Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 31 to 41 of 41
  1. #31
    Member Sales Rating: (0)
    Join Date
    Jan 2009
    Posts
    1
    Default
    Quote Originally Posted by McLoki View Post
    In the Yamaha - set sub to off and front speakers to large.
    Set your other speakers to small with the crossover at 150hz.
    Use the crossover in the sub to cross over to your front speakers. (probably around 150hz or so)
    Yeah i agree with that.... crossover in front speakers....
    _________________
    A cool idea from Busby SEO Test
  2. #32
    Join Date
    Dec 2008
    Posts
    12
    Default
    If the sub is connected to the sub out jack on the receiver and the receiver crossover is used, then should the crossover on the sub be set to the full range? Another newb...
  3. #33
    Join Date
    Jan 2009
    Posts
    23
    Default Help
    I don't want to step on toes or jack a thread but this was kinda what I asked in another post....
    I am considering this sub(PSW505) and was wondering if there is any preffered method to "hooking'' it up. I have my sub now hooked up to my receiver thru the Sub pre-out. I don't get as much bass as I used to hooking it up with speaker wire. Is this normal? I've got it set to the max(db) thru the receiver and it's still weaker than it was at half volume set up with speaker wire...my current sub(sony sw2500) isn't that great anyways...just wondering how the sub performs with just a sub pre-out connection from the receiver...thanks.
    I do have my towers set as large or actually it says "Full" I believe. Should I try small and change the crossover to what?? Newbie here too. Thanks for any and all replys.
  4. #34
    Member Sales Rating: (10)
    Join Date
    Apr 2005
    Location
    Magnolia, NJ
    Posts
    4,052
    Default
    Quote Originally Posted by Dune View Post
    Here's a great article that explains the whole "Small / Large" settings dead on. The biggest stumbling block is that guys with large (physical size) speakers always assume that they're full range. Not even close. http://forum.ecoustics.com/bbs/messa...79/128214.html Give it a try, I'll bet you like the results.
    "2 Channel & 11.2 HT "
    Panny 65" 3D Plasma
    Yamaha AVENTAGE RX-A3010 AVR
    D>SONIC M2-600M mono's / mains
    Rotel RMB-1095 / 5 channel amp
    Rotel RMB-1075 / 5 channel amp
    TEAC UD - 501 DAC
    Oppo BDP-93
    SONOS System
    KEF Q900 / mains
    KEF Q600 / center
    KEF Q800 / surrounds
    KEF Q100 / rear surr.
    Def Tech ProMonitor 1000 / front & rear presence
    Velodyne SPL-1200R subs / dual pair
    DSPeaker Anti-Mode 8033 sub EQ
    Equitech Balanced Power Son of Q 1.5R
    Extensive room treatments
  5. #35
    Join Date
    Sep 2002
    Location
    New York
    Posts
    18
    Default
    Looking for some advice on bass management. Just hooked up two RTI8s as main to my RM6000 sub and RTi28 surrounds. Always happy with the 'Polk method' of sub wiring but what's the preferred bass management--Large or Small---what about crossover freq.
  6. #36
    Join Date
    Feb 2010
    Posts
    1
    Default
    I just read the link that Pearsall001 provided.
    That answered some questions I had. Also reading through this whole thread answered almost all of the rest. There is a tremendous amount of collective wisdom in this group.
    As a beginner in this field of home theater, I'm sure I will be lurking around quite a bit.
    I do have one question tho...I purchased the 95 pack (5 rm8's) and a PWS505 sub. If the rm8's are:
    Overall Frequency Response 95Hz-24kHz
    Lower -3dB Limit is 130Hz, does that mean the speaker only works well down to 130Hz?
    So if my sub is:
    Overall Frequency Response 23Hz - 160Hz
    Upper -3dB Limit 125Hz
    Crossover Variable low pass 60 - 125Hz, 4th order(whatever that means)
    Will I still set the crossover to 120? The link provided seems to point to 80 being the magic number, but if I'm interpreting the info correctly my speakers don't even respond to a signal that low.
    The question sounds lame as I write it, but I am truly a novice. Never used a sub woofer before.
    Thanks for any replies
  7. #37
    Member Sales Rating: (7)
    Join Date
    Aug 2004
    Location
    Central Illinois
    Posts
    5,247
    Default
    Yes you are correct. Provided your main speakers have a -3db point of 80hz or lower, you should set your speakers crossover at 80hz. (you would set the subwoofer LFE crossover (if your AVR has that setting for the subwoofer) to 120hz.
    In your case, with your speakers, I would try 120 and 150hz and see what sounds better to you. I would guess that 150hz may be a little to easy to localise the subwoofer and if that is the case, you may want to try at 120hz.
    Anyway - give it a shot, try some different settings, and let us know what you think.
    Michael
  8. #38
    Join Date
    Jul 2009
    Posts
    10
    Default Sub Connections
    I am always replying to things years after the fact, but here goes.
    I have heard that a powered sub with a built in variable crossover like my Velodyne X-10 , and a receiver with a crossover built in as well, will be a problem of having two crossovers, if not wired through the "Polk Method"
    Please advise.
  9. #39
    Member Sales Rating: (1)
    Join Date
    Jul 2001
    Location
    Mobile, AL
    Posts
    3,267
    Default
    Quote Originally Posted by niles300z View Post
    Please advise.
    The key is not to have the two crossovers overlap and cause a gap in response. Typically, you can just dial the variable crossover up to its maximum, then let the AVR handle all the bass management on a digital level.
    The so-called "Polk method" of setting your mains to large, then wiring them through the subwoofer so that the sub controls the transition has several issues, primarily phase and time alignment. It's better to let the AVR handle all the bass management so that your channel delays can line things up without any analog crossover in place to alter delay.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  10. #40
    Join Date
    Jun 2009
    Posts
    14
    Default
    Quote Originally Posted by kuntasensei View Post
    Another fact that people like me don't always understand is that when using the "Polk method", everything is passed through the sub to your mains. It's just as if they were hooked up directly to your receiver, no bass is filtered at all. So if you have satellites or smallish bookshelves, you're sending them the low frequencies whether you like it or not.
  11. #41
    Join Date
    Jun 2009
    Posts
    14
    Default
    In my post above, I'm referring to most subs. Obviously there are a few subs out there that have a high pass filter. I was thinking about some of Polk's base models and some of their competitors when I made my statement.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Hooking up a subwoofer crossover??
    By Early B. in forum Electronics
    Last Post: 04-01-2008, 07:51 PM
  2. using crossover on subwoofer
    By ilikesound in forum Subwoofer Hookup & Bass Management
    Last Post: 09-24-2007, 12:10 PM
  3. Active Crossover for Subwoofer
    By SolidSqual in forum Subwoofer Hookup & Bass Management
    Last Post: 04-12-2007, 10:23 AM
  4. M&K Subwoofer Amp - No crossover or Controls
    By VR3 in forum Flea Market
    Last Post: 07-15-2004, 01:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
