Buy Direct M-F 9am - 10:30pm EST 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Member Sales Rating: (0)
    Join Date
    Feb 2009
    Location
    Burbank, CA
    Posts
    79
    Default Using seperate amps with integrated receiver
    Hey guys,
    I recently started acquiring some separate amps to use with my integrated receiver.
    Ive got a Sony STR-DA5400ES and i'm using the pre-outs to send signals to my carver amps. Currently i have a TFM-55 for mains and TFM-35 for center hooked up. The Sony is only powering the surround speakers (1 pair)
    My concern is that the Sony still gets quite hot while in use, and it since it's only driving the surround channels it seems to me that it shouldn't get so warm.
    I was unable to find any information in the Sony manual about any settings to
    change when using external amplifiers, and i am wondering if there is any common practices that people do when using a setup like this?
    Would a receiver like this be able to automatically disable its internal amplifiers if no speaker is connected to a channel? Or is it still trying to send the signals to all the speakers?
    I tried setting the speaker selector (A,B,A+B,OFF) to Off, but that turns off the pre-out's as well.
    Would installing jumpers from + to - complete the circut with 0 load be something to try, or would that create a short and fry the amp? i remember seeing jumpers on one set of speaker terminals on old receivers that allowed for hookup of multiple pairs of speakers, but that was only on one set. Is at least some load required?
    Maybe the Sony gets hot just from its video processing chips, but I thought it wouldn't get as hot when using external amplifiers. :(
    Any thoughts on this subject would be greatly appreciated, or if no one has any experience with this particular setup, i'll post results if i find some.
    luke
    ________________________________
    Panasonic TH-50PZ800U; Sony BDP-S350
    Sony STR-DA5400ES; Carver TFM-55
    Carver TFM-35; Carver A-500x
    Sony Playstation 3; Custom HTPC
    Polk Monitor 10B Front; 2xPolk CS350LS Center;
    Monitor 5B rears (RB0194-1 Upgrade);
    Velodyne VA1012XII sub
  2. #2
    Join Date
    Jun 2007
    Location
    North of New Orleans
    Posts
    3,306
    Default
    Many receivers run warm without any output.
    There are many components that create heat.
    Try it without any output and note it's temperature.
    Is it any different?
    The vast majority of audio amplifiers are still voltage sources so do not short them out.
    There are amps available that are current sources which can be shorted.
    If fact, they have to have a complete very low impedance circuit to properly function.
    We use these in our advanced power lab to simulate power system current transformers, however these are are not what you see as a typical audio amp. We use a specially modified version of the following amp.
    http://www.aetechron.com/7782.html
    Main HT/2 ch:
    Pioneer KRP-500M, SC-07, BDP-05FD, Emotiva XPA-5 x 2, XPA-1 x 2,
    Polk Audio LSi25, RTi12 x 2, LSi15 x 4, LSiC x 2, PSW1000 x 4,
    MB HT/ 2 ch:
    LG 47LM5800, Pioneer VSX-9040TXH, BDP-23FD, Sony BDP-S790, Emotiva XPA-2, XPA-5,
    Polk Audio LSi25, LSi15, CSi5, LSiFX, PSW505 x 4
    Listening Room 2 ch:
    Emotiva RSP-2, RPA-1, ERC-2, Pro-Ject RM5.1, Focal Chorus 814V, DSW600
    Adcom GCD 750, GFP 750, GFA 5802, Polk LSi9, DSW600
  3. #3
    Member Sales Rating: (58)
    Join Date
    Feb 2003
    Location
    6 Underground
    Posts
    25,086
    Default
    Don't worry about it Luke, its normal. Now turn the music up and sit down.
  4. #4
    Member Sales Rating: (13)
    Join Date
    Sep 2007
    Location
    Bridgeton NJ
    Posts
    4,240
    Default
    ^^^ What he said
    HT setup
    Dynex 40 inch tv
    Denon DBP-1610
    Monster HTS 1650
    Pioneer Elite VSX-81TXV
    Carver A400X
    MIT Exp 3 Speaker Wire
    Martin Logan Aerius
    Apple Tv 2nd Gen
    Logitech Harmony One Advanced Remote
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  5. #5
    Member Sales Rating: (1)
    Join Date
    Oct 2007
    Location
    NE PA
    Posts
    1,458
    Default
    I think what everyone is saying, and at least what I believe to be the case but don't know, is that even when using the pre outs of an AVR the entire amp section remains active. You just don't have the load on it you normally would have. This also (again not sure on this) means you can still over drive the AVR amps and induce clipping.
    Hope someone in the know here can add more to this as I would like to know if my thoughts on this are correct as well.
  6. #6
    Join Date
    Jun 2008
    Location
    Silicon Valley
    Posts
    4,644
    Default
    I am using the Sony 7100ES with an external amp, and it gets as hot as when it was being used as an amp. This also surprised me as I thought it would not get hot, so I put my DVD player on top of it. Since the DVD player was a Sony 9100ES, the two looked good stacked in that manner, but when I happened to touch it and felt how hot is was I immediately removed it. So, I guess unless one gets a dedicated pre/pro heat is something AVR users have to accept.
  7. #7
    Join Date
    Feb 2009
    Location
    Burbank, CA
    Posts
    79
    Default
    Thanks for the input guys, i'll check the temp with no output.
    im a bit sad that i can't disable the internal amplifier. :( oh well sounds better with the carvers, so i guess its worth it.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. One amp vs. Seperate amps
    By REDWING3139 in forum Basic Hookup/Wiring Questions
    Last Post: 09-12-2008, 10:48 PM
  2. Best Integrated amps for $400 - $700 used
    By AndyGwis in forum Electronics
    Last Post: 04-08-2007, 06:54 PM
  3. Split signal from Yamaha to seperate amps
    By MillerLiteScott in forum 2 Channel Audio
    Last Post: 03-03-2007, 07:51 AM
  4. Integrated Amps & Receivers
    By AllTheTimer in forum Electronics
    Last Post: 07-30-2004, 08:34 PM
  5. AV Receiver vs. Seperate Amp
    By cookaa in forum Electronics
    Last Post: 07-01-2002, 08:54 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
