Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Member Sales Rating: (11)
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,830
    Smile Long awaited new pre amp from Outlaw audio
    Outlaw just announced the specs for their new pre amp.. Outlaw Audio model 997
    It's not available yet.. you just have to wait.
    Main Features
    • HDMI 1.3 with Deep color support
    • Lossless Audio: Dolby TruHD; DTS Master Audio
    • Dolby Digital EX, Dolby Pro Logic IIx fully adjustable, Dolby Virtual Speaker, Dolby Headphone Layers 1, 2, 3
    • DTS-ES Discrete and Matrix, DTS-96/24, DTS NEO-6
    • Analog to Digital Video Transcoding
    • Silicon Optix Reon scales all video up to 1080P
    • XM Radio "Connect and Play" w/ Neural Surround
    • Bi-Directional USB/RS-232
    • Upgradeable Firmware
    • Multi-room/Multi-Source Capable
    • Advanced GUI On-Screen Display
    • 7.1 Multi-channel Analog Input
    • OSD over HDMI
    • A/V LipSync Delay per Input (0-200mS)
    Audio/Video Features
    • Dual TI 32-bit DSP processors
    • Quadruple Crossover
    • Surround Preout Reassignement (Bi-amp)
    • 4 HDMI inputs, 1 Output
    • Theater Compensation
    • Balanced Audio Outputs
    Trinnov Optimizer
    • Includes 4 Microphone Capsule Acoustic Probe
    • FIR and IIR filters to flatten speaker response
    • Loudspeaker (RE)Mapping
    • Supports ITU Surround Music and SMTPE Cinema Standards
    • Before/After Curves availble to USB output for Analysis
    Additional Features
    • High performance tuner
    • Direct access station tuning via remote control
    • 30 Station Presets
    • Room 2 A/V Output with fixed/variable audio level, S-Video and coaxial digital
    • IR control with 2 inputs and 1 output
    • Dedicated Room 2 Remote
    • Front Panel A/V and Mike Input
    • Video Input Renaming
    • Channel Level Memory
    • 12-volt Trigger
    • Aluminum Front Panel
    Trinnov Optimizer
    Model 997 FAQ
    Coming Soon
    Preliminary Specifications:
    • Input Sensitivity/Impedance: 200mV @47k ohms
    • Maximum Output: 9 V
    • Volume Range
    Main: -76dB to +10.0 dB (1dB resolution)
    • Bass Management
    Low-Pass Slope Crossover Frequency (Small Speaker Setting) (Adjustable 40/60/80/100/120200Hz): 12 dB/octave (2nd order)
    High Pass Slope (Subwoofer) 24 dB/octave (4th order): 40-120Hz as above
    • Tone Control
    Bass Center Frequency/Range: 100Hz / ± 10dB
    Treble Center Frequency/Range: 10KHz / ± 10db
    • Channel Separation (at 1kHz): 87dB
    • Frequency Response
    Line: 10 Hz to 100 kHz +/- 1dB
    • S/N Ratio (ref. 2.3Vrms): >105dB
    Video Section
    Input Sensitivity/Impedance: 1V p-p/75 Ohms
    Output Impedance:1V p-p/75 Ohms
    Frequency Response: Composite/S Video: 10Hz-10MHz Component Video: DC-100MHz
    S/N Ratio: 50dB
    Digital Audio
    All digital audio inputs and outputs are to S/PDIF electrical (75 ohms, 0.5 Vp-p), S/PDIF optical (Toslink), standards as appropriate.
    Coax: 2 In
    Optical: 5 In
    Processor: Dual TI 32 bit
    FM Tuner Section
    Usable Sensitivity, THD 3% S/N 30dB: 17.2 dBf
    50 dB quieting sensitivity
    Mono: 25.2dBf
    Stereo: 43.2 dBf
    S/N Ratio, 60dBf
    Mono: 72dB
    Stereo: 68dB
    THD 65 dBf
    Mono: 0.2%
    Stereo: 0.3%
    Stereo Separation: 40dB typ.
    Capture Ratio: 3.0 dB
    IF rejection ratio: 120 dB
    AM Tuner Section
    Usable Sensitivity: 500uV/m
    S/N: 40dB
    Selectivity: 30 dB
    Image rejection: 33 dB
    General
    Supply Voltage: 120V, 60Hz only
    Power Consumption: 50W
    Dimensions
    Width: 17.38 inches
    Height: 7.75 inches
    Depth: 17.75 inches
    Trigger Outputs: Sequential Delay 50 mA @ 12 VDC
  2. #2
    Member Sales Rating: (13)
    Join Date
    Mar 2004
    Location
    Bedford, TX
    Posts
    4,502
    Default
    Intro price of ~$1300 IIRC. If it looks any better than their old models, I'll give it a consideration.
  3. #3
    Join Date
    Jul 2001
    Location
    Spokane, Washington
    Posts
    15,830
    Default
    ok.. but I hope soundwise is more important to you than looks are. A lot of their gear isn't going to win any beauty contests for sure. but value is what and sound are what most people are looking for. i know I am. ;)
  4. #4
    Join Date
    Mar 2004
    Location
    Bedford, TX
    Posts
    4,502
    Default
    I'll shell out a few more bucks for the looks and sound. If the piece was behind closed doors, I wouldn't care.
    I just looked up their 970, it actually isn't as bad as remembered Outlaw gear to look like (NADish). I'll definitely put this on my list to shop when the time comes (soon).
  5. #5
    Member Sales Rating: (0)
    Join Date
    Jun 2005
    Posts
    2,381
    Default
    I think we now have two threads on this...
    http://www.polkaudio.com/forums/showthread.php?t=72642
    ...started back on Monday...just a few threads down from this one...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 5
    Last Post: 03-24-2006, 01:38 PM
  2. so long outlaw 990.....
    By sickicw in forum Electronics
    Last Post: 01-31-2006, 07:01 PM
  3. Outlaw 1070 Review (Long)
    By Polkitup2 in forum Electronics
    Last Post: 10-01-2005, 09:33 PM
  4. Long Awaited Black Lab Photos!
    By VR3 in forum Speakers
    Last Post: 11-15-2004, 04:08 PM
  5. Long awaited pics of latest HT revamp!
    By scottvamp in forum Electronics
    Last Post: 06-08-2004, 07:22 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
