Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 39
  1. #1
    Member Sales Rating: (11)
    Join Date
    Apr 2004
    Location
    Chicagoland
    Posts
    2,280
    Default Oil pressure light on after oil change
    I changed my oil today in my 2.7L Hyundai Santa Fe and my oil indicator came on immediately afterwards. I have not driven the car - the engine was on for just about 2 minutes following the oil change. I used a genuine Hyundai oil filter and Mobil 1. What could be wrong? I''m thinking I might have overfilled it as the dipstick is wet way above the indicator. Could overfilling cause a problem? Advice?
  2. #2
    Member Sales Rating: (4)
    Join Date
    Feb 2007
    Posts
    6,972
    Default
    Quote Originally Posted by anonymouse View Post
    Yes! Overfilling can cause problems just as underfilling.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  3. #3
    Join Date
    Apr 2004
    Location
    Chicagoland
    Posts
    2,280
    Default
    I'm presuming that draining a little oil by loosening the oil filer should help?
  4. #4
    Member Sales Rating: (16)
    Join Date
    Jan 2007
    Location
    eastern Pa
    Posts
    536
    Default
    If its overfull you may need to open the drain plug and get
    a hand full of oil trying to thread it back in. First check for
    a leak at the filter.
    jerry
    Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
    Basement-Audiosource pre/tuner,GFA-545,Onkyo
    DX-1400 and RTI10s
    Garage-GTP-450,onkyo M-282 and R50s with RTi55
    drivers and X-overs.
    My baby 18' V-king Mod VP with a merc 2.4 BP.
    KTM 620 Supermoto
  5. #5
    Join Date
    Sep 2008
    Location
    End of The Sound Wave
    Posts
    1,046
    Default
    How many quarts did ya put in it?
    Don't drive it over full not good for it.
    Probably smoke like hell.
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  6. #6
    Member Sales Rating: (6)
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    But overfilling as stated not good if way over like more then a quart or so. I don't see why this should cause the oil pressure light to stay on. Was the correct oil filter used? Is there oil leaking under engine, a bad leak?
    Mobil one being a bit thin is know to cause trouble with oil pressure at idle, check with some oil forums to see. Does the engine sound bad knocking or anything during the 2 Min's of running? If not I'm wonder if bringing up idle clears the oil light? If so Mobil One is a bit thin for that engine, so if you like a synthetic oil and I assume you put 0W-30 oil in I would drain a quart low to add a thicker oil to mix. A 20W-40 may work if this is true.
    For the record I would drive a car with the oil light on at idle without doing something above. Good luck.
    BTW is this you first time you change your oil? Is this the first time you changed with Mobil One? Did you change the Oil weight? Are you using a different brand of oil filter? What caused you to overfill?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  7. #7
    Member Sales Rating: (5)
    Join Date
    Jul 2008
    Location
    SoDak
    Posts
    211
    Default
    Overfilling causes the crankshaft to splash extra oil up onto the cylinder walls, overloading the rings thus glazing the cylider walls creating a loss of compression = BAD... the cure, don't overfill.
    Are you sure it was 2 min. before the light went off? Sometimes it takes 20-30 seconds for the oil light to go off. Like Disneyjoe says, a lot of facts are missing... how many miles are on the motor? What weight of oil used? Is the filter leaking? In order to drain some oil, I wouldn't take the oil filter off unless it's leaking. Loosen the plug, man are you gonna get slicked up!
    Thanks, Jeff...
  8. #8
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    For the record I wouldn't drive a car with the oil light on at idle without doing something above. Good luck.
    To correct what I was thinking above, sorry I wasn't clear before.
    Quote Originally Posted by disneyjoe7 View Post
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  9. #9
    Join Date
    Jul 2008
    Location
    SoDak
    Posts
    211
    Default
    Another thing, the dipstick... to correctly read the oil level you must first shut off the engine, pull the dipstick out and wipe clean with a rag or something the Ex bought you. Then reinsert the dipstick fully, pull back out and read. In between full or add is fine... a little above full, maybe ok... a lot above full, RED FLAG! If there is no oil on the dipstick, get out your checkbook, you are gonna need it.
    Thanks, Jeff...
  10. #10
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    Quote Originally Posted by Jeff Beaird View Post
    Another thing, If there is no oil on the dipstick, get out your checkbook, you are gonna need it.
    LOL :D:D:D
    Is that a DIY major F&*$ up ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  11. #11
    Join Date
    Jul 2007
    Posts
    2,849
    Default
    One guy at work a good while back attempted ( Yes I say attempted :) ) to change his own oil on his Honda Nighthawk S motorcycle. He figured they took 5 quarts just like his car
    When oil started pouring out before he got the 5 full quarts in he didnt know why ? He started it ...it ran for a few seconds then major blue smoke out of the pipes and then died. Wouldnt re-start.
    I went over to look at it....the crankcase breather had sucked pure liquid oil into the airbox.....I had to remove the airbox to clean it...replace the air filter...and drain the CV carb float bowls. And before starting it again remove a couple quarts from the crankcase so the oil was where it should have been.
    I told him to take it to the dealer for oil changes like he does with his cars....he said he just wanted to be able to tell me that he changed his own bikes oil...I told him don't try and impress me anymore
    The first rule of Fight Club is you don't talk about Fight Club
  12. #12
    Member Sales Rating: (28)
    Join Date
    Mar 2005
    Location
    Powder Springs, GA
    Posts
    4,890
    Default
    The problem I had recently was due to underfilling. My Passat takes about 6 quarts to fill up. In the past, I've always bought 1 5quart container and 1-single quart container and its worked fine.
    Last time I bought from Advanced Autoparts, I grabbed the same containers I always do. Drained, changed the filter, etc. Put in the entire 5 q container plus the extra one. Start up, turn off, check dipstick. Its very low, not even in range. What? So I add some more from another container. Still low. I put almost another half quart and still low. About this time I'm confused. I go and check the container. Its a 1 gallon (4 q) container instead of a 5 quart container! Effing companies trying to pull the fast one by downsizing containers and keeping the price the same! BTW, last time I was in WalMart, they still carried the 5 quart containers and the price was still lower than the 4 quart container from Advanced. I know where I'm buying my oil change stuff from in the future.
    So, just beware of whether you are using a 4 quart or 5 quart container (if you buy those like I do)
  13. #13
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    Any update Anonymouse?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  14. #14
    Member Sales Rating: (43)
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,924
    Default
    Quote Originally Posted by billbillw View Post
    Dude I had a Passat.
    Don't use Dino oil at all. Mine failed, and cost over $1500 to replace the pickup tube after running dino oil in it:(
    Ben
  15. #15
    Join Date
    Mar 2005
    Location
    Powder Springs, GA
    Posts
    4,890
    Default
    Quote Originally Posted by ben62670 View Post
    ? You talking about non-synthetic oil?
    I've been using the same oil for the last 122,000 miles with no problem. Castrol GTX. Kinda late to switch to synthetic now.
  16. #16
    Join Date
    Jul 2008
    Location
    SoDak
    Posts
    211
    Default
    It's NEVER too late to switch to synthetic oils... just don't try to "break in" a new motor on synthetics. Not recommended!
    Thanks, Jeff...
  17. #17
    Member Sales Rating: (1)
    Join Date
    Mar 2006
    Posts
    259
    Default
    Huh?
    Corvette
    Viper (I own one) :)
    AMG Mercedes
    Saturn Sky Redline
    EVERY 2008 Cadillac
    Other cars listed here ---> http://www.mobiloil.com/USA-English/...rs_Choice.aspx
    all come factory filled with Mobil 1 Synthetic as the motor oil in the crankcase.
  18. #18
    Join Date
    Feb 2004
    Location
    L.A., CA
    Posts
    355
    Default
    Quote Originally Posted by XJRGUY View Post
    Huh?
    Corvette
    AMG Mercedes
    Saturn Sky Redline
    EVERY 2008 Cadillac
    Some friction is necessary during the initial break-in period for a new engine so the moving parts can mate and the rings seat properly in the cylinders. Many of the synthetics are too "slick" to allow this mating to happen. So if you rebuild an engine (or just install new lifters, cam, etc.) it's best to break in the new engine/parts with regular oil and after a couple oil changes, move to synthetic.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  19. #19
    Join Date
    Mar 2006
    Posts
    259
    Default
    Quote Originally Posted by tugboat View Post
    Maybe with older technology, but with current engine design this is no longer the case.
    Mobil agrees http://www.mobiloil.com/USA-English/...ics/Myths.aspx
    Castrol agrees http://www.castrol.com/castrol/gener...tentId=7007980
    Royal Purple agrees http://www.carcraft.com/techarticles...tic_myths.html
    Now, I can agree with one reason NOT to use synthetic oil during a break in is that with the frequency of changes you will be wasting money changing the syn. oil out during a new engine break in period.
    Other than that, syn oil is fine during break in, according to facts and tests by OEM's, the oil companies and engine builders.
  20. #20
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    I sure that an engine came with Synthetic oil from a factory, comes with a break oil mix also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  21. #21
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    20,711
    Default
    Huh! Many manufacturer's including all European cars now use Synthetic oil right out of the factory. This nothing but one of those internet myths that keeps getting passed on and on and on.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Adcom GFP750/Dared SL2000A; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  22. #22
    Join Date
    Mar 2006
    Posts
    259
    Default
    Unless you have a credible source/citation claiming that syn. factory fill is mixed with break-in oil I would probably disagree.
  23. #23
    Join Date
    Feb 2002
    Location
    Orlando, Florida
    Posts
    11,349
    Default
    Don't believe everything you read. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  24. #24
    Join Date
    Mar 2006
    Posts
    259
    Default
    This is true, but facts from credible sources are better than anecdotes....
    :D
  25. #25
    Join Date
    Jul 2008
    Location
    SoDak
    Posts
    211
    Default
    +1 Thanks tugboat...
    On a new motor I change oil and filter at 50 mi. then again at 500 mi. After that every 3,000 mi.
    Thanks, Jeff...
  26. #26
    Join Date
    Aug 2007
    Location
    L.A.
    Posts
    3,178
    Default
    No European cars are designed for an oil change every 3,000 mi, even after break in. Usually more like 10,000 or more, and not always with synthetic oil either (for the four cylinder models). I think this is mostly because they use better filters, but I am no expert. All I do know is that even the dealers will not push for more frequent changes in Europe.
    It is also common for engines to be broken in "on the bench" before delivery. XJRGUY may be correct in assuming these engines can use synthetic oil normally during break in, as witnessed by a fellow Polkie's new Jetta, which requires its first oil change at 10,000 miles, not before. It's a different approach. Europeans are paranoid about dealer visits (the fewer the better), and there is no popular alternative like Jiffy Lube etc. Maybe that explains it to some extent. Mythology may be filling in the blanks.
  27. #27
    Join Date
    Jul 2008
    Location
    SoDak
    Posts
    211
    Default
    Quote Originally Posted by Kex View Post
    If you are saying oil filters in europe are better..? Which means they catch more particles of carbon, dirt, aluminum, steel, etc. wouldn't they clog sooner meaning you should change them sooner? I think you got it backwards, filters in Europe are worse
    Paranoid or not, an oil change after the first 10,000 mi. AND the motor has a 30,000 mi. warranty... UUMMMmmmmmm....??? Do you see something wrong there?
    No argument PLEASE! Just my two cents...
    Thanks, Jeff...
  28. #28
    Join Date
    Feb 2004
    Location
    L.A., CA
    Posts
    355
    Default
    Quote Originally Posted by heiney9 View Post
    Not true. You think they come directly from the factory with the oil used to break in the engine? Try again.
    The oil used to break in the engine before you purchase it is drained because it contains necessary additives for the break-in process and any metal particles from the break-in. It is then replaced with standard synthetic oil.
    Of course what do I know. I've only built a few engines in my days and have experience with synthetics in all areas (engine, tranny, PS...). Or maybe my brother (Chrysler Master Mechanic) was told incorrectly by Chrysler about the use of synthetics in rebuilds, etc.
    One of the leading manufactures of synthetic racing oil (Redline) was around long before the major brands and they always stated that the engine break-in was not to be done with synthetics. But of course, they must have started the internet rumor (well before the internet was in use by non-military).
  29. #29
    Join Date
    Feb 2004
    Location
    L.A., CA
    Posts
    355
    Default
    I knew a guy that tried to break in his newly built stroker with Redline 30w and the rings didn't seat. He had to drain the synth and add standard oil and after about 2hrs, the rings were properly seated. I told him he was stupid for trying anyway. The cost of synth from Redline is about 8 bucks a quart and he'd need to toss two crank cases full of the stuff before he could leave it in knowing all the crap from break-in was gone.
    In my old Trans-Am I built a bored ands stroked 350 and ran Redline 30w. I changed the filter and added a quart every 5000 miles and total oil change every 15000. The engine had over 45K on it when I sold it and she still cranked out over 400hp.
  30. #30
    Join Date
    Feb 2004
    Location
    L.A., CA
    Posts
    355
    Default
    I can't say for fact on all those cars listed, but the oil you get when you buy the car is not the oil used to break-in the engine. There isn't an engine out there that is just slapped together, dropped into the car and put on the lot never having been properly tested and broken in. That is done where the engine is made and the oil used during the break-in is discarded after the process is over. So of course in those cars you can use synth for YOUR first oil change (note this is not the ENGINE's first oil change).
    I dare anyone here to build an engine and run synth for the first fire-up and break-in. Then post your results about ring seating and crank bearings.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. A Review Of Four Digital Stylus Pressure Gauges
    By DarqueKnight in forum Electronics
    Last Post: 03-19-2010, 07:10 AM
  2. To Much Pressure,took Plunge
    By shahmichael@com in forum Speakers
    Last Post: 07-18-2007, 08:56 AM
  3. Air Pressure issues
    By howie777 in forum Car Audio & Electronics
    Last Post: 02-23-2007, 01:37 PM
  4. Radio Shack sound pressure level meter instructions
    By ntg in forum Basic Hookup/Wiring Questions
    Last Post: 09-30-2006, 08:22 AM
  5. Tire Pressure makes a huge difference
    By mantis in forum The Clubhouse
    Last Post: 07-23-2005, 05:54 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
