Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 37
  1. #1
    Member Sales Rating: (6)
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default My Harman AVR 247 is driving me crazy
    I've been drilling through the OSD for weeks trying to figure out the direct/bypass mode. Every time there's a layer change/channel change, the 247 switches back to DPLII Movie... it it's a stereo source, I want to hear it in stereo, if it's 5.1, pass-through the DD stream, etc... IS there an easy way to get this receiver out of its own way, or am I stuck pressing the "surround" button six times every time it decides to switch back to DPLII?
    Also - why do the "stereo" and "direct" buttons on the remote do nothing? WTF Harman?
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  2. #2
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    I had a 245, IMO that remote was the worst I've ever owned.
  3. #3
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    Was there a direct or bypass mode on the 245?
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  4. #4
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    I don't remember, I only used it for HT.
    I do believe I remember those buttons on the POS remote though.
  5. #5
    Member Sales Rating: (39)
    Join Date
    Jan 2006
    Location
    Dallas, TX
    Posts
    3,657
    Default
    My 635 had those buttons, and stereo seemed to work, but "direct" didn't seem to do anything.
    I had to use the multi channel inputs to get "direct" sound. Have no idea why it isn't easier. I need to check out my B&K 507 to see if it works better with "direct." I know it has a direct feature I can choose through the menu.
  6. #6
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    I guess the multi-channel inputs are always an option... grr. I'm starting to wish I'd just bought one of their stereo receivers and kept it simpler.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  7. #7
    Member Sales Rating: (5)
    Join Date
    Apr 2005
    Location
    San Jose, CA
    Posts
    3,182
    Default
    IIRC, auto polling has to be disabled for every source/format. This should fix the DPL2x force. Also, just setup your Direct through the analog/6-8 channel direct function. It sounds signifcantly better.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  8. #8
    Join Date
    Oct 2007
    Location
    Pensacola, Florida
    Posts
    754
    Default
    Quote Originally Posted by RutgersFTW View Post
    I have the AVR 240 (not currently using it) so this may not be the same. In the Input Setup menu the "default" SS mode for the initial lock can be set to Stereo (or several others). It sounds like yours is set for DPLII Movie. It sounds like yours also may be changing even after you set it. On mine I can turn off Auto-Polling for an input. Supposedly AP keeps looking at the input signal for changes. You might try turning it off. As for the Direct key I really don't have any suggestions other than hit the AVR Source key first and then hit Stereo or Direct.
    Hope this helps.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  9. #9
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    Here's my screen:
    Source: HDMI 2
    Title: Cable
    Video In: HDMI 2
    Audio In: HDMI 2
    Auto Poll: Off
    Tone: In
    Video: mode A
    My Oppo and the H/K play nice (though the Oppo often chooses the 2 channel, non DD track on DVDs and I have to manually select the DD/DTS track... WTF is up with that too, btw?) most of the time, it's just the dumb cable box.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  10. #10
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    AHHHH I just changed the default mode to Dolby VS Ref 2Ch, then turned off the OSD. The receiver flashed the two channels (like it was re-handshaking with the HDMI) then POPPED BACK WITH DOLBY PLIIX MOVIE!!! AHHHHHHHHHHHHH!!!! I'M GOING TO FIND THIS RECEIVER'S NECK, THEN THROTTLE IT.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  11. #11
    Join Date
    Oct 2007
    Location
    Pensacola, Florida
    Posts
    754
    Default
    Sorry, I'm out of ideas. My 240 does not have HDMI so I was using optical out of the cable box to the HK. In my case the default was PLII Movie for cable, Stereo for the Squeezebox, and DD for the DVD player. I've had auto poll off on the DVD & Squeezebox and on for cable and everything worked just fine. My only guesses are weird cable box or malfunctioning HK. I suppose you could play around with optical audio + HDMI video just to see if the problem moves but it kind of defeats the convenience of HDMI. Sorry.
    TT = Audio Technica
  12. #12
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    It's been bothering me all month, but it's REALLY starting to bother me now that the return window closes in 5 days. I knew when I bought it some people found it unintuitive, but I like to think I'm fairly capable at working complicated electronics. At this point, the receiver isn't being difficult, it's just being mean. If it's a normal inconvenience from the receiver that otherwise works pretty well, then fine. But if it's abnormal, I'm really annoyed.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  13. #13
    Member Sales Rating: (11)
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,835
    Default
    i don't know about HK receviers.. but yeah you are on the right track.. you should be able to override the DPL mode.
    I think some receiver treat a 2 ch stereo signal and automatically convert it to DPLII as a default. This is a PITA, but what if you reset the HK and set everything up again in the menu?
    Or
    Don't use HDMI for audio and instead use and optical cable for the audio portion. Might solve the problem.
    good luck though.
  14. #14
    Member Sales Rating: (1)
    Join Date
    Dec 2003
    Location
    Sooner Country
    Posts
    3,979
    Default
    HK has always been notorious for dropouts. Do a search at AVS forum and see how far back it goes, I can recall at least 5 years of dropout issues. Diehard HK fans keep them simply for the power and sound, not the processing...........
  15. #15
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    It definitely sounds nice for a cheap receiver, but this PITA stuff is really a PITA.
    Are the AVRs by Nad, Cambridge, etc... as bad with annoying things you don't think will bother you but do?
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  16. #16
    Join Date
    Oct 2007
    Location
    Pensacola, Florida
    Posts
    754
    Default
    Just a personal opinion but I think you will find that they all have their “why the hell did they do that” problems. It seems that the more sophisticated receivers are intended for the least sophisticated users. In others words, "our product are so complicated we really can’t trust you to mess with it or you may screw it up and then call us for help". Then there is the argument that people who spend a couple of grand on a receiver / processor are not the type folks who spend time tweaking settings; or that people who buy $400 receivers from Best Buy are probably not “stereo purists”.
    Unfortunately that approach doesn’t help those of us that are comfortable with technology, like to experiment, or have a specific listening goal in mind. My guess is that most people buying mid-range receivers enjoy having music or TV dialog dancing all around the room.
    I’m not sure how you combat it. A lot of the members have dedicated music systems and dedicated home theater systems. An expensive and space-intensive solution perhaps but it does solve the problem. My guess (and it really is a guess) is that your odds may increase with non-mass-marketed brands having roots in the higher end or custom installer markets. NAD would be one example but there a many. Of course you will probably have to spend a LOT more than your HK costs.
    It’s possible your HK is just not working right due to a design flaw in the DSP chip or in the audio extraction processor from the HDMI link. In either case, moving to any other brand receiver / processor would probably solve the problem - and no doubt introduce others. If it’s an HDMI issue then reconfiguring to an optical input may bypass the issue. The 240 was a pretty stable receiver, the 245 & 247 marked the change to HDMI (I believe) so maybe the problem is there. Regardless, if you are otherwise happy with the HK then I would try an optical input. If you’re “so so” on the HK, moving to another brand may be the only other choice.
    TT = Audio Technica
  17. #17
    Join Date
    Jan 2006
    Location
    Dallas, TX
    Posts
    3,657
    Default
    I don't know, my old 635 worked perfectly for 2.5 years or so. Never dropped a signal, never reverted back to a processing mode I didn't choose myself. Always a trooper, and the remote (while not perfect) did allow for easy changing of digital/analog inputs, speaker size, bass, etc.
    As far as user friendliness goes, I thought the HK was at least on par with my new B&K Ref 507 S2. I'm still getting used to the B&K (only had a couple weeks and watched a couple movies) but it seems to be able to do a few things the 635 couldn't, and vice versa.
    For looks, sounds quality, power, the B&K is the winner, but not by a landslide. Guess I should just post a full review of the two and be done with it.
  18. #18
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    I switched to a coaxial connection but it's the same story. My e-mail to Harman hasn't been answered yet, so hopefully there's an easy fix. The OSD is actually pretty good overall, and input naming/assigning is handled better on this AVR than any I've used before. Surround mode crap aside, it's pretty nice.
    The sound signature is totally different over Coax, btw. I'm not sure if it's better, but it's different.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  19. #19
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    http://www.amazon.com/Harman-Kardon-...325618&sr=1-29
    This is sexy and would probably drive LSi9s well, right? I've already got the proprietary H/K iPod dock so I don't want to walk away if I don't have to. Two sub outs, digital connection options, and a phono stage? Maybe this is more up my alley and I can just route the HDMI to the TV... stupid 30 day return window.
    Now fewer buttons are working on the remote (including the directional toggle) and I just changed the batteries yesterday. I've never had a REMOTE flake out.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  20. #20
    Join Date
    Jan 2006
    Location
    Dallas, TX
    Posts
    3,657
    Default
    It would probably be "adequate" for Lsi9s. I have a 3480 and it does well with Lsi7s.
    Look up the HK 990 and see what the prices are. It looks more like an amp that could drive Lsi9s properly. I think I'm going to get one to replace my 3480 when prices come down a bit more.
  21. #21
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    IMO, coax usually sounds better than optical.
  22. #22
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    Quote Originally Posted by AndyGwis View Post
    I guess it would be better to ask if I'd get better sound from my RTi6 with more power, but I'd assume the answer is "yes." I had thought 150ish /ch @ 4ohms with extra headroom would stand up to the 9s, though.
    Still no word from Harman CS.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  23. #23
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    LSi9's can go down to 2ohms.
  24. #24
    Member Sales Rating: (10)
    Join Date
    Dec 2005
    Location
    Safely in my Faraday cage
    Posts
    1,840
    Default
    As I remember, the 'direct' button was to dial in a specific FM station, and to go direct 2 channel, you hit the 'stereo' button until the DSP light went away. I not sure if 'direct' worked on digital inputs.
  25. #25
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    @ SK: I checked the manual and you're right - "direct" is for tuner input. Score 1 for h/k, minus 1 for me. The stereo button still won't work, though; is each button (Dolby Surround, DTS, DTS:Neo 6, Stereo, and whatever else) only able to switch modes when that mode is selected in the OSD?
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  26. #26
    Join Date
    Oct 2007
    Location
    Pensacola, Florida
    Posts
    754
    Default
    My 240 will switch any time but I have to hit the AVR button first.
    TT = Audio Technica
  27. #27
    Join Date
    Apr 2005
    Location
    San Jose, CA
    Posts
    3,182
    Default
    Quote Originally Posted by Marty913 View Post
    Plus 1...you need to hit the AVR button to change applicable formats.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  28. #28
    Join Date
    Apr 2008
    Location
    New Jersey
    Posts
    457
    Default
    I always check the AVR button, guys, but thanks anyway. The "Dolby Sur" button is responsive but the other four are not.
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Mirage CMD-5 x 5
    Bic H-100
  29. #29
    Member Sales Rating: (4)
    Join Date
    Jan 2005
    Location
    LSU, Louisiana "In a galaxy far far away"
    Posts
    4,100
    Default
    Its because its a digital signal. DD and Logic 7 (if you have that), will be your only option. Stereo will not work, unless you use DD stereo. Analog or non-coded signal through coax/optical will allow you Stereo, other than that, (at least on my 635) you cannot use Stereo.
    Also, on another note, in the OSD under advanced, turn polling "off" and source to "last".
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!
  30. #30
    Join Date
    Jan 2005
    Location
    Posts
    4,100
    Default
    Page 58 of the owners manual, Read on default surround modes. Turned on or off
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. What's driving your LSi-15's?
    By Dave38 in forum Speakers
    Last Post: 10-13-2011, 10:22 PM
  2. Phase setting driving my crazy
    By Jack from Indo in forum Car Audio & Electronics
    Last Post: 04-09-2007, 10:44 PM
  3. So I'm driving...
    By Frank Z in forum The Clubhouse
    Last Post: 05-21-2006, 02:58 PM
  4. Driving Mon 7s
    By KCF in forum Vintage Speakers
    Last Post: 01-02-2005, 02:24 PM
  5. cables driving me crazy
    By danger boy in forum The Clubhouse
    Last Post: 02-13-2002, 12:19 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
