Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Member Sales Rating: (2)
    Join Date
    Mar 2009
    Location
    El, Paso TX
    Posts
    293
    Default DIY record cleaning machine, possible?
    I have been throwing around the idea of doing this for a while now and I am trying to figure out the best way to do it, which is under 100 dollars. I recently purchased a hand-held Vac from Goodwill for the project. It is a hand-held Dirt Devil that plugs into the wall, with 5amps/600 watts. Do you think this is enough? It does seem to have some balls for a hand-held, it actually torques in you hand when you turn it on. Do you think that this will be enough power? After all, it does say on the box, "The power of an upright in the palm of your hand!"
    If anyone has ideas or tips about a DIY turntable, throw them in, I need all the help I can get.
    Thanks,
    Nate
  2. #2
    Member Sales Rating: (9)
    Join Date
    Sep 2006
    Location
    Baltimore
    Posts
    2,478
    Default
    I've seen it done, in fact I believe there's a thread around here where someone made one using a crevice tool and an upright vacuum. If I find it I'll post a link.
    Wris****ch--->Crisco
  3. #3
    Join Date
    Jan 2008
    Location
    Lakewood, CO.
    Posts
    106
  4. #4
    Member Sales Rating: (13)
    Join Date
    Jan 2005
    Location
    seattle,wa
    Posts
    920
    I used the teres audio link as a guide. I made one using an old throw away turntable and a $6 value village hand vacuum. I use a hockey puck with foam weather stripping on the bottom to turn the record. I plugged the end of the crevice tool with wood, cut a slot in it and glued velvet over it. It seems to work well, a little noisy, but the records are shiny clean and much quieter after a couple of cleanings.
    http://www.enjoythemusic.com/recordcleaner.htm
    D: SDTrans384 via I2S Teleporter-> Twisted Pear Audio Buffalo III DAC w Legato III I/V via XLR to Relaixed2 Preamp via XLR to Parasound A-21-> SDA-2.3 w/ RDO, Soniccrafts caps, Larry's Rings;
    A: Soundsmith Ruby LC Denon DL-103R-> Nothingham Spacedeck-> Hagerman Bugle2;
    C: Flac with Mediamonkey4 via coax SPDIF from Juli@24/192 -> Buffalo III
    V: Vinyl rips-> ESI Juli@24/192-> SPDIF-> Buffalo III
    SACD: Sony 333es via RCA
  5. #5
    Banned
    Member Sales Rating: (14)
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Quote Originally Posted by bikerboy View Post
    I wonder how your diy compares to a Nitty Gritty or VPI RCM as far as good deep cleaning goes.
  6. #6
    Join Date
    Mar 2009
    Location
    El, Paso TX
    Posts
    293
    Default
    I'm curious, how did your design manage or get rid of the the excess liquid?
  7. #7
    Join Date
    Jan 2005
    Location
    seattle,wa
    Posts
    920
    Smile Rcm
    Hi,
    I'm at work so may have to continue later. I will post pics later of the velvet covered wand. By excess liquid do you mean as you're cleaning the record. I use Tergitol and a steam cleaner, so its-steam, vacuum, tergitol, vacuum, steam and a final vacuum. The weather stripping foam on the hockey puck keeps the liquids off of the label. I use an old brush to scrub the record with the tergitol. I dont know how it compares to a "real" RCM but I wouldnt ever spend $350 to clean records when I have only spent $450 on the phono preamp. It does make records sound much quieter. So a good $40 (most of which was for the tergitol) invested on the vinyl source side of the sound system. Its just so hard to justify spending much on vinyl when my cd playback is so very good. The new transport and dac are incredible.
  8. #8
    Member Sales Rating: (47)
    Join Date
    May 2005
    Location
    Sufficiently Breathless
    Posts
    11,101
    Default
    I'm not as elaborate yet,as you,, but I use tergitol,, brush to "scrub",, then vac/rinse/vac..with my rainbow and a modified crevice attachment.
  9. #9
    Member Sales Rating: (3)
    Join Date
    Jul 2001
    Location
    SDA SweetSpot
    Posts
    5,220
    Default
    Quote Originally Posted by hearingimpared View Post
    Here's a thread you might find interesting:
    http://www.polkaudio.com/forums/showthread.php?p=1121994
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    __________________
    "Knowledge, without understanding, is a path to failure."~DK
  10. #10
    Banned
    Join Date
    Jul 2006
    Location
    Newark, Delaware
    Posts
    21,321
    Default
    Quote Originally Posted by DarqueKnight View Post
    Thanks for the great info Ray.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Record cleaning
    By Fongolio in forum 2 Channel Audio
    Last Post: 09-12-2009, 03:00 PM
  2. My Record Cleaning Machine
    By ckphoto in forum DIY, Mods & Tweaks
    Last Post: 04-07-2009, 02:36 AM
  3. WTB Record cleaning machine
    By Fongolio in forum Wanted (WTB) Classifieds
    Last Post: 05-11-2008, 12:16 AM
  4. Started work on a RCM(Record Cleaning Machine
    By BaggedLancer in forum DIY, Mods & Tweaks
    Last Post: 01-12-2008, 07:00 PM
  5. VPI 16.5 LP cleaning machine
    By TroyD in forum 2 Channel Audio
    Last Post: 02-10-2006, 11:49 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
