Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 11 of 11
Thread: Audyssey
  1. #1
    Member Sales Rating: (7)
    Join Date
    Dec 2001
    Location
    Kentucky
    Posts
    1,137
    Default Audyssey
    Has anyone turned off there Audyssey on reciever-pre-pro & used the old way with spl meter? Ive done what the instructions said 8 different positions & I dont like the way it sounds,it even has my sub at 28 ft away & thats not correct. thanks
    My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
  2. #2
    Member Sales Rating: (28)
    Join Date
    Mar 2005
    Location
    Powder Springs, GA
    Posts
    5,225
    Default
    Always go back and manually set the distance, crossover points, and SPL levels after running Audyssey, especially the sub level.
    I encourage you to try this and keep using Audyssey. The equalization that it applies is really where the benefit is.
  3. #3
    Member Sales Rating: (11)
    Join Date
    Dec 2007
    Location
    Austin TX
    Posts
    887
    Default
    just wondering why you want to turn off Audyssey?
    it does more than level matching...
    http://www.audyssey.com/technology/graphs/graph1.html
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  4. #4
    Member Sales Rating: (6)
    Join Date
    May 2005
    Posts
    4,373
    Default
    According to a thread over at AVS, there is a poster there who works for Audyssey, since Ausyssey takes time domain into consideration, the distances it sets are correct.
    Personally, I never liked what Audyssey did to the sound with my 885, I left it off.
  5. #5
    Join Date
    Dec 2001
    Location
    Kentucky
    Posts
    1,137
    Default
  6. #6
    Member Sales Rating: (25)
    Join Date
    Feb 2008
    Location
    West Chester, PA
    Posts
    4,301
    Default
    I upgraded the firmware on my 805 the other day so I had to start from scratch (now I can't find that damn mic), anyway I also have the SMS-1 so I started it first and I swear that with the Audessey set to off its ignoring my crossover settings based on what the SMS is showing me....
    ____________________
    2-chnl : Pio DV-46AV (SACD), Dodd ELP, Emotiva XPA-1s, XPA-2, Odyssey Khartago, LSi9, SDA-SRS 2 , SB Duet, MSB & Monarchy DACs, Yamaha PX3 TT, SAE Tuner...
    Pool: Atrium 60's/45's
  7. #7
    Member Sales Rating: (1)
    Join Date
    Jul 2001
    Location
    Mobile, AL
    Posts
    3,268
    Default
    Audyssey detects acoustic distance... However, if you're getting a huge discrepancy in subwoofer distance, you may have an acoustic issue causing it. For instance, my first run through detected my subwoofer 5+ feet off from physical distance. Moved it three inches away from the wall and on the next run it detected at its actual distance.
    Contrary to what billbillw says, once you fix any acoustic issues in the room, you shouldn't need to change the distance/delays it comes up with (though you can spot-check cross-speaker imaging if you have DVE, since it has between-speaker tones that make setting distance/delay easy). You can set more reasonable crossover points (because some implementations, especially Onkyo detect any speaker that goes below 80Hz as full range), but don't ever set a speaker to a lower crossover than what was detected because Audyssey has only equalized down to that point.
    I could go on and on about the proper method of calibrating with Audyssey, but I'd just be repeating what I wrote for the TX-SR705 FAQ at AVS.
    If you have any specific questions after reading that, let me know.
  8. #8
    Join Date
    Dec 2003
    Location
    3 sTars & Da SuN...
    Posts
    1,060
    Default
    HOW old is this technology? Are all AVR have this feature?....Sorry for my ignorance..
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  9. #9
    Join Date
    Mar 2005
    Location
    Powder Springs, GA
    Posts
    5,225
    Default
    The concept has been around for at least 5 years. The general term is "automatic room setup". Audyssey is a brand name for one version of the technology, kinda like Dolby or Faroudja. No, its not on all receivers. You must get a step or two above the entry level to the this feature. Also, not all manufacturers use Audyssey. Yamaha, HK, and Sony have their own varieties. Denon, Marantz, NAD, and Onkyo use Audyssey.
  10. #10
    Join Date
    Dec 2003
    Location
    3 sTars & Da SuN...
    Posts
    1,060
    Cool Thank you
    Quote Originally Posted by billbillw View Post
    Your wisdom is greatly appreciated.
    MY assumptions were right! I am still SPL meter loyal:D:D
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  11. #11
    Member Sales Rating: (10)
    Join Date
    Jun 2007
    Location
    Cape Cod, Massachusetts
    Posts
    1,286
    Default
    Quote Originally Posted by doggie750 View Post
    Audyssey and other automatic room setup variations do more than just adjust the SPL of each channel. They adjust size and distance (delay), as well as per-channel equalization. Even with Audyssey it's still useful to use an SPL meter to make fine adjustments and double-check the auto-configuration, especially for speaker size.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Audyssey MultEq and SDA's?
    By civilian in forum Vintage Speakers
    Last Post: 07-10-2008, 04:45 PM
  2. 2 ch audio: audyssey calibration useful?
    By SlowcarIX in forum 2 Channel Audio
    Last Post: 06-10-2008, 03:40 PM
  3. RM6880-Onkyo 605 Audyssey Setup
    By mlc1971 in forum Basic Hookup/Wiring Questions
    Last Post: 01-10-2008, 04:50 PM
  4. LSiC and Denon/Audyssey
    By tlainhart in forum Speakers
    Last Post: 10-29-2006, 07:51 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
