Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Member Sales Rating: (1)
    Join Date
    Mar 2008
    Location
    Florida
    Posts
    304
    Default 12 volt trigger question
    Hello, the Onkyo 805 has an RI trigger that is supposed to be used for other Onkyo products and a 12 volt trigger for the number 2 zone. Can either of these be used to trigger the Rotel RMB-1077?
    Hitachi 50" Plasma full HD 1080--Onkyo 805 AVR
    Rotel RMB-1077 amp--Polk LSic center
    Polk LSi25 fronts--Polk LSi 15 rears
    Genesis G-2800 sides--Polk PSW 650 sub
    APC H15 power conditioner--Netgear digital media player
    Napster external hardrive--Linksys Wireless G router
    Samsung DVD--Blue Jeans wires
  2. #2
    Member Sales Rating: (4)
    Join Date
    Feb 2005
    Posts
    3,586
    Default
    12 volt should work fine. Check the current that the Rotel pulls and the current that the Onkyo puts out (shouldn't be a problem, but you want to be sure).
  3. #3
    Member Sales Rating: (2)
    Join Date
    Mar 2008
    Location
    Indianapolis, IN
    Posts
    205
    Default
    Ever figure out how to hook up the trigger for the amp to the Onkyo? I'm using the R1 for a Onkyo Dvd player. Can the Zone 2 be used?
    I've got amp coming and trying to plan ahead.
  4. #4
    Join Date
    Mar 2008
    Location
    Florida
    Posts
    304
    Default
    Nope. I would think if you use the zone 2 trigger the side surrounds will be "off". I just do the finger thing to turn on the amp.
  5. #5
    Member Sales Rating: (8)
    Join Date
    Jan 2006
    Posts
    1,306
    Default
    I'm not familiar with these pieces but, does the amp have a trigger out? You may be able to daisy chain them. For example, AVR to amp, amp to cdp.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  6. #6
    Join Date
    Mar 2008
    Location
    Florida
    Posts
    304
    Default
    Onkyo has their own type of trigger for Onkyo components only called RI but it does have a trigger for a "zone 2" amp but the manual indicates when the zone 2 is on the side surrounds are off.
  7. #7
    Join Date
    Feb 2005
    Posts
    3,586
    Default
    Well, there's always this neat little trick:
    Get a 12 volt wallwart adapter & plug it into the switched outlet on the back of the onkyo. On the DC end snip off whatever plug it comes with and solder on whatever style adapter you need for your amp. Works great and you can switch as many amps on as you need by just picking an adapter with enough mA to cover their summed draw.
    Backburner:Krell KAV-300i
  8. #8
    Join Date
    Mar 2008
    Location
    Florida
    Posts
    304
    Default
    Well that's a neat idea. I'll give it a try.
  9. #9
    Join Date
    Mar 2008
    Location
    Indianapolis, IN
    Posts
    205
    Default
    Demaples,
    Hooked my new amp up today. I'm using the Zone 2 12V trigger out on my Onkyo to the amp with 1/8" to 1/8" mono cable with no problems. Just makes powering the AVR and the amp a 2 step process.
    Just hook your amp to the Zone 1 preouts as normal. While it's true that Zone 2 will on power 2 channels....Zone 1 will still operate as normal with the Zone 2 on. After powering the AVR, just hit the Zone 2 button then the "on" button on the remote.
    The wall wart is a nice option to keep in mind too. Especially if you actually plan on powering Zone 2 to run a couple speakers. ...I know I'm not.
    Hope this helps.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. how to get a 12 volt trigger
    By chargerman426 in forum Basic Hookup/Wiring Questions
    Last Post: 04-15-2008, 08:43 PM
  2. 12 Volt Trigger.
    By MSALLA in forum Electronics
    Last Post: 04-05-2007, 04:09 PM
  3. 12v trigger question?
    By hamzahsh in forum Basic Hookup/Wiring Questions
    Last Post: 12-19-2006, 06:09 AM
  4. XM Reference Tuner 12 Volt trigger
    By norris81b in forum Troubleshooting
    Last Post: 08-04-2005, 07:01 AM
  5. Polk DX, 2 volt or 4 volt input?
    By Joe in forum Car Subwoofer Talk
    Last Post: 03-21-2003, 11:37 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
