Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 121 to 140 of 140
  1. #121
    Member Sales Rating: (0)
    Join Date
    Dec 2007
    Location
    NW PA
    Posts
    273
    Default
    Quick hijack.....I just pulled the pr's from my 2.3tls. I want to get rid of the polyswitches and use jumpers. I do not see enough room to do so, as the legs on the mustard colored polys are not long enough and are very close to the board. Tight quarters, next to harness and a cap too. Do I have to remove the x-over and do it from the backside of the crossover?
  2. #122
    Join Date
    Feb 2011
    Posts
    770
    Default
    Quote Originally Posted by jmitchnh View Post
    Since it's in paralell I am assuming I do not need to jumper it?
    This is the question I answered. Once again, the correct answer is yes the polyswitch does need a jumper for proper operation of the tweeter. I see nothing about completing a circuit in that question.
    SDA 2BTL Sonicaps Mills resistors RDO-198s New gaskets H-nuts Erse inductors Crossover upgrades by westmassguy
    Adcom GTP-450 preamp
    Adcom GFA-555 amp Upgrades & speaker protection added by OldmanSRS
    Pioneer DV-610AV DVD/CD player
    SDA CRS+ Hidden away in the closet
  3. #123
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    21,190
    Default
    Quote Originally Posted by TennMan View Post
    If it's in parallel to the cap then if you remove just the poly, the cap still completes the circuit, why add a hunk of wire to the cap? Now that's simply in practice as there is more going on here than simply removing the poly since the cap and poly work together for the protection circuit.
    If I am wrong about how parallel and series circuits are configured please explain.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Eastern Electric Mini Max; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
  4. #124
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,065
    Default
    Yes,and you can remove the cap(C4)if so desired since it will have no function.
  5. #125
    Member Sales Rating: (3)
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,199
    Default
    Quote Originally Posted by heiney9 View Post
    DK,
    So the cap is part of the protection and not part of the contour circuit?
    Yes, as specified in the schematic notes.
    Seems like a large hole in the contour would exist if you just take it out, since it's obviously in the signal path.
    If that were true, then the previous model Monitor 12 would have a large hole in the contour since it has the identical HF circuit minus the polyswitch and 4.2 uF cap.
    Quote Originally Posted by FTGV View Post
    It appears in normal operation the polyswitch shorts the 4.2 uf cap( taking it out of the circuit).If the levels are high enough to trip (open) the poly switch then 4.2 uf becomes part of the hi pass network.This would allow the tweeter to still have some output but because C3 and C4 are now series connected( the combo resulting in just over 3 uf.) the high pass filter will be shifted to a higher frequency which would afford the tweeter more protection.
    I agree. The higher the signal's frequency, the less power there is in the signal.
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    __________________
    "Knowledge, without understanding, is a path to failure."~DK
  6. #126
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,199
    Default
    I think you will have to jumper it. When closed it is part of the circuit. If you simply removed it the tweeter would stop working as it does when the polyswitch trips.
    You answered incorrectly because you obviously assumed the polyswitch was in series with the tweeter, rather than being in a parallel combination with a capacitor. Your statement that the "tweeter would stop working as it does when the polyswitch trips" is not correct since the signal would still have a path to the tweeter through the 4.2 uF capacitor if the polyswitch were removed.
    __________________
  7. #127
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,065
    Default
    Quote Originally Posted by DarqueKnight View Post
    Correct ,however removing just the polyswitch as per H9's original suggestion would cause a large hole in the frequency response due to the high pass xover frequency being pushed much higher as a result of the series connection of C3 and C4.
  8. #128
    Member Sales Rating: (5)
    Join Date
    Mar 2009
    Location
    Richardson, TX.
    Posts
    1,522
    Default
    Quote Originally Posted by musky1963 View Post
    Pretty much yes. But it's just a single hex bolt plus unclipping the harnesses to remove them. It's not a big deal.
    Are you part of the dirty digital peasants or a member of the great Analog Master Race?
    SDA Recommended Playlist https://docs.google.com/spreadsheet/...FZCRkdxYXVNanc
    Open for editing.
  9. #129
    Join Date
    Mar 2005
    Location
    Posts
    21,190
    Default
    So the poly has that much influence on the contour? I was always aware the poly had a very small influence on the sound. I've removed several and never heard a large hole in the frequency response.
  10. #130
    Join Date
    Feb 2011
    Posts
    770
    Default
    I think you might be looking at this parallel circuit as if the polyswitch was functioning as a resistor when it is operating normally.
    I'm not an electrical engineer but I will explain the reason for my answer.
    If the polyswitch is not tripped, and is in new condition, is should ideally function as a straight piece of wire. Since electricity takes the path of least resistance the capacitor would effectively be bypassed.
    Once the polyswitch trips due to overheating, it does provide resistance and works in parallel with the capacitor to attenuate the power going to the tweeter in order to protect it.
  11. #131
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,065
    Default
    Normally it wouldn't but with this model as tennman also points out because it has an additional paralleled cap that only gets introduced into the circuit when the poly switch is triggered (or removed entirely).
  12. #132
    Join Date
    Mar 2005
    Location
    Posts
    21,190
    Default
    I am not and EE either and I can certainly see your logic.
    Fred and Raife are EE's so I'd certainly take anything they say more seriously.
  13. #133
    Join Date
    Dec 2009
    Location
    Canuckistan
    Posts
    3,065
    Default
    Fred ... EE .
    I wish but just a lowly ET.
  14. #134
    Join Date
    Mar 2005
    Location
    Posts
    21,190
    Default
    I'm not even that
  15. #135
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,199
    Default
    I am not and EE either...
    I'm not an EE either, I just stay at Holiday Inn Express a lot.
    __________________
  16. #136
    Join Date
    Oct 2004
    Location
    Mid-Michigan
    Posts
    3,549
    Default
    ...... I just stay at Holiday Inn Express a lot.
    lol lol
    Speakers:SDA2a, sub:Atlantic Technologies 172 PBM
    Pre:B&K PRO-10MC(2ch)
    Amps:Parasound HCA 1000a
    SourcesOppo DV-970HD, Xbox360, Kenwood KT-5300
    Cables:Philips/RCA/Monster
    Life's short, Listen to SDA's
    Life is short live Sui Juris
    Where did SOPA go?
  17. #137
    Join Date
    Aug 2009
    Location
    Milford,NH
    Posts
    24
    Default
    After reading numerous threads (beside this one) concerning removing polyswitches I went ahead and did the deed. I did install a solid core copper wire in it's place and the resistance of both switches registered at approx. .3 ohms. The result? Count me in is one who thinks this does make a significant improvement. The highs have more sparkle and air to them. More detail, more clarity. They sound a lot closer to the way my SDA-1Cs did and that is a very good thing. Next up, RDOs and Clarity Cap x-over rebuild.
    Life's too short too listen to bad speakers
  18. #138
    Join Date
    Jul 2010
    Location
    South Denver
    Posts
    649
    Default
    +1 in the believer camp!
    I need some more time listening to them (and probably more burn-in), but I'd say there is a definite hi-end clarity improvement without the Polys. I know for sure the Poly in my left speaker was junk.
    FYI - I installed .5, 12 watt Mills. I also have some .22's that I might try after a month or so, just to see if I can tell the difference. It almost takes longer to remove all the faceplate screws on the SDA-SRS plate, and warm up the soldering iron, than it does to complete the mod! (It helped having a TV snack tray that was about the exact height I needed to support the xover and plate while I worked on it though...)
    (A monster may have just been created! Spikes are next, already in hand.)
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	65365   Click image for larger version
  19. #139
    Member Sales Rating: (2)
    Join Date
    Jun 2003
    Location
    Triangle area of NC
    Posts
    262
    Default
    I have a pair of 1C's that I haven't listened to much over the last year or two as they just didn't sound that good to me. I have been debating selling them since they were just taking up space. I decided yesterday to see how complicated it would be for me, who has ZERO experience with soldering and ZERO experience with electrical circuits to to remove the polyswitches just to see if I would hear something better. I popped the passive out, unbolted the crossover, identified the polyswitch and decided to go for it. I had no soldering iron so went to Radio Shack and bought the $10.00 beginner kit and made a jumper to run between the leads. The soldering work is not especially pretty but damn these speakers sound like they have a new life. I have been listening most of the afternoon and can't believe they are the same speakers. Anyone sitting on the fence because of lack of knowledge I strongly urge you to just go for it, it really is simple and takes no more than an hour start to finish.
  20. #140
    Join Date
    May 2009
    Location
    Plano, TX
    Posts
    247
    Default
    I wish some of you guys had posted the (resistance) value of the polyswitches you removed. I just completed an XO mod on my Monitor 10's and replaced the PS's with a 0.5 Ohm resistor. The resistance value of the (removed) PS's ranged from .7 to 2.2 Ohms! Needless to say I'm thrilled with the results.
    Yamaha DSP-A1 Integrated Amp
    (2) Polk Monitor 4's w/peerless tweets (dual centers)
    B&O TX2 Turntable
    Nakamichi Cassette Deck 1
    Pioneer CLD-99 Elite LD
    Samsung BD-P2550 Blu-Ray/DVD
    LG LST-3410a OTA DVR
    Princeton AF3.0HD Monitor
    Optoma HD65 Projector
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Got a nasty virus? Forget drugs...
    By Jstas in forum The Clubhouse
    Last Post: 02-05-2008, 10:05 PM
  2. Nasty collection letter
    By Danny Tse in forum The Clubhouse
    Last Post: 02-01-2008, 10:48 PM
  3. Polyswitches
    By djf in forum Vintage Speakers
    Last Post: 11-13-2005, 11:38 AM
  4. The sound is kind of nasty but
    By Jstas in forum Car Audio & Electronics
    Last Post: 11-07-2003, 12:17 PM
  5. Nasty Reverb
    By VR3 in forum Speakers
    Last Post: 09-18-2003, 06:49 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
