Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 9 of 9
Thread: Bi amp
  1. #1
    Member Sales Rating: (0)
    Join Date
    Dec 2008
    Posts
    5
    Default Bi amp
    can i bi amp with the Denon avr3808 what i want to do is run the 2 front speakers with the Denon into 8 ohm load then use a 5 channel amp to run the center, middle. and back speakers all at 4 ohm load thanks
  2. #2
    Member Sales Rating: (41)
    Join Date
    Apr 2008
    Location
    Milwaukee, WI
    Posts
    8,581
    Default
    What kind of speakers do you have?
  3. #3
    Join Date
    Dec 2008
    Posts
    5
    Default
    Quote Originally Posted by leroyjr1 View Post
    2-rti 5’s front
    1 -cs 20 center not purchased yet could go to the ls series for 4 ohm
    2-lsi7 middle
    2 –vintage m&k sb2 rears
    1-dsw pro 600
    The problem I have is the center and fronts are 8 ohm’s the middle and rears are 4 ohm’s. I do not have an avr yet but looking at the Denon avr3808ci. After doing some research I found out the 3808ci will not work because of the 4 ohm load. So the question I have is could I use the 3808ci as a pre amp or could I use it just to drive the 2 front and center speaker. Also if I could what would I need as an amp for the other 4 speakers. Or should I trash that idea and get something different. Any help on a setup with what I have as far as speakers go would greatly help’ thanks for all your input.
  4. #4
    Member Sales Rating: (22)
    Join Date
    Oct 2008
    Location
    Directly over the center of the earth in Olathe Kansas
    Posts
    5,573
    Default
    Yes and yes
    Any AMP that supports 4 ohms, I am using a Carver TFM-25, it is rated at 400wpc 4ohm.
    Don't trash the idea
    Ofc: Wright WLA12 preamp: Anthem Amp 1 PSVANE 6CA7: Pio Elite DV-79AVI: Airport Express: PA LS90 sonicaps and mills
  5. #5
    Join Date
    Dec 2008
    Posts
    5
    Default
    Quote Originally Posted by thsmith View Post
    Yes and yes
    thanks thats what i do
  6. #6
    Member Sales Rating: (1)
    Join Date
    May 2008
    Location
    Silver Spring MD
    Posts
    493
    Default
    The Denon can support the 4ohm load - but they don't advertise it - it is in the owners manual.....so long as the speakers are not too hard to drive that it overheats.
    also:
    You can bi-amp the mains and still have a 7.1 system re-routing the zone 2 speaker to power the mains.
    also also:
    You can use it as just a pre-amp......
    Good Luck - it is a great reciever - just be patient when learning how to use it....
  7. #7
    Member Sales Rating: (4)
    Join Date
    Jul 2008
    Location
    Milwaukee, WI
    Posts
    664
    Default
    It may handle the load temporarily, but it will definetely shorten the life down of the Denon. You may just be able to fry an egg on top of it....
    Living Room:.................... Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  8. #8
    Join Date
    Dec 2008
    Posts
    5
    Default
    I called denon and they told me there would be no problem but i dont trust them from what i have read and i know the m&k's and the pulk's lsi7 need a lot of punch to run them if not they will not sing.
  9. #9
    Join Date
    Nov 2008
    Posts
    1
    Default
    I am running LSi9's and and LSiC across the front with a 2809 and I am not having any problems with heat or clipping. I don't listen at overly load levels but loud enough that they sound good.
    I can see how additional power would make them better but that is going to have to wait for awhile.
    Quote Originally Posted by curved View Post
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
