Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreLast edited by GV#27; 03-17-2009 at 05:05 PM.
LOL
The bypass cap is supposed to help provide some airiness and spaciousness to the sound. General consensus around here is that it is not needed with new, higher quality caps and is, in fact, detrimental. I didn't really notice anything but good sound when I did my 2A's, but I don't miss not having it on my 2B's either.You can order them and try for yourself if you're curious.
FWIW, I asked someone at Polk (Ken maybe) about the really low value of that original bypass cap and he said it was so low, it probably didn't do much anyway.
"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
The 270 is just fine. That cap is actually in series. Not shunt. It is used to prevent the bass signal from being canceled out by the SDA IC. It's kinda hard to fallow in the diagram, but that is the way they did it with the blade/blade SDA's.
http://www.polkaudio.com/forums/showthread.php?t=55888
The signal passes from the positive of the of the right to the negative of the left, and vis versa. If the cap was not there it would cancel out the bass also.
Ben
Yes, thanks GV for the link. I hopefully got in my order in time to get a couple. They are actually cheaper than that. The price is $34.00 Canadian which is about $27.00 U.S. Really nice deal.
Thank you all for entertaining my questions on this thread. I've really learned a lot and now that I've ordered the Solens, I think I know what I will do with the rest of the crossover upgrade. This forum is great and your opinions are very much appreciated!
I just saw NJPOLKER's post on his 270 ufd Solen caps... see link. Good lord it's the size a beer can! Suggestions on how I'm going to install this... Do I need to mount it on a separate board in the speaker and solder wires from it to the circuit board? I knew they would be large but holy cow these things are huge! Mine have not arrived yet, but now I won't be so shocked.
http://www.polkaudio.com/forums/showthread.php?t=80514
Just use some wire and mount it off board. It will not hurt performance:)
Ben
Ben
NJ will likely have a better method, but you could use a piece of masonite or peg board and secure the cap to it with wire ties and hot glue (or silicone).Then silicone or glue the finished board to the bottom of the cabinet.Solder in some leads with MonsterCable:) and your good to go.
I have completed the first stage of my upgrade. On the primary crossover I decided to go with Sonicaps for the high pass filter and Daytons for the 20uF shunt caps on the low pass. I'm still waiting for the Solen 270 uF monster caps I ordered and will upgrade the dimensional crossover with those and 20uF Daytons for the shunts on it. I used Cardas solder as well.
I've posted a before and after pic for the left channel speaker. Strangely, the low pass shunt cap on this speaker was different than the one on the right which was a standard blue electroytic cap. Anyone have any idea why two different shunt caps? Would that have been done in the factory or did a previous owner of this set change out one?
Everything went in fine and the only disappointment is that I didn't make the hot glue go on as neatly as I would have liked...:o not that anyone will be seeing them from now on. The speakers sound great and are getting better by the hour as the caps break in. I did go ahead and order a set of RD0194-1 tweeters to replace the SL2000s. Also waiting for them to show up.
Thanks for all your help guys... this project was not nearly as tough as I first thought it might be.
It looks like you decided to leave the original poly switches alone?
If they are the originals you may want to order two new ones from Polk CS, I think no charge.
Some say to bypass the poly switch with a jumper. I have not because of the potential for someone being reckless with the power. I have alot of clean power but ya never know what could happen :o
This is a good start for you and you'll find the low pass a little more tricky but not too tricky for you now :)
Is this switch just to protect the speaker from being overdriven or does it serve some other purpose? Why do you need to change them out, do they go bad or do they just make a better one now?
It is to protect the tweeters.It shuts off then comes back on after a few moments..They do go bad over time.Some suggest a bypass as it will improve the SQ of the highs
SDA-2BTL with custom IC
Theta Data Basic Transport--Camelot Arthur DAC--Camelot Dragon Pro2 MK III
Harman Kardon T-55c TT
Prophecy Cryo-Silver Reference AES/EBU
Prophecy Cryo-Silver i2s digital cable
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
So, if I bypass it, what do I need to be careful about doing... or not doing to keep from blowing the tweeters?
First good clean power.NO CLIPPING...Second dont crank it up too much.
What are you driving them with? If it's a receiver, leave them in.
It's a receiver... Onkyo TX-SR806... I tend not to overpower as my old ears can't handle it like they used to no matter how clean it is. Now as my kids get older and enter their teen years... that could be a different story.
After reading other posts on this subject, it would seem that I would have to be turning up the volume to a rediculous point where it would be so distorted I might rather find more enjoyment running bamboo shoots up my fingernails. I do not listen to my music that way nor will I ever allow my kids to do that either... not in this house at least. :) So, I think I will go ahead an take them out...
Does that reciever have pre outs.You could get a nice used amp to power them with and Im sure you would enjoy the better SQ you would get.AudiogoN has good deals on used ones.High current like adcom,rotel,marsh etc is the way to go for SDAs IMO
Hi,
I have been following this thread with the idea of doing the same. The polyswitch is the blue thing next to the square resisters? I will jumper mine but the dimensional xover (top one in the photo) is where I will need the 270 uf cap to replace the 3 blue ones? Bcline, any word on the sound of the changes?
Your polyswitch is in the high pass/lower x-over in pic next to the resistors mustard colored
You will need the 270uF to replace the two 130uF caps which are tied together. You will need a separate cap to replace the 20uF cap. When installing the new caps put the 20uF over the 270uF there are pictures posted by yours truly in another thread.
I have not installed my 270 caps yet. I just received them yesterday afternoon and probably won't be able to get to them until this weekend at the earliest.
I will say that the upgrade of the high main crossover with the Sonicaps and Daytons has resulted in better detail in the sound. I'm hearing things I did not hear before especially with subtle notes and background licks in the music. Overall, the sound is brighter and seems more natural than it was before. I still have not removed the polyswitches yet... again I will do that when I get around to upgrading the dimensional crossover (that's the upper crossover in your pic).
NJ's thread is here.
I do have preamp outputs (called a 2nd room output on the receiver). However, I don't think I have the money at this time to be going the route of the an audiophile grade dedicated amp. I do know what they can bring as I have a good friend who is in the business of super high end audio and home theater. He is the exclusive Martin-Logan dealer in Wichita right now. I've heard his stuff and have been blown away by it. However, I am a teacher and that brings it's limits and besides that, my wife has entertained my hobby this far, I don't want to push it. :) We will go with baby steps. ;)
Good for you. You know if you enjoy it what more can you ask for. I think you should leave the polyswitches in the x-over. You will not hear the difference and will give you some protection in case the unexpected happens, which happens too often![]()
I would replace the poly switches with new ones. I believe they're free from Polk.
Damn guy from L.I. is correct :D even a blind squirrel finds a nut :p:p
For those of you who have sat on the fence about changing your SL2000 tweeters to the RD0194 tweets. Quit sitting. I got mine yesterday and installed them and if I didn't know better, I would have said that I was listening to an entirely new set of speakers. I didn't realize how harsh the SL2000s were until I heard the change. I even have slight hearing loss at the high end, but I could sure hear what everybody had been talking about. The new xo components improved things... this upgrade just made all the difference.
BTW... I realize my Onkyo is not up to par with some of the integrated amps and monoblocks you are all talking about, but I get the feeling that some of you think it must be a fairly unimpressive Best Buy special too. If you look at the specs on the 806 it is not that bad and I beg to differ with some of you that I probably will not hear a difference when I make a change. This system is plenty clean enough to hear very subtle changes and as a musician myself, I have a pretty good ear for things. I know it ain't no McIntosh, but after owning some pretty dirty sounding recievers in the past, this one is leaps and bounds above many. Put it in direct sound mode and it essentially shuts down all extra functions and becomes a simple amp. It has 0.08% THD values, ample wattage and more importantly ample current flow. It has had no problem powering these SDAs and with the volume at 0db, I have it all the loudness I care to handle. Someday, I would like to own the real deal when I win the lottery or inherit a huge estate. For now this will do.
If you replace the poly switches and they start to kick in again, you know why. If they don't, then enjoy.
I think you nailed it when you stated "ample current flow" which is critical.
Its awesome you are enjoying your speakers and the upgrades.
There are currently 1 users browsing this thread. (0 members and 1 guests)
