SORRY I mean BOTTOM LEFT
OUT
Opt-2 (VCR)
Digital Assignable
is this some sort of pre-out? can I hook it up to an amp?
Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
OUT
Opt-2 (VCR)
Digital Assignable
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Receiver: AVR Denon 789
HTPC Soundcard: Emu-0404 USB for 2.1, Creative X-Fi Platinum for 5.1 (SPDIF out to AVR)
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
TV: Toshiba Regza 52' 120Hz
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Since its assignable.....I would think that whatever source is connected through an optical digital INPUT on your receiver can also be sent OUT of that optical output on your receiver and you just choose what one you want it to be. My denon also has ins/outs for optical digital connection.
Know what I still have the manual for mine, I havent looked at it in a long time but I think Im right with what I said above. Ill double check though
Edit: Ok I was right, it shows here its meant to be used with CD/Mini disc/DVD recorders that have an optical digital input so you dont have to connect/disconnect optical cables when watching a movie using your surround sound AND recording a copy of it too or the sort.
so i can assign it to an external amplifier (if it takes optical in) right? or anything takes optical in.
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
I would assume you would connect it to an external DAC (Digital to Analog Converter) and then back into the CD inputs. (so your External DAC does the conversion instead of your AVR)
It could be used for alot of things, but that is probably what it was intended for.
Michael
^^^Cool feature if that's what it's for^^^
HT - Adcom GFA7400,Lsi15's,LsiC,Lsi7's,Signal Analog II IC's, Canare 4S11,APC S10,Onkyo TX-SR705,Sony BD-S1000ES
2CH - Douglas Connection Furez cables and IC's,Lsi15,Grant Fidelity Tube Buffer,Pioneer Elite DV-45A
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
I thought about that, but then figured if it's an unaltered signal then the volume will have no effect whatsoever on the optical digital output. You will then require a pre/pro to process this unaltered signal before sending it out to another amp. A receiver alone works as well but of course separates are always finer :D
ill be only getting sound thru PC soundcard and TV box..
i hope they mate:D
but i dont understand how the connection works.
say i play something from my PC, how do I get 2 front channels to a seperate amplifier? OR should I get a 5 channel amp so my receiver become useless?
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Don't think thats going to happen for you. (if you figure out a way though - definately tell us how you pulled it off)
When you decide to move to the RTiA9 or LSi series, time to get a new AVR or pre/pro and move this one with your old speakers to the bedroom or basement.....
Good Luck,
Michael
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
how about the Zone-2 preout?
for my understanding u can have both on at same time, so
if i assume
Senario 1:
playing 5.1 soundtrack thru AVR,
Zone-2 only gets the Front signal,
zone1 & zone2 sing together at same time
Therefore
Senario 2:
unplug front speakers from AVR,
connect zone2 preout to Seperate amplifier
Connect front speakers to Seperate amplifier
all 6 speakers sing at same time
too optimistic?![]()
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Thats what alot do and why theyre there, use the preamp outputs and power speakers using a seperate amp. Generally a much more powerful one at that, but it doesnt have to be because seperates just sound better most of the time.
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
For the speakers you have it is a good reciever. How soon do you honestly plan on upgrading the speakers?
Based on the speakers you have now, I would recommend the RTiA line - maybe just the 5 or 7 and there would not be an immediate need to upgrade your reciever at all. Just move your current fronts (RTi6) to the surround or surround back position and you are good to go.
Just work with what you have....
Michael
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
If you want it for 2 channel - set up a good 2 channel.
If you can't swing the A9 + amp + pre/pro (or cheap AVR with pre-outs), get something you can afford or wait longer.
You may be better off just trying to run A9's off that AVR than cobbling a solution together and ending up with higher expense for marginal sound. Then when you can step up to the pre-pro and amp (A.K.A. - do it right), do it.
Just my opinion...
Michael
Ok, lets say my soundcard has 5.1 analog out. divided by 3 x mini , and I use 3x mini>2RCA cables
Front channel: I connect one end to soundcard 1 end to seperate amp
Centre and sub: I connect them to AVR
rear: to AVR
so Ill end up all 6 speakers sing @ same time. is this gonna work?
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Why do you want to involve your computer in your HT rig? Is there a specific reason?
I would imagine the problem with using Zone 2 preouts for your mains and the rest of the speaker level outputs for the surrounds and center, is that the Zone 2 out volume is likely controlled separately from the Main speaker level outputs.
I'd follow McLoki's 'sound' advice.
While putting together a mishmosh of stuff might sound like a cheaper or at least more fun way to go, it adds complication to the setup-which can only lead to frustration--especially if you have a significant other or visitors. Now if your PC is actually part of your HT rig (Movie server, etc) that's a differnet story, but....
____________________
2-chnl : Pio DV-46AV (SACD), Dodd ELP, Emotiva XPA-1s, XPA-2, Odyssey Khartago, LSi9, SDA-SRS 2, SB Duet, MSB & Monarchy DACs, Yamaha PX3 TT, SAE Tuner...
Pool: Atrium 60's/45's
I wonder---it has HDMI out...which carries audio....
anybody see where I'm going with that?
ahh nevermind--adding complication again...
I suppose that would be a cool accessory for those that have an AVR with no preouts but want to go the route of an external amp without having to upgrade thier AVR in the process.
i think the HDMI out is for TV.. which the AVR upconvers analog video signal to digital. (i to p)
Front: Polk RTi6
Center: Polk CSIa4
Rear: Polk M10
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
The majority actually send full audio/video. I think it was before 1.13 that only video was sent, but its pretty unheard of nowadays to have an hdmi in/out that only processes one type of signal
There are currently 1 users browsing this thread. (0 members and 1 guests)
