Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Member Sales Rating: (12)
    Join Date
    Jan 2009
    Location
    Bethlehem, PA
    Posts
    1,776
    Default Need honest opinion - feedback - pros/cons
    Hi all...
    I am, as many know, relatively new to the hobby. My equipment (For mostly home theatre use):
    Onkyo 606
    Monitor 50's (Fronts) 30's (Surrounds) CS1 (Center)
    Def. Tech Prosub 800
    Denon CD Player
    Now, here is the help required section...I know to eventually upgrade my speakers, I will need a new receiver - I have heard that I should look for one that preferably has pre-outs so I can hook in extra amplification. Now, I saw on sale on the forums an Onkyo 801 - I am assuming it is an older version of the 805/806 which is currently out. I have read that many find that a very nice receiver. My question is - what would I expect by using that instead of the 606 I have (With current speakers), and if you can comment on the potential it has for upgrades. For example...I believe the 801 does NOT have HDMI, where my current does...also it does not support True HD, where my current does. Would the extra power/preouts, etc. be an upgrade, or would I be better with what I have? I know my speakers are not the highest quality polks, and it will probably be some time before I upgrade. Please consider this a 'general' question, because this will probably not be very influential in my actually purchasing the receiver, unless it is a big upgrade...I am quite happy with what I have. I also see other receivers every once in a while (Here and other places) that have the same issues - more power, potential, but older without HDMI/True HD, and I'm never sure if it's better.
    Thanks for the input.
    Pycroft
  2. #2
    Member Sales Rating: (3)
    Join Date
    Oct 2004
    Location
    Mid-Michigan
    Posts
    3,499
    Default
    IMO, I would not do it If you mainly watch movies, and have HD and use the HDMI, or plan to. I'd hold tight. Now if you have cash to burn, skip the receiver, and go pre/pro and amp(s). Then the sub, followed by speakers if you feel you have to. If your listening levels are loud enough for you, and you don't change your speakers( not including your sub) I would say no less than 125-150 W\CH of separate amplification. If you end up with less efficient speakers, you would need more power for the same results, keep that in mind when you buy an amp. If you're going to upgrade your speakers, you might wanna go a little higher on the wattage so once you get the new speakers you're not kicking yourself, because you just got the amp x time ago and it's not enough for the new speakers. Plus, if you go with a pre/pro you don't have to replace everything, just get a new pre/pro with the new features, or new format compatibility.
    Like I said, IMO.
    later,
    dude
    Speakers: mains/2ch:SDA2a, surrounds-Monitor Series 7, center-CS350-LS, sub-Atlantic Technologies 172 PBM
    Control: AVR:Denon AVR 2106 powering surrounds and center(HT) pre: B&K PRO-10MC(2ch)
    Amps:Parasound HCA 1000a powering mains(2ch/HT)
    Sources: Oppo DV-970HD(2ch/HT), Xbox360(HT), PS2(HT), Wii(HT), Kenwood KT-5300(2ch)
    Cables:Philips/RCA/Monster
    Life's short, Listen to SDA's
    Where did SOPA go?
  3. #3
    Join Date
    Oct 2004
    Location
    Mid-Michigan
    Posts
    3,499
    Default
    Yeah, you know what happened.
    Where did SOPA go?
  4. #4
    Member Sales Rating: (0)
    Join Date
    Sep 2008
    Location
    Fairchild AFB WA.
    Posts
    3,630
    Default
    +1 on what dude said. If you use the HDMI and are able to take advantage of the new HD codecs, I would see this as more of a downgrade than an upgrade. Better off keeping the 606 for now and looking for something that supports HDMI and has pre-outs. I have an 806 and it is a very solid unit and at around $600 is hard to beat IMO.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    Polk Audio Monitor 10A's
    It's not that I'm insensitive, I just don't care.. :D
  5. #5
    Member Sales Rating: (7)
    Join Date
    Aug 2004
    Location
    Central Illinois
    Posts
    5,243
    Default
    So you are saying you MAY upgrade your speakers at some point in the future and you MAY choose speakers that need separate amplification. Based on that - you are thinking of selling your AVR that is working fine for you right now and getting something with Pre-Outs?
    You already crossed the AVR bridge - don't go back to it now for something that MAY happen. Enjoy your system for however long you choose to and when the time comes to upgrade your speakers - get your listen on. If the speakers you choose require separate amplification, get a pre/pro or new AVR then. Their may be new features out that you want by then anyway and for darn sure - there will be more AVR's on the used market that support the new HD codecs and HDMi.
    My strong vote is stop beating yourself up for choices you have made. Learn from them (research next time) and go on.
    You put together a nice budget system - put the money you were going to spend on a new AVR towards a netflix subscription and enjoy it.
    Michael
  6. #6
    Join Date
    Feb 2008
    Posts
    582
    Default
    I had a 605 and thought it was great to push my R50s and CS2. For Monitor 50s I would think the 606 is plenty. Wait until you NEED more power. Any move that you make now is likely to be less than ideal because you don't know what you need.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. pros and cons
    By chemical in forum Electronics
    Last Post: 06-17-2009, 08:25 AM
  2. Polk RT1000i pros and cons?
    By Aldous_Huxley in forum Speakers
    Last Post: 12-28-2008, 02:21 AM
  3. Pros/Cons of biamping the MMC6500s..
    By clcorbin in forum Car Audio & Electronics
    Last Post: 08-06-2004, 06:23 PM
  4. Sub positioning pros & cons...
    By denis87 in forum Car Audio & Electronics
    Last Post: 06-28-2004, 05:21 PM
  5. Pros and Cons-AGU vs. MAXI Fuses
    By MrDHEJ in forum Car Audio & Electronics
    Last Post: 01-06-2004, 11:57 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
