Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 43 of 43
  1. #31
    GV#27
    Guest
    Default
    Quote Originally Posted by Early B. View Post
    Update --
    I got the sub and hooked it up in the front of the room (main sub is in the back of the room just behind the seating position). Wow! I didn't expect this cheap sub to make such a big difference. Of course, it doesn't dig deep, but it fills in very nicely. My main sub is no longer localizable (is that a word?). For the price I paid ($129 NIB with free shipping), it is a great tweak for HT.
    Brad what frequency is the main sub crossed over at ,and how far down does your new one extend?
  2. #32
    Member Sales Rating: (19)
    Join Date
    Sep 2003
    Posts
    8,170
    Default
    Quote Originally Posted by GV#27 View Post
    The main sub is crossed over at 80 Hz and digs below 20 Hz. The new sub is rated down to 35 Hz and is also crossed over at around 80 Hz. I haven't played around with the crossover settings yet. If you have any suggestions, let me know.
    HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
    "God grooves with tubes."
  3. #33
    GV#27
    Guest
    Default
    So other than the last 15hz both subs are covering the same range.If you like the results then don't change a thing other then maybe experimenting with the phase controls.If you wanted the small one to work as a mid bass you would need to reduce its bass output below 50 hz ,either with a hi pass filter or by plugging the port if its a ported design.At the same time you would lower the other subs crossover to about 50 hz.Some tweaking of levels and phase would be required.
  4. #34
    Join Date
    Sep 2003
    Posts
    8,170
    Default
    Today I switched out the driver in my new sub as originally planned with an Ascendant Audio 10" woofer. Geez -- what a diference it makes! More heart pounding terror will be unleashed to all those who dare to hear my HT system from this moment onward.
  5. #35
    GV#27
    Guest
    Default
    I finally finished the little fella.I tried about 5 different stains and didn't like the colour of any and they tended to look abit streaky.In the end I decided just to keep it a natural blonde and Im glad I did as I like the results.
    It's still a couple of shades lighter than the flooring but it matches in well IMO.
    I chickened out on doing the hi gloss finish,opting instead for 5 coats of semi gloss lacquer.
    As the pic shows the control box is not quite completed but I hope by weeks end to have it up and running.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	35387   Click image for larger version
ID:	35388   Click image for larger version
ID:	35389   Click image for larger version
ID:	35390   Click image for larger version
  6. #36
    Member Sales Rating: (4)
    Join Date
    Jun 2002
    Location
    Illinois
    Posts
    1,516
    Default
    Looks fantastic! Great job.
    This might inspire me to re-laminate the side panels of my Lsi's and my subs in some exotic veneer. Now finding the time, is another matter........lol
    Enjoy the new beast.
  7. #37
    Member Sales Rating: (9)
    Join Date
    Sep 2006
    Location
    Baltimore
    Posts
    2,477
    Default
    I like the semi-gloss finish, it looks great.
    I've heard that to get birch to take stain without streaking you should use a wood pre-conditioner. I tried it on a set of birch shelves I made for my albums. It did help, at least compared to the sample I did without using the conditioner, but it still had some blotchiness to it.
    Wris****ch--->Crisco
  8. #38
    GV#27
    Guest
    Default
    Thanks guys.
    I was thinking of trying wood conditioner it may have helped,but none of the stain colours were close anyway.
  9. #39
    Member Sales Rating: (0)
    Join Date
    Oct 2007
    Location
    Dallas, TX
    Posts
    245
    Default
    so where do we place an order???
    looks good, have you had the 'look with your eyes not your fingers' discussion with the kids?
    Abel
  10. #40
    Member Sales Rating: (1)
    Join Date
    Jan 2008
    Posts
    1,180
    Default
    The wood conditioner is overrated. It helped when I was working with Birch last. In my case, this is russian birch plywood.
    I used a stronger than normal flash to overexpose the grain. In reality, these speakers are of an amber colour and can go almost red in low light to a light honey in sunlight.
    You can see there is still some blotchiness to the finish. The topcoat is wax, buffed in. So it's just pre-conditioner, stain, then wax. The stain I used reversed the contrast of the grain in strong light conditions. Knots stayed dark while light streaks became dark and dark went light.
    p.s. I had some wood leftover from making these speakers that I made into a pair of nesting tables for a friend. I did the same as you, left it natural and clearcoated. The natural color of birch is nice and smooth, albeit a bit light.
  11. #41
    GV#27
    Guest
    Default
    Quote Originally Posted by tx_polkhead View Post
    Yep,when they were very young I gave them an upclose demo of what Mr Vice does to little fingers that push in dust caps on speakers.:D;)It seems to have worked on them,but not so convincingly on the cats.
    Quote Originally Posted by ShinAce View Post
    I figured staying natural was the safest bet as I didn't want to risk the blotchies or poor colour choice.
    I quite like the natural/semi gloss combo and plan to finish another project the same.
    Cool lookin speakers,looks like Dayton woof/tweet?
  12. #42
    Join Date
    Jan 2008
    Posts
    1,180
    Default
    Actually, it's a Pioneer woofer and an Audax tweet(now discontinued).
    290-023 and 276-152
    Makes a killer good bookshelf, but a good mid bass or sub module would really help it along, ;)
  13. #43
    GV#27
    Guest
    Default
    After a few weeks of use and some tweaking to getting it dialed in, I have to say it does make a small but worthwhile improvement.I just watched IronMan which is very entertaining and very bass intensive.The MBM added noticeably to the impact and punch of the many explosive effects.
    While I expected the unit to help with movie soundtracks I was surprised that it was benificially to the enjoyment of 5.1 music soundtracks as well.
    I like watching the concerts shown sundays on HD Net as I find the PQ and the DD5.1 SQ to be very good.Recent broadcasts of MOE and Rusted Root while not exactly my cup of tea musically the SQ was so good it held my attention.
    With these 2 concerts the bass guitar was carried in the LFE channel and its here that the MBM really showed its worth.
    The reproduction of the bass notes were very tight and tuneful and completely lacking overhang and boominess.This is the best $2.75 driver I've ever purchased.:)(not including the $20+ for shipping)
    As well on all material played through it it never ran into over excursion problem's and the 100 watt amp's clipping indicators never flashed as long as it's level was set correctly.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 26
    Last Post: 12-23-2010, 02:20 PM
  2. Hsu's Mid-Bass Module
    By Early B. in forum Subwoofer Hookup & Bass Management
    Last Post: 08-03-2007, 03:01 PM
  3. Polk/Momo Remote Bass Gain Module
    By lollypop7 in forum Car Audio & Electronics
    Last Post: 03-08-2006, 01:27 PM
  4. an experimental fusion of hip-hop and jazz.
    By juice21 in forum Music & Movies
    Last Post: 06-06-2002, 09:03 AM
  5. Mobile SDA module
    By sabasigh in forum Flea Market
    Last Post: 08-29-2001, 10:31 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
