Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Member Sales Rating: (0)
    Join Date
    Apr 2007
    Location
    Albuquerque, NM
    Posts
    653
    Default SurroundBar 42 experiment
    Hello,
    I am experimenting with my SurroundBar 42", isolating the surround channels to try to get a more surroundy effect. I used the Set Menu on my AVR to set the center channel to NONE and turned off the front left & right channels with the A/B switch on the AVR. So what I end up hearing is nothing but the surround effects. I played the opening scenes from Master & Commander which has lots of water and creaky ship noises on the surround channels, later followed by cannon fire.
    I closed my eyes and just listened. What I hear is that half to two thirds of the surround effects appear to originate from the front, occupying a sound stage that is maybe 2 feet wider on both sides of the SB42. The rest of the sounds are spread out directly to the left and right with an occasional sound appearing to come from behind.
    My TV & SB42 are set up on the short wall of my 13' x 19' living room. There is an 8' opening to the 13' x 14' dining room opposite from the TV. The ceiling height is 8'-3" I have attached my room layout.
    Has anyone else been able to achieve a more surround like effect from their SurroundBars, that is, a less frontal surround field? I have tried adjusting the relative volume of the surround channels through a range of +0 db to 10 db, without much effect. Is 13' not quite enough room for the SDA to develop a more encompassing surround field?
    Regards,
    Jim
    5.1 System:
    Sharp Aquos 37" LCD
    Front: SDA-CRS+
    Center: CS400i
    Surround: Monitor 7A
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    NAD 106 pre-amp
    Panasonic DMP-BD85 Blu-Ray
    MacBook Pro 2.16 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  2. #2
    Join Date
    Apr 2007
    Location
    Albuquerque, NM
    Posts
    653
    Default
    Additional note:
    I just double checked the connections to make sure they were in phase. They were so that is not the problem. Any other ideas?
    Jim
  3. #3
    Join Date
    Apr 2007
    Location
    Albuquerque, NM
    Posts
    653
    Default
    Has anyone else tried this?
    Jim
    5.1 System:
    Sharp Aquos 37" LCD
    Front: SDA-CRS+
    Center: CS400i
    PSW10 subwoofer
    NAD 106 pre-amp
    2.0 Office System:
    MacPro
  4. #4
    Join Date
    Apr 2007
    Location
    Albuquerque, NM
    Posts
    653
    Default
    Jim
  5. #5
    Join Date
    Nov 2008
    Location
    Albany, NY
    Posts
    965
    Default
    I have to think that you can only mimic surround sound so much... Push comes to shove, ALL of the sound IS coming from in front of you. I don't think it's built for demanding listeners, I think they are band-aid solutions for a person that can't or won't set up a full system.
    If you want true surround sound, I think you need a real 5.1 or 7.1 system.
  6. #6
    Join Date
    Apr 2007
    Location
    Albuquerque, NM
    Posts
    653
    Default
    Thanks, Upstatemax. I am moving towards a true 5.1 system, but I was wondering if anyone had any tweaks to obtain a less frontal surround field from the SB42.
    Jim
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Review A little experiment...
    By steveinaz in forum 2 Channel Audio
    Last Post: 06-08-2008, 03:38 PM
  2. XLR vs. RCA Experiment
    By Early B. in forum 2 Channel Audio
    Last Post: 04-15-2007, 12:25 PM
  3. my summer beer experiment
    By Micah Cohen in forum The Clubhouse
    Last Post: 07-07-2005, 01:38 PM
  4. The mad experiment continues...HAHAHA
    By Jonesy in forum Speakers
    Last Post: 01-10-2005, 05:10 PM
  5. Photo experiment
    By joe6pak in forum The Clubhouse
    Last Post: 02-25-2003, 02:55 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
