Does anyone know of speaker wire (either monster or MIT) that comes terminated wit pin connections - that will fit into spring clips?
Im having no luck finding anything - and I dont trust myself taking apart an expensive cable..
Thanks.
Sean
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreDoes anyone know of speaker wire (either monster or MIT) that comes terminated wit pin connections - that will fit into spring clips?
Thanks.
Sean
ratshack....;)
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
No! Whenever I look at manufacturer terminated speaker wires I look for pin options. Most of my speakers and some of my amps use those dang clip connectors. This may be part of my enthusiasm for bare-wire conections. Clip it off and go bare wire. You'll get more surface area contact and skip a connection.
BTW: My Altecs have funky clip connectors that will barely accept pins. 14awg bare wire is too big. I hate these terminals.
Just out of curiosity. What are you trying to connect?
Make it Funky! :)
Just preperation for something - Russ knows what Im refering to. ;)
I have thought about simply replacing the spring terminals just to make life easier...
Rat shack carries some skinny binding posts....
I think that Monster makes some w/attached pins. 2 Pairs of original in various lengths, & sets of 10 for the "5" in 5.1.
Crutchfield, the Monster site, Circuit City may have info on this, if I am remembering it correctly.
Acoustic Research, available at Sears & Best Buy has some 16 gauge w/attached pins, too, I believe.
There are currently 1 users browsing this thread. (0 members and 1 guests)
