Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 91 to 120 of 351
  1. #91
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,225
    Default
    Thanks for this write up Ray,
    I know this thread is old but I am going to be ordering parts Monday and this is a huge help, and will be a very fun project. of course I will be building my own aluminum case for this project, the only thing I'm not sure of using is speaker wire, I will give it some thought this weekend.
    There was a time this thread was gibberish to me, HEHE.
    "Again Ray" thanks for all you share and do. This has been very helpful.
    No Way But The Hard Way, So Get Used To It!!!
  2. #92
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,225
    Default
    Just ordered my Transformer from AVEL, My Binding Post's from Sonicraft.
    and I'm working on my Aluminum Case now!!!!
    Should be a pretty simple project but fun...
  3. #93
    Member Sales Rating: (1)
    Join Date
    Jan 2010
    Posts
    656
    Default
    Hey Tool -
    Let me know how it turns out. This is one of those projects that I wanted to do earlier in the year, but kept putting it off. Now it looks like it will be a next year project.
    Thanks to DK with the parts list he posted, I hope to get this project done next year, or to at least order the parts to have it available. The only parts I purchased so far is the binding posts. I purchased it when I purchased the Blackhole 5.
    What binding posts are you using for this project?
    MJ
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  4. #94
    Join Date
    Jan 2010
    Posts
    656
    Default
    It seems that I am following in Larrys and DKs footsteps. I just ordered the transformer, it should arrive by Thursday. I need to call Par-Metal for the enclosure. Gotta think about the dimensions and finish of this enclosure. I am leaning twords an alodine finish.
  5. #95
    Member Sales Rating: (0)
    Join Date
    Oct 2011
    Posts
    16
    Default
    Hey DarqueKnight, can you guide me to the manufacturer of the box? I cant seem to find one online similar and now that i have the avil transformer I need an aluminum box to place it in! Thanks in advance
  6. #96
    Member Sales Rating: (3)
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,364
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    __________________
    "Knowledge, without understanding, is a path to failure."~DK
  7. #97
    Member Sales Rating: (17)
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Quote Originally Posted by DarqueKnight View Post
    Raife,
    I'm going to build one as well, do you think this case will be big enough?
    20-12125A $63.00 12w x 12D x 5H
    Thanks,
    Sal
    Polk Audio SDA SRS 1.2TL's
    With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
    My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
    It All Started here: http://tinyurl.com/lasareath2
    Part Deux: http://tinyurl.com/lasareath3
    Car Stereo---->http://www.salsleaf.com/leaf_stereo/index.htm<---- NEW for 2013
  8. #98
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,364
    Default
    Yes, if you are using the same size transformer that I used. My case is 4" x 12" x 12".
    __________________
  9. #99
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Oh ok. From the pictures it looks bigger. Then I'll use the 4" as well.
    Does the transformer come with the bolt and washer or I have to buy those separately ?
    And how did you attach the bolt? Is it just drilled through the bottom of the enclosurer?
    Thanks again,
    Sal
  10. #100
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,225
    Default
    Quote Originally Posted by Lasareath View Post
    Thanks again,
    Sal
    I can answer that, yes it comes with the washer, nut and bolt, just drill a hole and bolt it down. Sal I also cut a piece of rubber/ gasket material to mount the transformer on.
  11. #101
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Quote Originally Posted by Toolfan66 View Post
    Thanks. Did you use the same case as well?
  12. #102
    Join Date
    Jan 2009
    Location
    Wyred 4 Sound
    Posts
    11,225
    Default
    No I built my own at the shop..
  13. #103
    Join Date
    Jan 2010
    Posts
    656
    Default
    I am still waiting for Larry to build me a case. I guess this means I did not make the 2011 deadline on making the dreadnaught case. This could make a 2012 New Years resolution.
    My other new years resolutions are to complete a never-ending speaker project and amp project so that I will not have to go into them in 2013.
  14. #104
    Member Sales Rating: (14)
    Join Date
    Mar 2005
    Posts
    4,305
    Default
    Get in line dude. Before he's making you a dreadnaught case he's making me a pair of CRS+ stands!
  15. #105
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    I had no idea that Larry was making Dreadnaught cases. The place where Raife got his is in NJ and they offer bulk discounts. Maybe we should order 100?
    Maybe Avel Linberg would give us discounts if we order 100 transformers.
  16. #106
    Join Date
    Jan 2010
    Posts
    656
    Default
    Just to clarify - Larry is not making cases as far as I know. I was joking. If he were making cases, I would not hesitate to have purchased them from him. I have purchased his rings and brackets for my 1.2TL with complete satisfaction. All that remains is to install the brackets into the other 1.2TL. This will be done in 2012.
  17. #107
    Join Date
    Jan 2010
    Posts
    656
    Default
    I plan to purchase the case from Par-Metal. If others are interested, I would be interested in purchasing a case using a bulk discount.
    Too bad I already purchased the transformer in 2010. Too many projects. Too little time. I still have an A/D converter to place in a case.
  18. #108
    Join Date
    Mar 2005
    Posts
    4,305
    Default
    I'd be in for one.
  19. #109
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Quote Originally Posted by nspindel View Post
    I'd be in for one.
    I emailed Avel Linberg and when they reply I'll ask if there's a discount for multiple unit.
    I also emailed Par-Metal and I'll ask them as well.
  20. #110
    Join Date
    Mar 2005
    Posts
    4,305
    Default
    Sorry should have been more clear. I already have the transformer. I'd be in for a case.
  21. #111
    Member Sales Rating: (4)
    Join Date
    Jan 2008
    Location
    Salem, Oregon (Polk county!)
    Posts
    4,342
    Default
    I'd guess that we would not make 100 cases for 100 AI-1's, but maybe people will use the case for other things as well. I'd be in for one case. My custom made case works OK, but I'd like one a little more sturdy. Don't need a transformer though, I have one.
    Greg
  22. #112
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Quote Originally Posted by headrott View Post
    Greg
    And each person would need different connections on the case. Raife used really nice binding posts. I don't think I'll do the same because I'm still using the stock Pin/Blade connectors on the back of my 1.2tl's. I'd like to install all Cardas binding posts but I don't have the free funds for that project now. Eventually I'll just drill holes in the back of case myself.
    Hopefully tomorrow these people get back to me and I'll find out if there is any discount if we buy 10 units. If so I'll make a new thread and see if anybody wants to pitch in.
  23. #113
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,364
    Default
    There is a link on their website to their current price list which lists the prices for volume orders for each case.
    __________________
  24. #114
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Thanks.
    20-12124A (1) $57.00 each (6 to 19) $51.00 each (20 to 49) $45.90 each (50 and up) $41.30 each 12W x 12D x 4H
    Now I need bulk prices from Avel Linberg
  25. #115
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    These prices are so cheap it's not worth it to worry about getting a discount for 10 units. After we re-ship to everyone who ordered one we'll most likely be paying the same or more per unit. If you want one then you might as well buy one directly from the company.
  26. #116
    Join Date
    Jan 2010
    Posts
    656
    Default
    I would be in for a case. I will be using Vampire or Cardas CCGR Binding Posts, so I would need cutouts on the case to accomidate for it. DarqueKnight - good point on the shipping. Sal - if you worked out the cost on what it would be for the case + shipping - assuming you were to receive the bulk order, what would you estimate the total cost would be?
    Now, if Larry had some time, I am sure there would be enough interest in this forum for us to buy cases from him. I have no reservations on spending my money on his work!!!
    PM1
  27. #117
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    I'm a little confused.
    I want a case that is all black but on their website they state that:
    "Painted whole case include inside (no EMI shield)"
    And
    "Gold/Clear alodine finish for EMI shield"
    Does this mean that only the Gold or Clear alodine finish offer EMI shielding?
    Can somebody please explain this?
    Thanks,
    Sal
  28. #118
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,364
    Default
    And
    The prices and description you listed above are for the 20-12124A (A is for alodine).
    If you review our PM conversation, you will see that I mentioned that the case I used was the 20-12124B (B is for black). Note that the 20-12124B costs substantially more than the 20-12124A.
    MODEL 20-12124B: 82.00 (1 to 5), 73.70 (6 to 19), 66.30 (20 to 49), 59.70 (50 up)
    EMI/RFI shielding is not listed as a feature of the 20-12124B. I can't imagine that they would not add this feature for you as an extra cost option, since they do completely custom cases.
    __________________
  29. #119
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    What does the EMI/RFI shielding consist of?
  30. #120
    Join Date
    Feb 2007
    Location
    Central NJ
    Posts
    11,421
    Default
    Well I officially ordered my transformer, it came out to $128.48 Shipped. I paid $117.48 + shipping. they sell them at 108.08 each if you buy 10.
    I'm waiting for an email back from Jin at Par-Metal for the exact price and explanation of what exactly does the EMI/RFI shielding consist of.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. JBL fun project
    By Zero in forum Electronics
    Last Post: 03-28-2013, 10:23 AM
  2. AI-1 Dreadnought - Preliminary Results
    By DarqueKnight in forum Vintage Speakers
    Last Post: 01-25-2009, 10:50 PM
  3. SOLD FYI Sub Project HSU-VTF-2
    By criverajr in forum For Sale (FS) Classifieds
    Last Post: 12-02-2008, 01:27 PM
  4. Need Help with new HT project
    By Sherardp in forum Electronics
    Last Post: 03-27-2007, 10:48 PM
  5. My next project..
    By Ricardo in forum Electronics
    Last Post: 02-06-2007, 11:15 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
