Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 8 of 8
Thread: ADCOM question
  1. #1
    Member Sales Rating: (0)
    Join Date
    Mar 2009
    Location
    Chicago
    Posts
    187
    Default ADCOM question
    I have been looking at ADCOM amps.
    Are they any good? I have heard a lot about them on some threads.
    Is it true they need their own 20amp circuit? The adcom site says its neccessary. Or could i just hook it up to a voltage stabilizer?
    Will the sound quality coming from the amp be better than my ONK 906?
    I know that the preouts will be sending the single, but how is ADCOMS sound quality? What differences can i expect?
    I have very little experience with home amps so any feed back would be great. Sorry about all the Qs at once.
  2. #2
    Member Sales Rating: (3)
    Join Date
    Feb 2009
    Location
    California
    Posts
    603
    Default
    Well, I'm no expert, but I know the Adcom GFA-555II and 545II that I have simply rocks! Awesome power to be had from these amps. Sound quality... eh. I can't perceive SQ differences between amps if there is one.
    Not sure about that 20amp circuit question though... I just plug my stuff into a power strip which plugs into my wall.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  3. #3
    Member Sales Rating: (8)
    Join Date
    Oct 2005
    Location
    Midwest
    Posts
    486
    Default
    I've owned many ADCOM amps over the years and I quite like them. ADCOM makes good, solid mid-fi gear that has impressed many people (including Stereophile). Whether it will sound better than X brand is completely in the ear of the beholder. A lot depends on system synergy.
    In my experience, you can't go wrong with a a good ADCOM amp. I've owned a GFA-535, GFA-545 and currently run a GFA-585 in my secondary system. I've loved every one of them.
    [ My Rigs ] Balanced Audio Technology | Revel | Dodd | Monarchy | PS Audio | MIT | Polk | Etc.
  4. #4
    Member Sales Rating: (11)
    Join Date
    Oct 2008
    Location
    Dixon, IL
    Posts
    6,519
    Default
    As far as I know, the need for a dedicated 20 amp circuit is only applicable to the newer multi-ch. amps such as the 7805/7807 and the 7705/7707. They require a 20 amp circuit because of the huge amounts of current they require to drive 5-7 speakers with their rated power output.
    To the best of my knowledge though, those are the only Adcoms that require a 20 amp circuit. I'm not sure of any of their older multi-ch. amps though.
    The nirvana inducer-
    APC H10 Power Conditioner
    Denon DVD-2910 universal player
    DPA The Little Bit Three DAC
    Yamaha P-300 turntable/TCC TC-750 phono preamp
    Acurus L10 preamp
    Adcom GFA-545 power amp
    PolkAudio SDA 2A's/PolkAudio Monitor 7A's
    Audioquest Type 4 speaker cables
    Audioquest Sidewinder IC's
    Audioquest Black Mamba IC's
    Signal Cable Analog II IC's
  5. #5
    Member Sales Rating: (43)
    Join Date
    Nov 2006
    Location
    CT
    Posts
    15,931
    Default
    Older Adcom amps are a great bang for the buck amp. Here is my short list of great Adcom amps.
    545, 5802, 565, 585, 555.
    Other than that I can solidly recommend getting Emo's.
    As for needing a dedicated circuit they don't need a dedicated circuit more than any other amp.
    Ben
  6. #6
    Member Sales Rating: (1)
    Join Date
    Oct 2008
    Location
    Descending toward the moon in the CLEM (Chinese Lunar Excursion Module), looking for Chang'e
    Posts
    11,445
    Default
    Do you want to run a multi-channel Adcom or a 2 channel? Because it seems you're asking about an Onkyo 906. So my question is what speakers are you running on that receiver...if they're 8 ohm the Onkyo is probably fine. If they are 4 ohm then, the Adcom will add to your experience.
    Ben is the expert here so I'd go with his short list, that's who I asked about my Adcom. If your question is will the Onkyo sound better in 2 channel, I might have to draw the line there and give a provisional yes.
    A bit more info might be useful. But as Ben says, bang for your buck, Adcom is there!
    cnh
  7. #7
    Join Date
    Jan 2003
    Posts
    197
    Smile
    Hi, I have two Adcom GFA-555's (original design) driving my electrostatic speakers. I've owned these two since I bought them in the mid-80's and would not part with them. They're powerful, reliable and when matched with my tube pre-amp create a nice warm smooth sound. Just love em! DJ
  8. #8
    Member Sales Rating: (16)
    Join Date
    Mar 2005
    Location
    In A Van Down By The River
    Posts
    21,185
    Default
    Great amps. I've owned heard several. I *just* recently replaced my 545 which I bought new in 1986. I felt I really needed to go up the ladder to get something markedly better. They complete with amps costing twice as much and many times even the higher priced amps don't always sound better.
    One of the best used values going. There were a lot of these amps sold so there's always a great selection of used pieces. They are pretty indestructable and buitl like tanks. I can't really think of a down side other than some of their early pre-amps aren't the greatest and if mated with the amps can sound a tad bit grainy.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30; Eastern Electric Mini Max; Adcom GDA600; MIT S3/Z Pc; SDA 1C; Squeezebox; Tubes add soul!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. question regarding adcom amp
    By mlastarza in forum Electronics
    Last Post: 12-27-2007, 08:05 AM
  2. Adcom preamp question
    By NeilGabriel in forum Electronics
    Last Post: 10-31-2007, 08:05 PM
  3. Adcom 565 pre question
    Last Post: 08-23-2007, 01:42 PM
  4. Adcom question
    By SwedePolk in forum 2 Channel Audio
    Last Post: 12-13-2006, 09:53 AM
  5. Another Adcom question
    By cindy100 in forum Electronics
    Last Post: 05-01-2006, 04:09 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
