Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Results 1 to 12 of 12
  1. #1
    Member Sales Rating: (0)
    Join Date
    May 2006
    Posts
    108
    Default hiding a dswpro 600 in a wall....
    So I am building a theater with a false wall, I will have around 30 inches of space to build a cavity for the sub in.......directly above the cavity for the sub will be a built in for a tv.....I do plan on double drywalling and using green glue on this room......is there anything special I should know/do when I build this?
    Should I have the sub be forward firing or downward firing?
    Any special materials inside the cavity to dampen sound so it does not rattle the whole false wall?
    Any input is appreciated.
  2. #2
    Join Date
    Mar 2010
    Posts
    68
    Default
    jkg, Polk makes in-Wall subwoofers which are more suited for that type of implementation. Often times you can find them for cheap on the eBay store.
    _________________________________
    Onkyo TX-SR805
    RTi8 | CSi5 | F/XiA6
  3. #3
    Join Date
    May 2006
    Posts
    108
    Default
    dsw pro 600 is already bought.....actually two of them are......want to hid both to make room on stage for towers and center..... building a mitsubishi dlp into the wall.......
  4. #4
    Join Date
    May 2006
    Posts
    108
    Default
    anyone?
  5. #5
    Member Sales Rating: (26)
    Join Date
    Oct 2006
    Location
    The tube lair in Charlotte, NC
    Posts
    11,298
    Default
    Well, I'll tell you this. That sub was not built to be put into a cubicle, it was built too remain out in the open. That said, all the advice we could give you will be lost in the end result of bad sound.
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction". - Kenneth Swauger
  6. #6
    Join Date
    May 2006
    Posts
    108
    Default
    what will the difference be if it becomes front firing, the port is on the same side as the driver....how will that effect sound if it pushes out towards the open area of the room?
  7. #7
    Join Date
    Oct 2006
    Location
    Posts
    11,298
    Default
    Port?
  8. #8
    Member Sales Rating: (4)
    Join Date
    Apr 2009
    Location
    Northern New Jersey
    Posts
    1,293
    Default
    Page 4 of the owners manual tells you how to prepare the sub for a cabinet installation, which is pretty close to what your trying to do.
    I've tried the Pro-600 in the front firing position in an open room, and found I liked the down firing position better, because it had more punch.
    In the front firing position the remote control won't work due to the fact the receiver will be on the top face of the sub. Also the spacers that Polk gives you are not high enough to fit straight cables under the sub, so you'll need to get angle connectors for the power cord and the RCA cable, or just raise the sub some other way.
    Jimmy
  9. #9
    Join Date
    Oct 2006
    Location
    Posts
    11,298
    Default
    Quote Originally Posted by treitz3 View Post
    Quote Originally Posted by jimmydep View Post
    Daggum, I stand erected. :o
    I have not yet heard a sub that sounds decent in an enclosure. Too much "boom" and not enough room for the sub to breathe properly IMO. Sound waves need to travel, especially those in the lower octaves. Bouncing off closely bordered walls on 5 sides of the sub has got to be detrimental to the sound waves. The same theory applies to a main set of speakers.
  10. #10
    Join Date
    Apr 2009
    Location
    Northern New Jersey
    Posts
    1,293
    Default
    Tom, you'll get no argument from me , I think it's much better to place a sub in an open room, but if you have no other choice, it might work ok......
  11. #11
    Join Date
    May 2006
    Posts
    108
    Default
    thanks guys, ill think about just leaving them up on the front stage, to the left and right of the center....
  12. #12
    Join Date
    Apr 2009
    Location
    Northern New Jersey
    Posts
    1,293
    Default
    Good Idea!!!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. For Sale DSWPRO 400 Subwoofer (used) & RM20 set (brand new)
    By mdk5068 in forum For Sale (FS) Classifieds
    Last Post: 07-30-2009, 10:10 AM
  2. Need Help Dsw microPro 1000 or DswPro 600 subwoofer
    By jimmydep in forum Speakers
    Last Post: 06-22-2009, 11:52 AM
  3. No hiding on the internet
    By gatemplin in forum The Clubhouse
    Last Post: 12-02-2005, 05:32 PM
  4. Hiding Wires??
    By zkazi in forum Basic Hookup/Wiring Questions
    Last Post: 01-20-2005, 03:50 PM
  5. I'm not hiding
    By liv4fam in forum The Clubhouse
    Last Post: 01-06-2003, 12:27 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
