Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 38 of 38
Thread: Bass blockers
  1. #31
    Member Sales Rating: (0)
    Join Date
    Sep 2008
    Posts
    17
    Default
    Would sealing the front doors do any good if I don't have any speakers in them? I was only considering adding speakers in the rear doors because I don't have any place to put them in the front doors. And yes, the bass blockers ARE blocking too much of the bass IMO, but they are better than what I had and will suffice until I get a decent head unit. Once that better head unit is installed, the bass blockers will come out.
  2. #32
    Member Sales Rating: (1)
    Join Date
    Mar 2004
    Location
    College Station, TX
    Posts
    7,122
    Default
    Is a set of q-logic kick panels out of the question?
    Deadening doors with no speakers in it really only helps with road noise.
    -Cody
  3. #33
    Join Date
    Sep 2008
    Posts
    17
    Default
    I haven't found any made for a 1996 Buick Century wagon.
  4. #34
    Join Date
    Aug 2008
    Posts
    183
    Default
    I assumed that the front 4x6's were in the doors.
    If not, then it would be pointless to seal the front doors unless you're worried about road noise.
    It would be helpful to get a head unit with built in crossovers.
    But, still, I would recommend just getting a 4 channel amp and using its crossover. Not only will it solve the bass problem, but you'll end up with a lot more clean power to work with.
    From my experiences, head unit power just isn't enough to make most after market speakers sound right.
    Also, as far as I know Q Logic kickpanels work for 6" round speakers only.
  5. #35
    Join Date
    Sep 2008
    Posts
    17
    Default
    If I can find the room, then perhaps I'd add an amp w/crossover, I know that would be the ideal choice.
    If I did go with speakers in the rear doors, how would I wire all six of those speakers?
  6. #36
    Join Date
    Aug 2008
    Posts
    183
    Default
    Quote Originally Posted by JetMech View Post
    That really depends.
    Off head unit power alone, it's not really recommended unless you wire two pairs of speakers together in a series wiring. Doing that will significantly reduce how much power the head unit is sending to each pair, so again I wouldn't recommend it.
    Another way to run 3 pairs of speakers is to run 1 pair off the head unit and the other two with a 4 channel amp.
    Or, if you made sure you got a head unit with 4 sets of pre-outs, you could run a 6 channel amp. Most head units have 3 sets of pre-outs , but the 3rd set is usually for the subwoofer amp, and I'm not sure if it will play full range frequencies.
  7. #37
    Join Date
    Sep 2008
    Posts
    17
    Default
    So if in the radio's specs it said:
    Preamp outputs....6-channel
    That would be fine, right?
    It also has Sub preamp outputs.
    The head unit is a Pioneer DEH-P77DH, which is one of few that fit my car.
  8. #38
    Join Date
    Sep 2008
    Posts
    17
    Default
    Also, I could use two separate amps instead of one 6-channel amp, right?
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Bass blockers with DB series drivers
    By Andy_M in forum Car Audio & Electronics
    Last Post: 07-11-2007, 04:12 PM
  2. bass blockers for my db570s?
    By nadams in forum Car Audio & Electronics
    Last Post: 03-07-2006, 04:51 PM
  3. detectors//blockers :)
    By knils in forum Car Audio & Electronics
    Last Post: 08-30-2003, 09:49 AM
  4. bass blockers
    By soccerpharm in forum Car Audio & Electronics
    Last Post: 05-05-2003, 12:04 AM
  5. bass blockers
    By soccerpharm in forum Basic Hookup/Wiring Questions
    Last Post: 04-27-2003, 02:09 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
