Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 91 to 120 of 140
  1. #91
    Banned
    Member Sales Rating: (14)
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    ^^^^ right on the money. I got a "mo' better" amp and use jumpers in lieu of polyswitchs (I've not tried the resistor tweak yet) and have no fear at all of turning my volume dial past 3 o'clock when I'm really rockin'.
  2. #92
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,733
    Default
    Quote Originally Posted by F1nut View Post
    Buy a mo' better amp.
    Correct!
  3. #93
    Member Sales Rating: (25)
    Join Date
    Feb 2008
    Location
    West Chester, PA
    Posts
    4,301
    Default
    Quote Originally Posted by heiney9 View Post
    It does make sense but the length of wire would dramatically increase the time before the poly breaks the circuit. That distance of wire will dissipate the heat generated when overdriving your tweets. Heat is what causes the ploy to open...
    That doesn't make sense. The heat of an over current situation is generated by the current passing through the 'circuit breaker' (or poly, fuse, etc). The heat isn't generated at the circuit board with the potential to be dissipated by the extra 24" or so of wire located at the binding post cup.
    Older model Monitors were protected with a fuse that was located at the binding post cup (as opposed to a resettable polyswitch) and they worked as designed, the heat wasn't dissipated en-route. Apparently the polyswitch (or lack thereof) was an improved design over the external fuse.
    The concept of using a resettable circuit breaker is essentially the same as the older design of using a fuse. I recall it being discussed before, but it was also including talk of the option to replace various inline with the tweeter resistor values to play/experiment with to get a different sound from the tweeters, esp after removing the polyswitch. Apparently some preferred a 'hotter/brighter' highs where others might prefer a more laid back sound. I think this is much like the selector knobs on the back of some of the older vintage speakers where you could tailor the sound curve.
    In the end though, because wire has resistance and capacitance, as well as the additional connections, the less extra stuff the better. I can't say if it will or won't affect the sound at these short lengths-I guess that depends on how sensitive your ears are.
  4. #94
    Member Sales Rating: (0)
    Join Date
    Jul 2010
    Location
    South Denver
    Posts
    649
    Default
    Quote Originally Posted by mmadden28 View Post
    So, if indeed the heat is generated internal to the polyswitch, then the extra wire wouldn't make any difference in the tripping time. The only drawback would be the additional connection, etc, as mmadden28 pointed out. It still might be too much trouble to mess around with though. I think I'll just take the advice of getting a "mo' better amp".
  5. #95
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,030
    Default
    I have been running a jumper in my 1.2tl's since day one, Yesterday I took out the jumper and put in a .5ohm resistor I can say I like it much better.
    Hot Rodded SDA 1.2TL's, SDA 1C's, SDA CRS+'s...
    Powered By Wyred 4 Sound, STP-SE, SX-1000...
    MIT-Shotgun's ...
  6. #96
    Member Sales Rating: (3)
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,175
    Default
    What improvements did you hear with the 0.5 ohm resistor?
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    __________________
    "Knowledge, without understanding, is a path to failure."~DK
  7. #97
    Join Date
    Dec 2006
    Location
    Annville, PA
    Posts
    246
    Default
    I ran mine with a .5 ohm Mills for several months and thought they sounded veiled. Popping in a .2 ohm Mills instead made female vocals and cymbals come alive in my case.
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  8. #98
    Member Sales Rating: (8)
    Join Date
    Sep 2006
    Location
    Towson, Maryland
    Posts
    2,557
    Default
    I run a .22 resistor in mine. Works for me. The jumper was to bright and unbalanced. .5 was to veiled and did not sound right to me.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  9. #99
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,030
    Default
    putting in the resistor smoothed out the sound and I guess I never realized how bright it was till I put in the resistor.
    Thanks for the info above I will try some other values as well..
    MIT-Shotgun's ...
  10. #100
    Join Date
    Sep 2010
    Location
    SoCal
    Posts
    2,059
    Default
    I'm going to order the .22 Mills and see what happens.
  11. #101
    Member Sales Rating: (1)
    Join Date
    Apr 2007
    Posts
    3,919
    Default
    I have .5 resistors in all of my SDA's. Smoother is the only description that fits.
    They can be quite bright without the resistor. But some like that, I do not.
    Quote Originally Posted by Timothy Smith View Post
    WOW!
    That's like working your way through Katie Perry in order to get to Rosie O'Donnell.
  12. #102
    Join Date
    Jul 2010
    Location
    South Denver
    Posts
    649
    Default
    Man, I need to do this mod badly on one of my sets of SDA's. I have one speaker that trips frequently when at loud levels, and that "level" seems to be getting lower and lower. It's annoying to say the least. One minute I'm rocking out, and the next ... "What the @%#$?"
  13. #103
    Member Sales Rating: (58)
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,306
    Default
    A jumper to remove all the coloration that may or may not exist works fine too. As far as adding a resistor to the mix, and I respect the opinions offered, don't believe it's anything but placebo.
    Get rid of the Polyswitch, period. Whatever method you choose, fine.
  14. #104
    Join Date
    Sep 2010
    Location
    SoCal
    Posts
    2,059
    Default
    Quote Originally Posted by dorokusai View Post
    That one statement right there got me super curious tonight. I went ahead and removed the .5 ohm Mills resistors from my SDA-2B TL's, replaced them with jumpers, and have been listening for the past hour to Norah Jones & John Mayer.
    I still need more evaluation time but my initial impressions are really good. The first thing I noticed besides the obvious increase on the top end was a lot better coherency in the vocals. I haven't run across a song that was overly bright. I think the words "bright" and "harsh" are often interchangeable, and they shouldn't be. The speakers are definitely a little on the brighter side now but not in a harsh way. It sounds really good now, but I still need more time.
    The inductor mod is a must now the Larry has had such a good experience. I can't wait to tackle that one.
  15. #105
    Join Date
    Sep 2010
    Location
    SoCal
    Posts
    2,059
    Default
    Got in a couple more hours of listening last night and I've been popping in my favorite tunes all morning. I like the change and they're going to stay this way! I'm experiencing better coherency from tweeter to mid driver. Like Mickie D's, I'm loving it.
  16. #106
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,733
    Default
    I don't believe so, when voicing speakers .5-1ohm can make a subtle, but noticeable difference. The kind of resistor makes a difference too.
  17. #107
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,030
    Default
    Quote Originally Posted by Face View Post
    I agree they are subtle but I noticed the difference right away, I have been wanting to try a different resistor the .5 is the only mills in the mix on my xovers now..
    MIT-Shotgun's ...
  18. #108
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,306
    Default
    Like I said, respect the opinion but I don't agree. It's not like it's expensive to try so knock yourslef out folks.
  19. #109
    Join Date
    Sep 2010
    Location
    SoCal
    Posts
    2,059
    Default
    No polyswitches or resistors ROCK. I've been listening all day with only the jumpers and I'm hearing more coherency then I ever have before. Piano's sound "right." Vocal separation is improved. Me likey.
  20. #110
    Join Date
    Aug 2009
    Location
    Milford,NH
    Posts
    24
    Default
    One thing I've noticed on my (new to me) Monitor 12 S2s is that the highs seem a bit weak. I can hear sound from the tweeters but the high end seems softer than the lows. This is something I never experienced in my SDA-1Cs. According to the schematic, there is a RDE 090 polyswitch in paralell with a 4.2uf cap. Although I am planning on recapping the x-over in the near future, any danger in just removing the poly to see if it makes and difference? Since it's in paralell I am assuming I do not need to jumper it?
    Life's too short too listen to bad speakers
  21. #111
    Join Date
    Feb 2011
    Posts
    768
    Default
    I think you will have to jumper it. When closed it is part of the circuit. If you simply removed it the tweeter would stop working as it does when the polyswitch trips.
    SDA 2BTL Sonicaps Mills resistors RDO-198s New gaskets H-nuts Erse inductors Crossover upgrades by westmassguy
    Adcom GTP-450 preamp
    Adcom GFA-555 amp Upgrades & speaker protection added by OldmanSRS
    Pioneer DV-610AV DVD/CD player
    SDA CRS+ Hidden away in the closet
  22. #112
    Join Date
    Dec 2007
    Location
    NW PA
    Posts
    273
    Default
    I have 2.3tl's and I would actually like a little more zip to the uppers. So would it be a good thing to remove the polys and use a jumper?
  23. #113
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,030
    Default
    Yes!!
  24. #114
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    21,185
    Default
    Quote Originally Posted by jmitchnh View Post
    Quote Originally Posted by TennMan View Post
    If it is in fact parallel there is no need to use a jumper if you want to delete using the poly switch. Many other models have the poly in series and in that case you would need to jumper it to complete the circuit. So make sure it is in fact parallel w/said cap. I wasn't aware of series II monitors using poly switches, but then Polk wasn't always 100% consistent from generation to generation. They used up older parts/pieces in newer models so there is some variation across generations.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Eastern Electric Mini Max; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  25. #115
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,175
    Default
    Notice that footnote "B" informs that the polyswitch and the 4.2 uF capacitor were added together in a circuit revision. The Monitor 12S2 high frequency circuit is identical to the Monitor 12 high frequency circuit, with the exception of the added parallel polyswitch/4.2 uf cap combination. In this case, you would need to take the 4.2 uf cap and the polyswitch out of the signal path. Both can be physically removed and replaced with a jumper or you could electrically "remove" them by putting a jumper across the parallel pair's terminals.
    __________________
  26. #116
    Join Date
    Mar 2005
    Location
    Posts
    21,185
    Default
    DK,
    So the cap is part of the protection and not part of the contour circuit? Seems like a large hole in the contour would exist if you just take it out, since it's obviously in the signal path. Note, I haven't looked at the schematic just going by what's be said in this thread.
  27. #117
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,060
    Default
    It appears in normal operation the polyswitch shorts the 4.2 uf cap( taking it out of the circuit).If the levels are high enough to trip (open) the poly switch then 4.2 uf becomes part of the hi pass network.This would allow the tweeter to still have some output but because C3 and C4 are now series connected( the combo resulting in just over 3 uf.) the high pass filter will be shifted to a higher frequency which would afford the tweeter more protection.
    Note,I haven't looked at the schematic...
    Yet you suggested to remove it?
  28. #118
    Join Date
    Mar 2005
    Location
    Posts
    21,185
    Default
    Quote Originally Posted by FTGV View Post
    Yep, sure did based on his explanation and what he was asking. If two parts are hooked in parallel to each other and you remove one part, you don;t need to "jumper" the removed the part to complete the circuit. That's what he asked and that's what I answered.
  29. #119
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,060
    Default
    The fact that a poly switch is in parallel with a cap should be a direct tip off that something unusual is involved requiring a peek at the sch.Just sayin.
  30. #120
    Join Date
    Mar 2005
    Location
    Posts
    21,185
    Default
    Fair enough, because I did note that was unusual.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Got a nasty virus? Forget drugs...
    By Jstas in forum The Clubhouse
    Last Post: 02-05-2008, 10:05 PM
  2. Nasty collection letter
    By Danny Tse in forum The Clubhouse
    Last Post: 02-01-2008, 10:48 PM
  3. Polyswitches
    By djf in forum Vintage Speakers
    Last Post: 11-13-2005, 11:38 AM
  4. The sound is kind of nasty but
    By Jstas in forum Car Audio & Electronics
    Last Post: 11-07-2003, 12:17 PM
  5. Nasty Reverb
    By VR3 in forum Speakers
    Last Post: 09-18-2003, 06:49 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
