Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Member Sales Rating: (0)
    Join Date
    Nov 2008
    Posts
    2
    Default Mixing VM series speakers
    I'd like to set up my 7.1 home theater using Polk VM series speakers. How much mixing/matching can happen within the VM series? For example, I was considering the following:
    Center - VM10
    L/R - VM20
    4 speakers in the surround areas - all VM10
    Subwoofer - Undecided (and looking for advice)
    Will this type of configuration fly? Or should they really all be the VM10s for best performance? I'm open to suggestion. I'm a bit limited by space on the center speaker, as I've not found a good tv stand that will allow me to have a larger speaker and not have an eyesore in the room. Aesthetic is important (wife says so too). With the back speakers (not the surround ones), I'm also potentially limited as I may like these to sit on bookshelves rather than having stands back there for kids/animals to potentially knock over. But that's not set in stone.
    I'm thinking of a Denon AVR-3808CI to bring it all together.
    Thanks for your opinions.
  2. #2
    Polk Customer Service
    Join Date
    Jul 2004
    Location
    Polk Audio HQ
    Posts
    556
    Default
    Should sound great, everything is from the same series. Another VM20 would be a better match in the center, but since you're space limited the VM10 will be the next best choice.
    DSW microPRO really shines with VM series.
    -Eric
    -Polk Audio
  3. #3
    Join Date
    Nov 2008
    Posts
    2
    Default
    Thanks, Eric. Would I be better served to just go with VM10s all around? Will the sound be lopsided with the two VM20s on L&R? My thinking in going with those for L/R was more to bolster the times when I want to listen to music, but if I would be better balanced to get all VM10s, then I'd rather go that route. Thoughts?
  4. #4
    Member Sales Rating: (3)
    Join Date
    Jul 2007
    Posts
    340
    Default
    A vm20 for the center would be a better idea being that it does most of the work front stage.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Mixing RTi with RTi A Series
    By RVJII in forum Speakers
    Last Post: 06-06-2008, 12:07 AM
  2. Need Help Mixing 4 ohm and 8 ohm Speakers?
    By VXR8 in forum Basic Hookup/Wiring Questions
    Last Post: 05-27-2008, 07:28 PM
  3. Mixing Speakers in 7.1 System
    By cooped in forum Speakers
    Last Post: 02-09-2008, 12:05 AM
  4. mixing rti with lsi series
    By vikings22 in forum Speakers
    Last Post: 04-07-2005, 02:54 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
