Has anyone ever used the KAB EV-1. I'm sure it doesn't compare to the VPI, but it costs a lot less. Just looking for some opinions. Thanks!
http://www.kabusa.com/frameset.htm?/m1200.htm
Top of the page. Record cleaners tab.
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online StoreHas anyone ever used the KAB EV-1. I'm sure it doesn't compare to the VPI, but it costs a lot less. Just looking for some opinions. Thanks!
I've heard good things about it. Fully manual and you supply your own vacumn but a lot cheaper than a VPI or a NG.
SDA-1C (full mods)
Eico ST70 tube integrated rebuilt
Nitty Gritty 1.5FI RCM
The Clamp
Nakamichi CR7 Cassette Deck
Rotel RCD-855 with tube output stage
Cambridge Audio DACmagic Plus
DBX 3BX-DS
DBX 224-DS
ADC Soundshaper 3 EQ
Ben's IC's
Mike, I think you should save your money and buy a used Nitty Gritty or VPI. I've owned manual cleaning machines in the past and they are a PITA!
I've had one for about 2 years now. It's simple, easy to use and works well. Cheap, too. Obviously there's a bit more elbow grease involved then with a VPI 16.5 or the like. You can't scrub on the RCM, I use an old direct drive TT that doesn't work any more. For the price I don't think you can beat it.
Wris****ch--->Crisco
The KAB is just a NG without the motor or vacuum.
The VPI just looks more practical for cleaning. The full size platter allows for scrubbing, correct? Doesn't look like the Nitty Gritty allows for that with the small base.
You can scrub on the NG then turn the record over for the vacuum. The VPI is very easy and convenient to use. It has me spoiled.
In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction". - Kenneth Swauger
There are currently 1 users browsing this thread. (0 members and 1 guests)
