Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Member Sales Rating: (0)
    Join Date
    Jun 2007
    Posts
    404
    Default CD Player playback education.
    Hi all.
    I wanted to start a new thread about getting more educated as to how to properly add a CD-player to your sound system and what to expect.
    I don't own any SACD material so maily red-book CD ... I am hoping I am saying right...(regular CD's)
    I am only talking about CD-players like Rotel RCD-1072, or Cambridge Audio 840c, possible the new Emotiva ERC-1 etc.
    Most of these CD-players have left-right RCA(unbalance) connection, left-right XLR(balance) connection and a coax/optical connection. no mutichannel or hdmi out.
    What I undestand so far is these type of CD-palyers can convert , decode and play up to 24bit/384kHz. Some can only go up to 24bit/192kHz.
    I also read that if I choose RCA/XLR then the CD-Player will be using their internal DAC and decode and send it to the receiver for the sound to be sent to the speakers.
    If I choose optical/coax then the signal goes in PCM and it is the receivers DAC doing the decoding and sending the sound to the speakers. but the max sampling is 48KHz.
    1. So if I only have bookshelf spakers + a external Sub, How can I setup my receiver to make sure I am listening using 2.1 since my speakers might not have enough bass.
    2. Is one connection more recomended than another RCA/coax/optical. sorry I don't have anything than can handle XLR.
    3. Is there any relationship between the number 24bit/384kHz and the numbers I see on a speakers - overall frequency response 50Hz-27KHz
    4. If I decided to connect them using RCA, is this the same cable as what people call interconnect. RCA cable that go from the receiver to the external amplifier?
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  2. #2
    Join Date
    Jun 2007
    Posts
    404
    Default
    in shame ... a bit of a bump.
    I was hoping these would have been a few interesing questions...
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  3. #3
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,199
    Default
    2. In your case, RCA. Any of the players above will sound better than letting your receiver decode.
    3. No.
    4. Correct.
  4. #4
    Join Date
    Jul 2001
    Location
    Castro Valley/San Francisco, California
    Posts
    4,892
    Default
    Quote Originally Posted by olilugo View Post
    1. What kind of receiver and speakers do you have? The crossover point between satellites (your bookshelf speakers) and sub is determined by what you have.
  5. #5
    Join Date
    Jun 2007
    Posts
    404
    Default
    Thanks Danny, Face.
    The mains are Rti6.
    I know that my receiver has something called pure direct which is for 2ch sound out.
    I was hoping to get more information what Analog to Digital Conversion 24bit/384KHz means and how does that translate into sound which somehow works within the speakes frequency response.
    Thanks,
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
  6. #6
    Member Sales Rating: (6)
    Join Date
    May 2005
    Posts
    4,280
    Default
    384Khz is the sampling rate, how many samples per second. It has nothing to do with frequency response of the speakers.
  7. #7
    Member Sales Rating: (1)
    Join Date
    Feb 2005
    Location
    Spotsylvania, Virginia
    Posts
    553
    Default
    1. the best set up here would be to run your subwoofer with the speaker level inputs if it has them. this will give you more control over matching the sub with your bookshelf speakers and then it takes out the additional processing that the receiver has to do so you could put it into pure direct mode (wich by its nature is 2 channel only 2.0 and no sub) but that would not matter.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. I need an education in CDP
    By JimBRICK in forum Electronics
    Last Post: 06-11-2007, 10:04 AM
  2. DVD Player Education
    By Schris22 in forum Electronics
    Last Post: 10-10-2005, 01:12 PM
  3. Amp Education for the New Guy
    By Holydoc in forum Electronics
    Last Post: 10-02-2005, 10:53 PM
  4. Y-Splitters on SACD/DVD player 5.1 outputs? Anybody done this for 7.1 playback?
    By aaharvel in forum Basic Hookup/Wiring Questions
    Last Post: 07-14-2005, 06:03 PM
  5. Best DVD player <$100 for redbook playback
    By organ in forum Electronics
    Last Post: 04-01-2005, 12:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
