I am planning to purchase a set of LSi9's for music listening in my family room. Considering my options on how to power them. I have an Onk 806 sitting in the closet not being used. Considering flipping the switch on it to 4ohm and running with that. on the other hand..... I was also looking at an Emotiva 2 channel amp that delivers 185wpcX2 at 4ohms. I could use the Onk as a pre amp with the Emo. Not sure what my old Onk does at 4ohms, but it would have to be about 200watts. Appreciate any suggestions.
One other question...
If I used the Onk as a pre amp and drove the LSi9's with the Emo, can the Onk still drive a set of 8ohm speakers direct from the receiver at the same time. That would enable me to listen to the same thing in 2 different rooms... one room with the LSi9's from the Emo, and a second room with a set of RTiA1's direct from the receiver set at 8ohms. Not sure if the receiver can do both at the same time. If the pre-out is connected for the front speakers, does that disable the direct outs from the receiver? or can they both work at the same time? Thanks!
