Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 13 of 13
  1. #1
    Member Sales Rating: (16)
    Join Date
    Jul 2007
    Location
    Andromeda
    Posts
    13,779
    Default Experiments in Vinyl Cleaning Terror
    I've been playing around some with home brew recipes from simple Dawn dishwashing liquid and isopropyl, to stuff I've bought specifically for record cleaning. I found this elaborate recipe on the web while searching, but haven't tried it. The ingredients are probably simple enough to get, but for me just looks to much to be a pita.
    http://www.diamondcut.com/vforum/arc...hp?t-1775.html
    I was reading on the Steve Hoffman forum where some vinyl addicts are using and swear by Glass Plus as a record cleaner. It doesn't contain ammonia like Windex and I'd never use anything with ammonia on my vinyl. Although I've heard some people do. Just the thought of putting Windex on a record makes me cringe because I'm assuming it would be corrosive. Regardless, I'd never try it.
    So anyway, I was bold enough to try the ammonia free Glass Plus method on a few meager LPs I have. I didn't use it full strength however. I mixed it in a half/half solution of purified water and a couple drops of Dawn in a spray bottle, then cleaned the records as usual with a soft, fine bristle paint brush. I rinse the vinyl first, followed by my Shark Steamer, clean with the solution and paint brush, rinse, steam and rinse again. I follow this with a thorough wipe with a carbon fiber cloth to remove any excess liquid, then air dry for about half an hour before spinning. I've only used the GP solution on really grungey records, but the results have been quite successful so far. Shiney, quiet LPs with little to no clicks or surface noise. Just passing this info along and you can try it at your own risk.
    http://www.stevehoffman.tv/forums/ar...p/t-39597.html
  2. #2
    Member Sales Rating: (17)
    Join Date
    Jul 2001
    Location
    Northern Colorado
    Posts
    11,914
    Default
    You have to watch out, some people think because you make it shiny it is clean. I've bought numerous used LP's that look great but are full of crud in the grooves. Some of them take several cleanings before they stop creating suds. This is just unacceptable.
    madmax
    Vinyl, the final frontier...
  3. #3
    Member Sales Rating: (0)
    Join Date
    Aug 2009
    Location
    Toronto
    Posts
    828
    Default
    Thank's for the tip's! How do you keep the label's from getting damaged?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  4. #4
    Join Date
    Jul 2007
    Location
    Andromeda
    Posts
    13,779
    Default
    Quote Originally Posted by sTiLlLeArNiNg View Post
    http://www.napaonline.com/MasterPage...on=Suction+Cup
    Works perfectly and a lot cheaper than the Groovemaster Label Savers.
  5. #5
    Join Date
    Aug 2009
    Location
    Toronto
    Posts
    828
    Default
    Cool! Also put's some handle's on there to make cleaning easier :D
    I guess it wouldn't matter if they were Napa brand or not? I find Napa to be overpriced for stuff like that and i usually go to Princess auto (Canadian equivalent of Harbour freight) for those type thing's.
    Thank's Keiko :)
    Media Room 7.1
    HTPC
  6. #6
    Join Date
    Jul 2007
    Location
    Andromeda
    Posts
    13,779
    Default
    PITA, but works until I can get a VPI.
  7. #7
    Join Date
    May 2005
    Location
    Six 'Burgh (Pittsburgh), PA
    Posts
    6,451
    Default
    Mike,
    I recommend using Mobile Fidelity Cleaning brushed for scrubbing the vinyl. Buy two, one for scrubbing and one for rinsing. The microfibers get down into the grooves and lift out all that **** deep in the grooves without harming the record. Get some replacement pads also.
    I think the cleaning process is the most important step. Most of the solutions work to varying degrees, but the cleaning method itself makes the biggest impact. It sounds like you have a good process.
    VPI machines ROCK!
    Carl
  8. #8
    Join Date
    Aug 2009
    Location
    Toronto
    Posts
    828
    Default
    quick Q: will a dirty album ruin the stylus quicker?
    Media Room 7.1
    HTPC
  9. #9
    Member Sales Rating: (49)
    Join Date
    Jan 2009
    Location
    In Hell
    Posts
    10,263
    Default
    Yep!!
  10. #10
    polkfan45
    Guest
    Default
    It would be easier if the made albums dishwaher safe... Just think how many you could wash at a time... :D
  11. #11
    Join Date
    Aug 2009
    Location
    Toronto
    Posts
    828
    Default
    ^^ ROTFLMFAO
    Quote Originally Posted by TOOLFORLIFEFAN View Post
    Yep!!
    I thought so, thank's :)
    Media Room 7.1
    HTPC
  12. #12
    Join Date
    Jul 2007
    Location
    Andromeda
    Posts
    13,779
    Default
    Keeping the stylus clean is as equally important as keeping the record clean.
  13. #13
    Join Date
    Jul 2007
    Location
    Andromeda
    Posts
    13,779
    Default
    Quote Originally Posted by schwarcw View Post
    Mike,
    VPI machines ROCK!
    Roger that Carl, thanks! I plan on getting it all together when I get the VPI. Hopefully before the end of the year. The method I have is effective, but it is a lot of work. A VPI would make vinyl life a whole lot easier for sure.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Vinyl cleaning tips...
    By nooshinjohn in forum 2 Channel Audio
    Last Post: 06-30-2009, 02:14 AM
  2. Cleaning vinyl records..................
    By treitz3 in forum 2 Channel Audio
    Last Post: 08-20-2007, 05:57 PM
  3. Cleaning up the Vinyl!
    By dkg999 in forum For Sale (FS) Classifieds
    Last Post: 11-17-2006, 11:36 AM
  4. Cleaning Vinyl
    By audiobliss in forum The Clubhouse
    Last Post: 09-15-2006, 02:38 PM
  5. Vinyl Cleaning
    By rlw in forum 2 Channel Audio
    Last Post: 11-10-2002, 10:47 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
