columbia DBS
    Power Conditioner: Belkin PF60
  11. #11
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Those do sound like spendy options. Is there anything I can do with my current equipment...
    What if I just built my own little two-way hifi switch box?
  12. #12
    Join Date
    Jun 2007
    Location
    Posts
    1,286
    Default
    I think you might be able to use the tape loop to do something like what an HT Bypass does. I honestly don't know the difference between the two -- I only know that my HT Bypass works great.
    It may be that the tape loop doesn't leave the signal unprocessed, so the fronts when using it for HT might not sound as good. Or there may be some other difference, which someone else can chime in about. Might be worth a shot of experimenting though.
  13. #13
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    What if I created a two-in two-out audio switch? I could input both my preamp and prepro like a regular switch box. But split the output to two sets of jacks, so each source would get sent both amps. I would just buy a Radioshack two-way switch and rewire it. Would splitting the signal like that work?
  14. #14
    GV#27
    Guest
    Default
    Why not just connect the pre outs of your Marantz into an unused input on your preamp?Then set the preamps volume to the appropriate level.Having the pre in the chain should not degrade the HT sound discernably.
  15. #15
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I feel confused, but I don't think that would do it. The issue is that each amp only has a single set of inputs, and no outputs. So I would still be running an output from each pre to a single amp. Or did I miss something...
  16. #16
    GV#27
    Guest
    Default
    Sorry can't do a scetch but here is what I mean.
    Marantz front L and R pre out to aux in on Pre amp.
    Preamp L and R out to main amp in.
    When you want to watch a movie select aux input on the pre amp and set the pre amps volume control about half way.This will allow the Marantz's output to feed through the preamp.You will likely have to readjust the balance between the fronts center and surrounds with the reciever.
    Does that make sense?
  17. #17
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Oh. That just might work good sir! So the 2 ch pre would end up being a control for the main speakers and subs when I watch movies, but runs independently when I listen to music. I'll have to try it out...
  18. #18
    Member Sales Rating: (3)
    Join Date
    Aug 2005
    Location
    Hamilton, OH
    Posts
    905
    Default
    Quote Originally Posted by GV#27 View Post
    The above is what I do and it works well. I set my 2ch pre's volume to a predetermined level that I have calibrated with the rest of the HT channels (about 1/2 way on the pre's volume knob) However, as others have said, a 2ch pre with a HT bypass is the ideal situation when you want a 2ch pre and HT pre/pro to share the same amp for L/R, since it bypasses the preís gain circuitry.
    Trying to share the sub between the HT pre/pro and 2ch pre is going to be more of a challenge. Hooking things up like above and then running the sub with speaker-level connections from the L/R amp, and speaker level outs from the sub to the L/R speakers may work.
    Most 2ch pre's do not have a line level sub out or bass management. For these pre's, you would need to run a 2nd set of pre-outs (assuming it had them) from the 2ch pre to the sub and adjust the sub's low pass filter and level to blend with the L/R.
    Even if you used a switch for the pre/proís sub out and a 2ch sub out (or 2nd set of stereo pre outs), you may need to change settings on the sub for each. For example, if the sub has a low pass filter bypass, you would want to use that for the pre/pro since it has bass management, but you would want to use the subís low pass filter with the 2ch pre in order to blend with the main L/R (assuming the 2ch pre doesnít have any bass management). Kind of messy.
    Polk LS90
    Polk CS400i
    Polk FX500i
    Outlaw LFM-1 Sub
    Polk Monitor 7C (secondary location)
    Pioneer Elite VSX-45TX
    Audiosource Amp Three (2), Amp One/A (1)
    Cambridge Audio C500 Preamp
    Sony 222ES CD/SACD
    MSB Nelson Link III DAC with P1000 Power Supply, Music Hall DAC 25.2
    Squeezebox Classic
    Sony BDP-S1000ES
    JVC DLA-HD250 Projector
    Da-Lite HCCV - 100" Permwall 16:9
    Time Warner HD Cable
    Panamax 500 DBS
    MIT, Blue Jeans, AR, Outlaw Cables
    System Showcase
  19. #19
    Join Date
    Jun 2007
    Location
    Posts
    1,286
    Default
    The problem with that approach is that you'll not be able to get correct volume matching in HT. "About half way" isn't going to cut it when you really want your speakers calibrated within a db of each other.
    And that's exactly what the HT bypass of a pre-amp will do for you, because it outputs a fixed level. It lets you calibrate for HT and not have to "guess" at the volume level each time you switch inputs. I'd still pursue the tape loop a bit if I were you -- it has a chance of working the way you want I think.
    And also, as adam2434 mentioned, doing that would still route the signal through the pre's gain path, which means it'll get doubly processed.
  20. #20
    GV#27
    Guest
    Default
    Quote Originally Posted by zingo View Post
    Yes.
  21. #21
    GV#27
    Guest
    Default
    Quote Originally Posted by tcrossma View Post
    After he calibrates his levels he merely just has to set the volume on the preamp at the exact same spot every time he watches a movie.Mark it with tape or something.
    As it will going through the tape loop as they are usually buffered with an an op amp.Anyhow the pre amps gain stage should be neutral enough that it does not degrade the HT sound noticeably.It won't hurt to give it a try.
  22. #22
    Join Date
    Aug 2005
    Location
    Hamilton, OH
    Posts
    905
    Default
    If you calibrate the L/R ch levels on the pre/pro with the 2-ch pre's volume at a specific point (say 1/2 way), and make a small mark on the pre (if it doesn't already have tic marks for volume levels that you can reference), and set it to exactly that same place every time, you can can have proper level matching every time.
    I do agree that a pre with a HT bypass is the ideal though.
    Polk LS90
    Polk CS400i
    Polk FX500i
    Outlaw LFM-1 Sub
    Sony 222ES CD/SACD
    Squeezebox Classic
    Sony BDP-S1000ES
    Panamax 500 DBS
    System Showcase
  23. #23
    Join Date
    Aug 2005
    Location
    Hamilton, OH
    Posts
    905
    Default
    Yep, I hear no problems or degradation running my receiver's L/R pre out to an input on my 2ch pre with the volume on the pre at a predetermined level (1 tic over 1/2 way up).
    In the grand scheme of things, with the equipment I have, this is the best compromise to get the best 2ch sound my system can offer without swapping cables around.
    My next 2ch pre will have a HT bypass though, or maybe a pre/pro that has good 2-ch performance.
    Polk LS90
    Polk CS400i
    Polk FX500i
    Outlaw LFM-1 Sub
    Sony 222ES CD/SACD
    Squeezebox Classic
    Sony BDP-S1000ES
    Panamax 500 DBS
    System Showcase
  24. #24
    GV#27
    Guest
    Default
    Quote Originally Posted by adam2434 View Post
    Yes it is a simple solution without adding cost or complexity.:)
  25. #25
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I will try this first since it won't cost me anything. It seems like a pretty good solution, and I will try both the tape-loop and the pre-out. And I am not too worried about the subs as they have their own amp and an active x-over (thanks to GV#27s suggestion) with separate volume control.
  26. #26
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    I may be solving this problem. Right now I am looking at the Lexicon DC-1 and Outlaw 7100 combo. I feel like that would solve all 2 channel and HT problems...
    (PS. Is the 7100 a common ground amp?)
  27. #27
    Audiophile
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    11,185
    Default
    Yes the 7100 is a common ground; I just measured it.
    Looks like I'm pulling the trigger on the Outlaw 7100 & Lexicon DC-1 combo (Since I already have half of it now :)). I think that should be a nice upgrade, for HT and 2 channel.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Tube Preamps and hum
    By polkatese in forum 2 Channel Audio
    Last Post: 09-07-2005, 11:20 AM
  2. Tube Preamps
    By gregure in forum 2 Channel Audio
    Last Post: 08-31-2005, 01:05 PM
  3. Do higher end preamps have a sub out?
    By trubluluc in forum Electronics
    Last Post: 10-28-2004, 06:37 PM
  4. But seriously, what Preamps are out there...
    By steveinaz in forum Flea Market
    Last Post: 01-09-2004, 08:17 AM
  5. preamps
    By gmg in forum The Clubhouse
    Last Post: 08-06-2001, 11:51 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
