Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 23 of 23
  1. #1
    Member Sales Rating: (17)
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default What is the First Reflection Point?
    And Where is it in a standard room with two speakers?
    Thanks,
    Sal
    Polk Audio SDA SRS 1.2TL's
    With new Exotic wood, Sonicaps, Mills & RDO198's - Born on 4-24-1989 and Signed by Matthew Polk!!!!
    My Polk SDA SRS 1.2TL's http://www.LASAREATH.com/
    It All Started here: http://tinyurl.com/lasareath2
    Part Deux: http://tinyurl.com/lasareath3
  2. #2
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,264
  3. #3
    Member Sales Rating: (58)
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    If you slide a mirror along that wall, when you see the loudspeaker cabinet...moreso a split between the baffle and the cabinet.
  4. #4
    Member Sales Rating: (28)
    Join Date
    Mar 2005
    Location
    Right here.
    Posts
    10,358
    Default
    Are you serious?
    If you are, it is the point in the wall, ceiling and floor (normally only the wall is treated), where if you place a mirror, you can see your speakers (right speaker for the righ wall) from your seating position.
    SOPA
  5. #5
    Member Sales Rating: (7)
    Join Date
    May 2007
    Location
    Climbing that pole...in your backyard
    Posts
    3,993
    Default
    Yer thinkin' to much, Sal!
    Go with the music.....;)
    Lots of variables associated with First Reflection.
  6. #6
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    Quote Originally Posted by lightman1 View Post
    Sure, but it's an excellent rough estimate. Ricardo said it best. I wouldn't cement anything but laying panels on the wall can help tune it in...and it shouldn't vary that much to dial it. If you change styles of loudspeaker, that could be a problem.
    This isn't rocket science.
  7. #7
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    Quote Originally Posted by dorokusai View Post
    Let's eliminate some variables. What speakers are you using?
  8. #8
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    None of your business or do you have something to teach me?
  9. #9
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    Putz! I'm finally talking audio and you say something like that.
    I've got six more days of probation. Don't make me f*ck that up.;)
    Sal?
  10. #10
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    Sal. Is this for the 2ch system? Rico is on the right track with the mirror bounce. But that depends on the speaker...and your ears with the room treatments.
    SDA's, monitors, etc.
  11. #11
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    Jerk.
  12. #12
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    Sal?
    Great, ain't no wink wink here man. Check out the troubleshooting section, hook some folks up.
  13. #13
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    What are you saying, Mark?
  14. #14
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default
    Yeah my brother told me about the mirror trick yesterday.
    I thought the first reflection point would be the wall where the closet is as shown below:
    So, if it's the side wall, wouldn't the ceiling and floor be additional reflection points?
    I think I already have the side walls covered.
    What's more important, covering the reflection points on the ceiling and floor or covering the corners?
  15. #15
    Join Date
    May 2007
    Location
    Posts
    3,993
  16. #16
    Join Date
    May 2007
    Location
    Posts
    3,993
    Default
    OK. Different.
  17. #17
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default
    Yes.
  18. #18
    Member Sales Rating: (0)
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    4,751
    Default
    Quote Originally Posted by Lasareath View Post
    If you have carpet the point is moot. I put Auralex acoustic foam on my ceiling but did not notice any differance, so I took it down. Having foam in the corners, on the side walls, and the back wall did the trick for my room. It is easy to over do the acoustic treatment and deaden the sound.
  19. #19
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default
    Quote Originally Posted by BlueFox View Post
    Thanks.
    I'm going to try to mount a few on the ceiling and then the corners, if I deaden it too much then I will remove some panels.
  20. #20
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default
    I just did the mirror trick on the side walls and since the 48x48's are so large they cover the 1st reflection point on the side wall just fine.
  21. #21
    Join Date
    Aug 2004
    Location
    Central Illinois
    Posts
    5,243
    Default
    As already stated - first reflection point is where you see the right speaker on the right wall (with a mirror and no, its not exact, but its pretty darn close). The second reflection point is where you see your left speaker on the right wall. If you can - cover both the first and second reflection points.
    The reflection points will help with imaging and mid-range/high frequencies from your main speakers. The traps in the corners are mainly for bass control and should be the more dense of the 2. i.e. - if doing a DIY, use Owens Corning 705, double thick across the corners, Use Owens Corning 703 on the side walls for the reflection points.
    (this is from memory, but I believe 705 is more dense and better for bass - 703 is less dense and better for mids/highs. If I am mistaken, reverse as neccesary)
    in either case, you will get better performance if you have the panels mounted a little ways off the wall (even an inch or two would be a big help - short pegs made from dowels would work fine for this) In the case of the corner traps - cross the corner if using flat panels rather than tucked along the walls in the corner.
    This...
    Not this....
    if that makes any sense.
    Michael
  22. #22
    Member Sales Rating: (21)
    Join Date
    Sep 2002
    Location
    Deep Down the Rabbit Hole
    Posts
    9,596
    Default
    Its all good Sal. Keep working at it. Lots of reflections, nodes, nulls, etc. but agree the panels are not rocket science. You might run some sweeps to see what happens at different frequencies.
    RT1
    REEL TIME THEATRE
    Onkyo-TX-NR5007
    B&K 7270 amplifier
    Polk SWA-500 Subwoofer amplifier
    OppO BDP-83
    Pioneer Elite 50"
    Polk LCi-RTS-105;LCi-RTS-C;LCi-RTSFx;LCi80Fx
    Subs-Twin Polk CSW200
    HTS5000
    RABBIT HOLE RIG
    BAT VK-31SE
    VTL MB-450 Signature monoblock
    Wolcott Presence monoblock
    Musical Fidelity kW SACD
    Rega P25/RB600/Clearaudio Aurum Beta
    Acoustech Phono-Pre
    Sound Lab Millenium ELS
    BillyBags Rack
    MIT S1/3 cables
    Shunyata/PS Audio/Virtual Dynamics Power Cords
    Everthing Matters...Tubes Rule...and It's Over until it's Not Over
  23. #23
    Join Date
    Feb 2007
    Location
    Roselle Park, NJ
    Posts
    10,913
    Default
    Right now I have the first reflection points on the sides walls done, I have a pair of panels on the floor temporarily that I intend to move to the ceiling and I have the corners filled and 4 panels behind my listening position.
    It sounds pretty damn good!, The SDA range and detail is much more defined, I am very happy!!!
    I bought a really nice stud finder that can tell you the difference between wood & metal studs, the thickness of the sheetrock and if there is electrical wiring in the wall where I am about to do some drilling and/or screwing.
    I'm going to use that for the ceiling mounted ones.
    Thanks All,
    Sal
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Is this reflection?
    By Face in forum 2 Channel Audio
    Last Post: 01-26-2008, 01:06 PM
  2. What's the point...
    By Serendipity in forum Car Audio & Electronics
    Last Post: 12-08-2007, 11:27 PM
  3. Aquariums - I know you all must have had one at some point
    By BaggedLancer in forum The Clubhouse
    Last Post: 09-24-2007, 08:42 PM
  4. F.E.A.R. Extracation Point
    By MrNightly in forum Video Games
    Last Post: 04-05-2007, 08:31 PM
  5. Boiling Point
    By VR3 in forum Speakers
    Last Post: 09-16-2003, 02:55 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
