Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Member Sales Rating: (0)
    Join Date
    Mar 2009
    Posts
    10
    Default Is Onkyo 606 enough for RTIA5+CSIA4+FXIA4+PSW125+Energy C-100?
    Hi, I just finished to complete my sound system: RTIA5 + CSIA4 + FXIA4 + PSW125 + Energy C-100. I have an Onkyo TX-SR606 and I was asking myself if this receiver is enough to support my system. Do I need to replace the receiver? Can I add other receiver? could you suggest me the best option please?
    thanks
  2. #2
    Member Sales Rating: (41)
    Join Date
    Apr 2008
    Location
    Milwaukee, WI
    Posts
    8,583
    Default
    Your receiver will do just fine but more power is always better.
  3. #3
    Join Date
    Mar 2009
    Posts
    10
    Default
    thanks Leroy for your fast reply.
    If I add another receiver, I don't know wheter it is possible or not, does the quality of the sound improve?
    Sorry by my noob question, but I'm new in sound systems.
    thanks
  4. #4
    Member Sales Rating: (22)
    Join Date
    Oct 2008
    Location
    Directly over the center of the earth in Olathe Kansas
    Posts
    5,573
    Default
    What do you feel you are missing ? Movies ? Music ?
    If you just want to upgrade AVRs look at AVRs with Pre outs so you can expand. I like Denons, Pioneer is popular here. You really need to understand what you do not like about your current setup and what you do like. From there you will get better suggestions.
    If you use the system mostly for Movies I think you are in fine shape.
    Ofc: Wright WLA12 preamp: Anthem Amp 1 PSVANE 6CA7: Pio Elite DV-79AVI: Airport Express: PA LS90 sonicaps and mills
  5. #5
    Member Sales Rating: (5)
    Join Date
    Apr 2005
    Location
    San Jose, CA
    Posts
    3,182
    Default
    Quote Originally Posted by arriagadaa View Post
    thanks
    Yes, there are differences between the brands signature sound and within each brand. Generally, the more you spend the better the sound...better parts, better DACs, as well as, more features. The 606 has a ton of features for an entry level AVR. It's plenty to run most HTs if your speakers don't represent a heavy load. Yours aren't. Paraphrasing thsmith, if you don't find it lacking now, then stick with it for awhile. Get a taste of what you like and dislike. If you decide you want more, do some research. Ask some questions. Get your ears around other options.
    That said, where that product is likely short changed is in the amp section and and overall sound quality department. That, and you can't use it as a pre/pro (no pre-outs).
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  6. #6
    Join Date
    Mar 2009
    Posts
    10
    Default
    Thanks all for your answers.
    I use my sound system to play movies and music (same use for both). I find my system working fine, but I just wanted to know if it will be a difference adding another receiver.
    thank you very much guys!
  7. #7
    Member Sales Rating: (11)
    Join Date
    Oct 2008
    Location
    Dixon, IL
    Posts
    6,510
    Default
    The 606 will do just fine powering that setup. I'm running a 606, with a fairly similar speaker setup.
    The speakers would benefit very much from more power though. I plan on upgrading to a Pioneer Elite SC-07 eventually. Some external amps will be coming along after that as well.
    The nirvana inducer-
    APC H10 Power Conditioner
    Denon DVD-2910 universal player
    DPA The Little Bit Three DAC
    Yamaha P-300 turntable/TCC TC-750 phono preamp
    Acurus L10 preamp
    Adcom GFA-545 power amp
    PolkAudio SDA 2A's/PolkAudio Monitor 7A's
    Audioquest Type 4 speaker cables
    Audioquest Sidewinder IC's
    Audioquest Black Mamba IC's
    Signal Cable Analog II IC's
  8. #8
    Join Date
    Oct 2007
    Location
    Pensacola, Florida
    Posts
    754
    Default
    I'm probably off base here but you have mentioned adding another receiver a couple of times. I'm assuming you mean "replacing" your receiver with another one. Correct? You cannot add a receiver. Other than that, I agree with everything said here. I think you're fine for now so you should just enjoy. Always good to plan ahead though. Good luck arriagadaa.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. CSiA4 Mod
    By curved in forum DIY, Mods & Tweaks
    Last Post: 07-12-2011, 09:21 PM
  2. Need Help 7.1 Setup With RTiA5, CSiA3, FXiA4, RTIA4, PSW10
    By RedBrave in forum Speakers
    Last Post: 04-06-2009, 08:24 PM
  3. RTi10 and CSiA4 or A6
    By metal83 in forum Speakers
    Last Post: 05-21-2008, 11:16 AM
  4. CSiA4, A6 vs CSi5
    By djlogix in forum Speakers
    Last Post: 05-02-2008, 04:00 PM
  5. CSIA4 center with M20's?
    By silvervulcan in forum Speakers
    Last Post: 03-23-2008, 02:21 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
