Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 13 of 13
  1. #1
    Member Sales Rating: (22)
    Join Date
    Oct 2008
    Location
    Directly over the center of the earth in Olathe Kansas
    Posts
    5,794
    Default 12Volt Trigger cables
    My AVR(Denon 2808CI) has 12v trigger connectors as well as the outlet I am considering.
    What kind of connectors/cables to you connect the AVR and outlet?
    http://www.diguniverse.com/HOME-THEA...EO/DHACT1.html
    TIA
    Ofc: Wright WLA12 preamp: Anthem Amp 1: Pio Elite DV-79AVI: Airport Express: CAL Sigma II DAC: PA LS90 sonicaps and mills
  2. #2
    Member Sales Rating: (0)
    Join Date
    Feb 2008
    Location
    New Zealand
    Posts
    240
    Default
    Without knowing what you want to hook up. The 12v trigger uses a 3.5mm mono plug similar to a headphone plug, which is generally the same for all components. I use a similar cable to switch my power amp on automatically with my AVR.
    The switched outlet uses an elongated hex type plug from avr to an iec to another component. I use my switched outlet for my tuner.
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/show...p?userid=86838
  3. #3
    Join Date
    Feb 2008
    Location
    New Zealand
    Posts
    240
    Default
    A friend has no 12v trigger on his avr so had to use a dc convertor. It has the type of plug a switched outlet has, see in pic the plug middle right.
    http://search.digikey.com/scripts/Dk...me=T945-P6P-ND
  4. #4
    Member Sales Rating: (8)
    Join Date
    Jan 2006
    Posts
    1,306
    Default
    There are 2 types, mono and stereo. My gear requires 3.5 stereo wires for all the functions to work correctly. I had an oddball mono cable in my wire box and used in when setting up my gear. It took me 2 days to figure out what wire was causing the issue!
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  5. #5
    Member Sales Rating: (4)
    Join Date
    Apr 2009
    Location
    Northern New Jersey
    Posts
    1,293
    Default
    I'm using standard 3.5mm stereo cables from my Yamaha AVR trigger to a Monster HTS5100 trigger then from that to an Emotiva 12v trigger, and all is well.
    According to the equiptment specs I can use either a Mono cable or the easier to find stereo cable.
    Jimmy
  6. #6
    Member Sales Rating: (17)
    Join Date
    Oct 2002
    Location
    North Victoria Gardens, Altacucawanda, California
    Posts
    6,802
    Default
    Quote Originally Posted by Hawkeye View Post
    Gordon
    I always thought that it only requires 3.5 mono to trigger. Isn't it just to trigger the relay in AMP with ON or OFF position? Interesting that yours require mini stereo. What power AMP do you have? (just curious)...
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  7. #7
    Join Date
    Oct 2008
    Location
    Posts
    5,794
    Default
    Thanks All.
    Where can you buy or build such cables?
  8. #8
    Join Date
    Nov 2006
    Posts
    553
    Default
    Quote Originally Posted by thsmith View Post
    Thanks All.
    I suspect you can, but unless you need some super long cable you can get them for about $2 at radio shack
  9. #9
    Join Date
    Oct 2008
    Location
    Posts
    5,794
    Default
    Thanks, I may need one at least 10-12'. I will check with the shack
  10. #10
    Join Date
    Sep 2003
    Location
    Los Angeles
    Posts
    73
    Default
    This is probably a stupid question, but my Denon 2808CI has 2 mini audio plug ports for the trigger out, and my Parasound AMP has 4 raw wire screw blocks for its trigger in. Does this mean my Parasound can be started remotely by 2 different devices? I have never cut open the mini audio cable, but I would guess it has 2 wires inside. If so, how do i know which wires go to which terminal on the amp (or does it not matter)? I don't want to accidently fry my Parasound if I can help it.
    Looking at its manual does not explain the break down. Denon's website and manual also does not go into any detail.
    Lonwa
    “Sometimes good command decisions get compromised by bad emotional responses."
    Pioneer Elite PRO-1120HD
    Denon AVR-2808CI
    Parasound HCA-1205A
    Panasonic DMP-BD30
    DirecTV H20
    Belkin PURE AV
    Polk RTi38
    Polk CSi40
    Polk TC615i
    Polk TC60i
    PSW450
  11. #11
    Join Date
    Feb 2005
    Posts
    3,539
    Default
    You won't fry the parasound- it's optically coupled.
    Anyhow, IIRC only the middle two screws are used; the right one is ground and the left one is +12v (but anything close to 12v will work). On the minicable the braid goes to the ground. If there's no braid, then get a volt meter and see which one is hot.
    Backburner:Krell KAV-300i
  12. #12
    Join Date
    Jan 2006
    Posts
    1,306
    Default
    Quote Originally Posted by polkatese View Post
    The how and why my gear requires a stereo wire to trigger is beyond my electrical knowledge :o. I do know that in my system data flows over the "trigger" wires from the controller>Transport>DAC>preamp. Not audio signals but control signals i.e. change tracks. I had the mono cable between my controller and transport and could get nothing to work correctly.
    My amps are a pair of McIntosh 501's and they are daisy chained with stereo 3.5 cords also.
    Gordon
    2 Channel -
  13. #13
    Join Date
    Feb 2009
    Location
    Burbank, CA
    Posts
    79
    Default
    Gordon
    i believe you are referring to the control port not the 12v trigger ports. control ports go by several names but basically send info that would normally be sent by remote control. like next track.
    ________________________________
    Panasonic TH-50PZ800U; Sony BDP-S350
    Sony STR-DA5400ES; Carver TFM-55
    Carver TFM-35; Carver A-500x
    Sony Playstation 3; Custom HTPC
    Polk Monitor 10B Front; 2xPolk CS350LS Center;
    Monitor 5B rears (RB0194-1 Upgrade);
    Velodyne VA1012XII sub
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Cables,cables,cables, Digital AES/EBU decision
    By fbm211 in forum Basic Hookup/Wiring Questions
    Last Post: 06-16-2009, 12:14 AM
  2. IC Cables: Difference Between Source Cables And Amp/Preamp Cables?
    By Freak When C in forum Basic Hookup/Wiring Questions
    Last Post: 05-28-2009, 09:40 PM
  3. 12v trigger
    By superjunior in forum Basic Hookup/Wiring Questions
    Last Post: 05-17-2009, 10:20 PM
  4. 12volt Auto on/off wire; Where to get one?
    By G-2 in forum Electronics
    Last Post: 02-05-2008, 08:09 PM
  5. 12v Trigger
    By gwh in forum Electronics
    Last Post: 01-18-2008, 07:13 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
