Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 26 of 26
  1. #1
    Member Sales Rating: (1)
    Join Date
    Sep 2009
    Location
    Austin, TX
    Posts
    1,644
    Default using Banana Plugs
    I was just reading the Polk FAQ's and saw that you can hook up your binding posts on the speakers with a banana plug and I was wondering how many of you do this and if it makes a difference in the sound?
  2. #2
    Member Sales Rating: (6)
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    I use bananas because of convenience and positive fit. I think the argument regarding spades vs bananas is a moot point. If anything, bananas have more surface area contacting the binding post. Bare wire connections are probably best; but can come loose causing other problems, and are not always practical depending on the type of wire being used.
    As far as sound, who knows. As long as your terminations (regardless of type) are non-corroding and a good electrical conductor (copper, gold, silver).
    Transport: Oppo BDP-103/USB HDD (flac)
    DAC/Preamp: Benchmark DAC/PRE
    Power Amp: Parasound HCA-1500A
    Speakers: Harbeth Compact 7ES-3 Monitor
    Cables: Kimber Hero/8TC; DH Labs D-75
  3. #3
    Member Sales Rating: (27)
    Join Date
    Jun 2003
    Location
    Wish I knew...
    Posts
    4,520
    Default
    Its more for convenience. Sonically i dont think it will change much over bare wire or spades etc...
    Pauly
    Life without music would
  4. #4
    Member Sales Rating: (5)
    Join Date
    Jul 2009
    Location
    Jackson, Ms.
    Posts
    2,340
    Default
    Quote Originally Posted by steveinaz View Post
    I use bananas because of convenience. I think the argument regarding spades vs bananas is a moot point. If anything, bananas have more surface area contacting the binding post.
    +1
    I have never heard a difference. Nanners are easier to swap out, so I use them.
  5. #5
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    Also, avoid soldered connections if at all possible. It's better to have a good, properly crimped connection.
  6. #6
    Banned
    Member Sales Rating: (0)
    Join Date
    Apr 2009
    Location
    Louisville, KY
    Posts
    1,533
    Default
    I use solder style banana connectors with built in strain relief. Why is the crimped connection better?
  7. #7
    Join Date
    Sep 2009
    Location
    Austin, TX
    Posts
    1,644
    Default
    thanks guys.. i'm actually using bare wire connections right now but I was a little worried about what if a strand or two come loose and cross with the other side.. i'll go ahead and pick up some more bananas then I think and reconnect my speakers with them.
  8. #8
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    Quote Originally Posted by jinjuku View Post
    There's alot of tin/lead in solder, not the best conductor. A properly crimped connection needs no solder. Also, adding solder in the mix introduces another "transition" from wire-solder-connector-binding post. In audio, less is more.
    Not saying it can't be done--of course it IS done alot, but it's not an ideal setup.
  9. #9
    Banned
    Join Date
    Apr 2009
    Location
    Louisville, KY
    Posts
    1,533
    Default
    There's alot of tin in solder, not a very good conductor. A properly crimped connection needs no solder. Also, adding solder in the mix introduces another "transition" from wire-solder-connector-binding post. In audio, less is more.
    And the solder connections in the x-over? A lot of the leads are tinned in solder on the components in an x-over.
  10. #10
    Member Sales Rating: (31)
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    Exactly, so why add more?
  11. #11
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    ...and there's thousands of solder joints in a $15,000 preamp too. It's cost-effective, and speeds up production, but it's not ideal.
  12. #12
    Join Date
    Jul 2009
    Location
    Jackson, Ms.
    Posts
    2,340
    Default
    That is exactly what I have read. Silver solder properly done being the exception.
  13. #13
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    Yes, but even silver solder is a compromise---albeit a necessary one.
  14. #14
    Member Sales Rating: (11)
    Join Date
    Aug 2007
    Location
    L.A.
    Posts
    3,194
    Default
    I use them for convenience, since I keep swapping stuff out to see what I think is best, and it's a PITA! Spades aren't too bad, but nanners are easily the most convenient. Otherwise, I would actually prefer bare wire, but I'm no scientist or engineer, so I am not basing this preference on any solid facts, but hey! Since when did facts matter on an audio forum?!
  15. #15
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    My bad, I forgot.
  16. #16
    Join Date
    Feb 2007
    Location
    Long Island
    Posts
    14,790
    Default
    Solid silver spades or bare wire trump brass bananas any day of the week.
  17. #17
    Join Date
    Sep 2009
    Location
    Texas
    Posts
    785
    Default
    There are zero, nada improvements except as some posters said, convenience and less chance to "short" your amp. For most of the mid- price AVR, these 5 way binding posts are clustered in a small area, for safety reason more than convenience, I prefer the single banana plugs than bare wire or space lugs. Bare-wire and space lugs can get loose and the consequence sometimes is not a nice thing to see, especially when you have a high-current amp.
  18. #18
    Join Date
    Jun 2003
    Location
    Wish I knew...
    Posts
    4,520
    Default
    Just use coat hangers and call it a day :D:D
    Pauly
  19. #19
    Join Date
    Sep 2009
    Location
    Texas
    Posts
    785
    Default
    Quote Originally Posted by Pauly View Post
    Pauly
    Believe it or not, some people believe in the metal cloth hanger not as connectors but as ICs. After all, we are just moving electrons from point A to point B within 1 meter length piece if wire. Please do not try this at home by yourself, leave it to the laundry pro.
    Who cares about capacitance, inductance, resistance!!!!!!!
    :D
  20. #20
    Join Date
    Sep 2009
    Location
    Austin, TX
    Posts
    1,644
    Default
    Quote Originally Posted by anhchungdoan View Post
    yeah I actually have bananas on my AVR i was more referring to the speakers themselves.
  21. #21
    Join Date
    Jun 2003
    Location
    Wish I knew...
    Posts
    4,520
    Default
    :D
    this i know... This is CP afterall
    Pauly
  22. #22
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    Quote Originally Posted by Face View Post
    I wouldn't use "brass" anything for audio connectors. I'm talking silver, copper or gold plated bananas. My first set of Kimber 8TC had Kimber PM 33 copper spades; my current set of 8TC has Kimber banana's, I'll be damned if I can tell a difference. Both were 8' pairs.
  23. #23
    Banned
    Join Date
    Apr 2009
    Location
    Louisville, KY
    Posts
    1,533
    Default
    I have been using silver solder (4%) for all my DIY cabling and x-overs.
    I think poo-pooing soldered connections vs crimped with all the other soldered connections (literally 1000's) is just a bit over the top.
  24. #24
    Join Date
    Sep 2003
    Location
    Arizona
    Posts
    16,491
    Default
    Hey bubba, it's your rig, do what you want. Some connections must be soldered, no doubt--that's where silver solder works best if the components can take the heat necessary to melt silver solder.
  25. #25
    Join Date
    Sep 2009
    Location
    Texas
    Posts
    785
    Default
    Quote Originally Posted by coolsax View Post
    Same thing, brother. Either way, there are nada improvements. I hate space lugs even though there some claims that it will have more surface contacts but I ain't hear no improvements.
    Hi-end guys love the space lugs but I do not need to impress myself so either single banana plug or bare-wire goes straight to the binding post.
  26. #26
    Banned
    Join Date
    Apr 2009
    Location
    Louisville, KY
    Posts
    1,533
    Default
    Here is a Youtube video on soldering some banana jacks.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Banana Plugs...
    By Shicks18 in forum 2 Channel Audio
    Last Post: 08-15-2009, 10:18 AM
  2. Need help on Banana Plugs
    By Atrocity in forum Basic Hookup/Wiring Questions
    Last Post: 01-15-2009, 10:28 AM
  3. Banana Plugs
    By Mike Kozak in forum Wanted (WTB) Classifieds
    Last Post: 01-23-2008, 07:10 PM
  4. banana plugs
    By Willow in forum Basic Hookup/Wiring Questions
    Last Post: 04-07-2004, 09:00 PM
  5. Banana Plugs
    By aba4430 in forum Speakers
    Last Post: 02-26-2004, 06:50 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
